P0456 - Which Gas Cap works best?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RockfordTaco2006, Nov 17, 2024.
  1. Nov 17, 2024 at 9:57 AM
    RockfordTaco2006
    RockfordTaco2006 [OP] Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    I swapped my gas cap with a few different Auto store caps. Some seem to work for a while but i got the code again. It'll go away a couple days then come back for a couple days.
    Is there anything better than a New OEM Gas Cap?
    Is there anything I could do to give me a better seal? ....like a grease or a gasket around the bare metal gas intake?
    Thanks!
  2. Nov 17, 2024 at 11:14 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    OEM is the only gas cap that seems to work on Toyotas, others are hit or miss.
    That being said if the sealing surface is damaged or pitted from rust then nothing is going to seal well.
  3. Nov 17, 2024 at 11:25 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Coming up on seven years with a Gates locking cap, 31840. Never given me a code, but, sometimes, you don't need the key to remove it.
    RockfordTaco2006[OP] likes this.
  4. Nov 18, 2024 at 7:42 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    OEM is the only way too go.
  5. Nov 21, 2024 at 1:57 PM
    lynlan1819
    Tacoma
    Lifted
    Any others are a hit or miss,I tried a bunch of locking caps,and ended up back stock as I got tired of codes coming up monthly.
