P0606... Am I SOL?
Discussion in 'Technical Chat' started by memario1214, Apr 26, 2012.
  1. Apr 26, 2012 at 9:30 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So this morning I turned the truck on and started driving. I noticed that my CEL was on, so I checked my Ultragauge to see what it was. The code was P0606, which upon using Google was discovered to be a PCM / ECM Processor Fault. So am I pretty much effed here? Gonna have to buy a new ECM? Can you just swap them in and out?
  2. Apr 26, 2012 at 11:33 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    reset code and see if comes back. still factory battery?
  3. Apr 26, 2012 at 11:34 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It's windows OS and just needs a reboot..........
  4. Apr 26, 2012 at 11:37 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    I am sorry to read about your P0 606 code. Yes it is a PCM problem, but it always doesn't mean it is the computer. My book says that you should let the dealer hook it up and see what the problems is. I see that you are out of warranty, so if you know of a good repair shop that has invested in a good PCM diaganostic machine. I don't know how the truck has been driven and I can't say why the PCM is failing, but it will fail soon if it is not fixed.
    You may want to check the electrical connections going into the PCM to see if they are Corroded or frayed. Sorry about the bad news, I hope it can be fixed. Good Luck.
  5. Apr 26, 2012 at 11:39 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this
    I shot a code a few months ago and once it was reset it never came back.
    It was saying I had an over-retarded diff censor or some crap.
