P0724 error code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbraumb11, Feb 16, 2022.
  1. Feb 16, 2022 at 3:09 PM
    tbraumb11
    tbraumb11 [OP] Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    Today while driving my check engine light came on and I read the code and it was P0724 brake light switch.
    The traction light was also on.
    I checked the tail fuse with a test light and it was blown so I know I need to replace that fuse but what is weird is I just replaced that fuse about a week ago.
    reason i replaced it about a week ago was that the traction control and ABS light were coming on out of nowhere and somewhere someone mentioned to check the tail fuse it might be blown and sure enough it was.
    any idea what would be causing it to blow and what else i should look at after changing fuse?
    Thanks,
  2. Feb 16, 2022 at 3:36 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Do you have a trailer light harness/module connected to your brake and turn signal lights? If so, look for possible shorts in there.
    Dm93 likes this.
  3. Feb 16, 2022 at 3:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Test the brake light switch
    Dm93 likes this.
  4. Feb 16, 2022 at 5:14 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I second this, if you have an aftermarket trailer plug adapter that would be the primary suspect area for both issues.
    If you have a factory tow package 7 way plug, your gona have to look for shorted wires and test the brake light switch outputs.
    You may also want to edit your title as P0274 isn't a valid code:spy:
    tbraumb11[OP] likes this.
  5. Feb 16, 2022 at 5:44 PM
    tbraumb11
    nanaimo
    what are those?
    Thanks for pointing out my typo but I dont know how to edit.
    I will check these things this weekend as I am out of town and have limited tools in my truck on the road.
    no aftermarket its a 2015 trd sport with factory harness.
    Dm93[QUOTED] likes this.
  6. Feb 16, 2022 at 5:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    At the top of the page click thread tools>edit title.
  7. Feb 16, 2022 at 5:48 PM
    tbraumb11
    nanaimo
    what are those?
    Got it thanks!
