P0705 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mytaco-D, Apr 23, 2024.
  1. Apr 23, 2024 at 3:43 PM
    Mytaco-D
    Mytaco-D [OP] New Member
    2007 Tacoma prerunner
    none
    Hi guys need your help, I have a Tacoma 2007 4.0L I am having transmission issue.I am getting P0705 neutral switch code, when I shift into drive it take about 5 seconds before it jerk into gear. What I am finding is that if you shift from drive to neutral roughly 4 time it will ingage straight away also if you shift to the lowest gear its fine also. PS I HAVE TRIED 2 DIFFERENT TRANSMISION WITH DIFFERENT NEUTRAL SWITCH AND I AM GETTING SAME PROBLEM. HELP HELP
  2. Apr 23, 2024 at 6:33 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What does the connector and wires at the connector look like, any broken wires/green crusties?
    I'll grab the diagrams here in a bit but which light(s) don't light up on your PRDNL display when you shift through the gears?
  3. Apr 23, 2024 at 7:23 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can check all the signals from the switch backprobing connector PB on the junction box behind the glovebox.
    Each pin should be at battery voltage with the shifter in the respective position, the rest should be at or near 0v.
    Pin 5 (Green/Black) Park
    Pin 6 (Red/White) Reverse
    Pin 8 (Blue/White) Neutral
    Pin 3 (Blue/Black) D & 4
    Pin 1 (Yellow) 3
    Pin 7 (Red/Yellow) 2 & 1
    GilbertOz likes this.
