P0500
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NwiTACO, Dec 2, 2009.
  1. Dec 2, 2009 at 8:06 PM
    NwiTACO
    NwiTACO [OP] Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    So my speedo and odometer went out yesterday. Along with this the ABS, check engine, and Brake lights came on on the dash.
    Code read from scanner is P0500. Any help would be appreciated. I doubt its the wheel sensors, cause all 4 would've had to go out...
  2. Dec 2, 2009 at 8:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Thats a speed sensor malfunction. Check for broken wires...or a bad connection
  3. Dec 2, 2009 at 8:16 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    vehicle speed sensor?
  4. Dec 2, 2009 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Dec 2, 2009 at 8:23 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
  6. Dec 2, 2009 at 8:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Dec 3, 2009 at 4:28 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Thanks! I'm assuming the auto and manual both have this sensor? Sucks that it went out after 4 1/2 hours into a 5 hour trip out of town for work for 2 weeks. Oh well...sh1t happens...
  8. Dec 3, 2009 at 4:30 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Nevermind. Dumb question. I was scouring that whole manual last night...dont know how I missed that page!
    OK, so how do I know if it is Speed Sensor (NT) or speed sensor (SP2)?
  9. Dec 3, 2009 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I*m not really sure.
  10. Dec 3, 2009 at 5:12 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    If you have access to an oscilloscope you can check each sensor individually to determine which one has the fault. If you don't have one, you could possibly take the sensors to a shop and have them tell you which one is bad.
  11. Dec 3, 2009 at 5:42 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    What wavform am I looking for? I'm assuming a square wave just indicating pulses?
  12. Dec 3, 2009 at 6:17 PM
    SC4333
    Grant
    San Antonio, TX
    Yes sir, you got it.
  13. Mar 25, 2011 at 11:05 AM
    colvilletacoma
    colvilletacoma Well-Known Member
    Central Washington
    Toyota Tacoma
    OME 886 Coils, Bilstein 5100's in Front, Tuff Country in Rear, Custom Racks with winch built in
    I got this same problem, replaced all 4 wheel speed sensors, and the 2 on the tranny. None of which seemed to fix the problem, still throwing 2 codes saying the rear two speed sensors are out but I tested both of them on the front and vice versa and they all work. Im assuming it must be in the instrument cluster and has something to do with the speedometer itself?
  14. Sep 9, 2012 at 9:49 AM
    NHCrewcab2008
    NHCrewcab2008 Well-Known Member
    Thornton, NH
    SR5 TRD
    I just had this exact issue, part comes tuesday, taco is useless until then, thanks so much for posting the links to repair manual sheets. I wouldn"t have thought to use ATF and a proper torque for such a small part.
  15. Sep 18, 2012 at 9:47 AM
    NHCrewcab2008
    Thornton, NH
    SR5 TRD
    I am still having the same problem as well, any fix yet?
  16. Sep 18, 2012 at 9:57 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    I added a old school t-case speed sensor and spliced the signal wire in at the abs ecu. Works like a charm. Much thanks to Wyatt for this one.
    This is only a option if you have an 06 or older as they stopped knocking the blank out of the tcase casting so new models dont have a place to add this sensor.
  17. Sep 18, 2012 at 10:13 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What part did you replace?
  18. Sep 18, 2012 at 6:32 PM
    NHCrewcab2008
    Thornton, NH
    SR5 TRD
    The speed sensor on the tranny and that didn't work, I found a broken ABS sensor on the right front axle and just replaced it this morning. It drove fine for 3 miles and flipped out again. I then decided to make sure all tires were inflated properly and that the brake fluid was topped off, disconnected the battery for 10 mins again and then took it out for a few 40 mph hard brake tests to engage the ABS system. It seems so far that after the first 2 brake tests it did some sort of self check and reset and all seems fine now.
  19. Sep 19, 2012 at 5:55 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Any idea how the sensor wire broke?
  20. Sep 19, 2012 at 9:31 AM
    NHCrewcab2008
    Thornton, NH
    SR5 TRD
    It wasn't the wire, it was the actual senor, cracked in two places, next to the bolt, and the part that goes into the axle was broken off inside. I had to drill and dig it out. It acted up again this morning when I tried to start it but has not been an issue since.
    *edit*
    It turns out I had two wires wrong in the harness for my towing, I think I may be problem free now. I hope!
