P0705 code popped on yesterday
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rondog, Jan 19, 2014.
  1. Oct 24, 2018 at 11:29 AM
    #81
    wmchenry02
    wmchenry02 Well-Known Member
    Wil
    2007 Tacoma
    Does anyone know if I am supposed to take out the plastic bolt that the metal bolt is attached too? This is a new NSS and will not go on the spindle that is on the tranny.NSS.gif NSS.gif
  2. Oct 24, 2018 at 11:31 AM
    #82
    wmchenry02
    Wil
    2007 Tacoma
    Did your new NSS have a plastic "bolt" that you had to take off in ordered to get it over the spindle on the tranny?
    lynyrd3[QUOTED] likes this.
  3. Oct 24, 2018 at 1:17 PM
    #83
    lynyrd3
    Bill
    East Central Upstate NY
    Got me :notsure: I pay to have that stuff done ! I am mechanically challenged o_O
  4. Jan 10, 2019 at 2:54 PM
    #84
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    Were you able to fix it?
  5. Jan 10, 2019 at 3:05 PM
    #85
    wmchenry02
    Wil
    2007 Tacoma
    I was able to "fix" it with a new Neutral Safety Switch. The fix worked well for about 1000 miles but now its throwing t in e same code. I believe the switch is not on all the way like it should be (my mechanicless knowledge) so I have to get up under it to see what I can do to get it on there all the way.
  6. Mar 1, 2019 at 5:43 PM
    #86
    wmchenry02
    Wil
    2007 Tacoma
    Do you know if the NSS has to be flush against the transmission case in order to work properly?
  7. Mar 2, 2019 at 12:37 PM
    #87
    rondog
    Ronnie
    Escondido/San Diego
    I think its that rectangular metal thing that goes through it that actuates the switch so for it to be flush, I dont think it *has* to be, but when I put mine on, it sat pretty flush.
  8. Mar 8, 2019 at 7:34 AM
    #88
    wmchenry02
    Wil
    2007 Tacoma
    Thanks Rondog!
  9. Mar 8, 2019 at 7:36 AM
    #89
    wmchenry02
    Wil
    2007 Tacoma
    I replaced the NSS a couple of months ago and I am now having the same issues and the same code. (705)
    Looking for opinions..
    Should I take apart the shifter to look for issues or should I look for a wiring harness that goes into the NSS?
  10. Mar 8, 2019 at 1:21 PM
    #90
    rondog
    Ronnie
    Escondido/San Diego
    If its not the NSS itself, could be the harness. That would def be the next place I check. I dont have much experience with electrical so I'm not sure how you'd test it. Maybe give the connectors a good cleaning
  11. Mar 8, 2019 at 1:30 PM
    #91
    wmchenry02
    Wil
    2007 Tacoma
    Thanks!
    Do you know the part number of the harness or what I would type to search for one?
  12. Mar 8, 2019 at 1:31 PM
    #92
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the range sensor flush against the side of the trans? Yours looked pretty rusty, if it was hard to get the range sensor off the little ecentric shaft it may be hard to get it all the way on
    wmchenry02[QUOTED] likes this.
  13. Mar 8, 2019 at 1:59 PM
    #93
    wmchenry02
    Wil
    2007 Tacoma
    Yes it was rusty and very hard to get on even after cleaning the shaft.
    b_r_o[QUOTED] likes this.
  14. Mar 8, 2019 at 3:28 PM
    #94
    wmchenry02
    Wil
    2007 Tacoma
    Do you think that because it's not flush that it could be throwing the code again? And causing the issues.
  15. Mar 8, 2019 at 3:50 PM
    #95
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea, possibly. When the shaft turns the sensor has to turn with it to be accurate. The symptoms youre describing indicate that the range sensor is "out of adjustment". Some cars give you slots/room to adjust the sensor back and forth
  16. Mar 8, 2019 at 5:33 PM
    #96
    wmchenry02
    Wil
    2007 Tacoma
    Ok thanks.
    Do I just get under and turn it one way and drive it like that for a while to see how it turns out? Do I need to loosen it up to turn it or just force it a hair?
  17. Mar 8, 2019 at 5:51 PM
    #97
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Im not sure if the range sensors we've got allow for adjustment, some of them are adjustable, some are fixed. Look for slots at each bolt that would allow it to rotate.
    If the sensor was on there for a while twisted/bent it may be damaged again. In past ive really had to clean that shaft with a wire brush to get the rust off and get the sensor on without damaging it.
    REDdawn6 and wmchenry02[QUOTED] like this.
  18. Jul 9, 2020 at 2:32 PM
    #98
    88Taco
    88Taco Well-Known Member
    Michigan
    Black 08 DCSB TRD Off-road.
    Rear diff breather mod. Block heater
    Adding for people that come here with this problem in the future. Check your trailer harness first. Had this issue and replaced the switch with no luck. Turns out I smashed the harness in a rock and bent 4 pins over on each other. Straightened the pins and I was good to go.
    gearcruncher, KTM753 and b_r_o like this.
