P0500
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jagmk09, Dec 15, 2016.
  1. Dec 15, 2016 at 9:06 AM
    jagmk09
    jagmk09 [OP] New Member
    Al
    2005 Toyota Tacoma
    I have a 2005 Tacoma 4WD with 138000K that throws a P0500 code periodically. Speedo OK and trans shifting fine, just have the annoying light about every 30-40 mile or so. It also goes off by itself without clearing codes. I bought the truck 4 months ago and the dealer put new tires on it (30 inch) so I thought tire size could be an issue but I drove it 180 miles home and for 2 weeks following with no issues. Any ideas?
  2. Dec 15, 2016 at 9:10 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    a quick look up says vehicle speed sensor...
  3. Dec 26, 2016 at 4:49 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    :popcorn:
    Did you fix this?
  4. Dec 26, 2016 at 5:53 PM
    woof359
    woof359 Well-Known Member
    theres a software update for this code on some years, it caused by a differance in input shaft speeds
  5. Dec 26, 2016 at 7:46 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    P0500:
    • Open in VSS+/VSS- harness circuit.
    • Open in TCSS signal or TCSS signal return harness circuit.
    • Short to GND in VSS harness circuit.
    • Short to GND in TCSS harness circuit.
    • Short to PWR in VSS harness circuit.
    • Short to PWR in TCSS harness circuit.
    • Open or short in the vehicle speed circuit(s) (VSC) between the PCM and appropriate control module.
    • Damaged VSS or TCSS.
    • Damaged wheel speed sensors.
    • Damaged wheel speed sensor harness circuits.
    • Damage in module(s) connected to VSC/VSS circuit.
    • Damage drive mechanism for VSS or TCSS.
    VSS = Vehicle Speed Sensor
    TCSS = Transfer Case Speed Sensor
  6. Dec 26, 2016 at 7:55 PM
    Justinlhc
    I plugged it into a Solus Ultra and got a few more codes C0210 C0215 for rear speed sensors. Tested them and they came back good, but they had a thick coating of paste-like oil on them. Hopefully cleaning that off fixes it :notsure:
  7. Dec 26, 2016 at 8:43 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    Cool, it's always nice when you find something suspicious...
