P0705 Park Neutral Switch
Discussion in 'Technical Chat' started by RustyC, Apr 8, 2010.
  1. Sep 19, 2014 at 11:01 PM
    #41
    CyberKnight
    CyberKnight Member
    Atlanta, GA
    05 PreRunner SR5 LB
    TacoSmitty - Just went through all this, no "P" LED, flickering "D" LED, no Cruise Cntrl, occasional delayed shifting, and code P0705 on my 05. Went through all the various DIY steps in this thread with no improvement.
    JB#1 may have corrosion issues but they have nothing to do with the P0705 code. I know because I disconnected every connector (there are at least 8) in the driver's side kick and the PRNDL LEDs continued to function uninterrupted. Cleaned and sprayed DeOxit on them while there though.
    Did the same with the Driver's Side J/B (cabin fuse panel) and all 6 connectors on it - no help. So did the Inst Pnl J/B #2 behind glove box, and still no improvement.
    Last possibility was the connector at the PRNDL switch on the transmission so I used contact cleaner & DeOxit on it and, good news!, that completely cured all the problems in the list above - every one of them!
    But be aware that the moisture seal for this connector is embedded in the bottom of the transmission mounted male connector. This means that getting the cable mounted female back on can be a pain as the last 1/10 inch compresses the rubber gasket in the male connector - so you have to apply considerable force to get the two halves LOCKED back together. More than just finger pressure, unless you have a lift and can get a better angle on it than I could laying on my back unable to extend my arms much. (I used small channel-lock pliers to gently squeeze the two halves together, but be careful as the plastic is old and could crack)
    That was 3 weeks ago and everything is working perfectly since with no flickering PRNDL LEDs and no codes thrown, which is most important.
    Hope this helps you with yours...
  2. Sep 21, 2014 at 8:38 AM
    #42
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Several days and 400 miles later I cancled the alarm and no more "pending code"...just an update...
  3. Nov 29, 2014 at 5:55 AM
    #43
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    I got one too last night. As it happened I noticed that I was resting my hand on the shifter at a red light and it slipped from D to 4. I am thinking I was resting on it just enough for the truck to think it was in both D and 4 and threw the code. At least that's what I hope.
  4. Dec 20, 2014 at 10:01 AM
    #44
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    I was plagued with the occasional delayed shifting (was happening a couple times a day, at least).
    I believe I solved the issue by replacing the neutral safety switch, located on the side of the tranny. I've had the new one installed for the past 2 days and the delayed shifting hasn't happened yet. You can read my full post here: http://www.tacomaworld.com/forum/2n...0705-code-popped-yesterday-4.html#post9603230
  5. May 19, 2015 at 7:48 AM
    #45
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    Just so we're on the same page as I've been experiencing these issues, That is for a Tundra in the PDF so the parts aren't the same. And the PRNDL switch you're describing is actually the Neutral safety switch as shown here: http://www.rockauto.com/catalog/moreinfo.php?pk=1186600&cc=1432865&jnid=514&jpid=0
  6. May 19, 2015 at 1:19 PM
    #46
    gearcruncher
    Canadain bumper technician
    Oops , my bad .Toyota terminology .....Park neutral position switch .
    General motors call it the prindle switch .Park / Reverse /Neutral /Drive /Low
    In the illustration ,the Tundra and Tacoma share the same transmission and identical Park neutral position switch .
    The illustration is from an old post that I simply copy and pasted . At the time , thats all the information I could find for the switch .
    There are some better sources now .
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/02700610.pdf
    http://www.customtacos.com/tech.old...06toyrm/06toypdf/06rmsrc/rm2006ta/0280013.pdf
  7. May 19, 2015 at 1:23 PM
    #47
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    Just to give another update, since my Park neutral position switch was replaced, I have not experienced the problem.
    wmchenry02 and lynyrd3 like this.
  8. May 19, 2015 at 3:56 PM
    #48
    Smoke
    Eastern Ontario
    2006 SR5
    Thanks. It might also be geographical because here in Canada even Toyota called it a neutral safety switch. But I'm glad that cleared it up, I was so confused when researching.
  9. May 29, 2015 at 5:32 PM
    #49
    Smoke
    Eastern Ontario
    2006 SR5
    Update: I had the hard shifting issue, i got under there and the cable doesn't go to the NSS, it goes to the drivers side and attaches to a balljoint. I sprayed some penetrating oil on the cable and it works perfectly now.
  10. Mar 30, 2016 at 12:01 AM
    #50
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    That's what I did. I sprayed the cable linkage and the shafts seal where it goes into the transmission with some a Liquid Wrench penetrating oil and the tight shifting and intermittent PRND light issues are gone. Sprayed it good a few times and cycled the shifter back and forth a bunch of times with the ignition in the run position but engine not started. Works great now.
  11. Apr 16, 2018 at 8:28 PM
    #51
    Woody06
    Woody06 Well-Known Member
    Maryland
    06 DCLB Sport
    6"lift procomp with 2 in lift struts custom alcan 8" leafs in the rear bilstein shocks
    Did anyone's speedometer stop working with this code??
  12. Apr 17, 2018 at 4:43 AM
    #52
    lynyrd3
    Bill
    East Central Upstate NY
    I had a stall issue when moving shifter into D or R . Had the P0705 code .Replaced sensor on tranny and stalling is gone . But now hesitates for a count of 5 before engaging in gear when moving from P to D .No check engine light on . Still trying to figure it out .Wiring harness and junction block like new .Had full flush done , problem still exists .
  13. Apr 19, 2018 at 4:22 PM
    #53
    lynyrd3
    Bill
    No
  14. Apr 19, 2018 at 4:24 PM
    #54
    lynyrd3
    Bill
    Anyone have the delayed engagement moving from P to D ?
  15. Apr 22, 2018 at 4:22 AM
    #55
    lynyrd3
    Bill
  16. Aug 24, 2018 at 5:29 PM
    #56
    builder
    builder Member
    Boston area
    '06 Access Cab
    I have the hard shifting and P0705 code, and it sometimes stalls when I put it in park. Let you know how it goes after I try all fixes listed here.
  17. Sep 1, 2018 at 7:59 AM
    #57
    ozzy73
    ozzy73 Active Member
    Milton, Ontario
    2005 Toyota Tacoma TRD 370 KM
  18. Sep 1, 2018 at 8:41 AM
    #58
    builder
    builder Member
    Boston area
    '06 Access Cab
    Cleaned the contacts with deoxit, while I had everything apart dripped TriFlow into the cable ( slid back the rubber seal so the lube could get to the cable/ housing) repeatedly over the 20 minutes I was cleaning the contacts. Worked the cable back and forth, slowly kept adding Triflow and now the shifter moves like new. Still stalls in neutral though, but stopped stalling in park.
  19. Sep 22, 2018 at 12:08 PM
    #59
    wmchenry02
    wmchenry02 Well-Known Member
    Wil
    2007 Tacoma
    I know its been years since you posted but thought I would check anyway. I also have increased force needed to move the shift lever - and sometimes it wont go into Drive. Did you ever find out what is wrong with yours?!
  20. Sep 24, 2018 at 10:42 AM
    #60
    wmchenry02
    Wil
    2007 Tacoma
    Did you have a problem with it going into gear before this or just the "hard to put the shifter into gear"?
