P0705 and P0456 in 04 engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by blwill5974, Jul 14, 2014.
  1. Jul 14, 2014 at 7:14 PM
    blwill5974
    blwill5974 [OP] New Member
    Rome, GA
    04 tacoma SR5 TRD
    My 04 tacoma (3.4L) threw these two codes today at the same time. Just curious if anyone has seen anything like this and if they could possibly be related? I read a little bit about the p0705 code in 05 trucks and it doesn't sound good but couldn't fine much about a 04 truck. I read a little about the transmission sensor but couldn't find the part so I'm assuming it is internal? Any suggestions to try before taking to a mechanic would be appreciated. Thanks!
  2. Jul 14, 2014 at 8:02 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Here's some info I found.
    p0705 - Transmission Range Sensor Malfunction
    Possible Causes:
    -Faulty Park/Neutral position switch
    -Misadjusted Park/Neutral position switch
    -Park/Neutral position switch is open or shorted
    -Park/Neutral position switch circuit poor electrical connection
    p0456 - EVAP Control System Leak Detected Very Small Leak
    Possible Causes:
    -Missing or loose fuel cap
    -Incorrect fuel filler cap used
    -Fuel filler cap remains open or fails to close
    -Foreign matter caught in fuel filler cap
    -EVAP canister or fuel tank leaks
    -EVAP system hose leaking
    -Fuel tank leaking
  3. Jul 14, 2014 at 8:05 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Also for the p0705 code, the park/neutral position (PNP) switch includes a transmission range switch. The transmission range switch detects the selector lever position when the shift lever is in the N or P shift position and sends a signal to the Transmission Control Module (TCM).
  4. Mar 13, 2017 at 12:33 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    My 2003 just threw this code and won't shift up out of second. I've heard it can be throttle position, gear shift solenoid, or PRNDL input sensor.
