P0748 - Pressure Control Solenoid A Electrical
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DR_SEYMOUR_BUSH, Jul 21, 2016.
  1. Jul 21, 2016 at 8:14 PM
    DR_SEYMOUR_BUSH
    DR_SEYMOUR_BUSH [OP] Well-Known Member
    Tony
    Vancouver, BC
    2008 TRD Sport DCLB BSP
    Bilstein 5100's/OME 885, LR UCA, URD exhaust/intake, Frontrunner rack
    Hey guys,
    Was driving last night and hit a rut on the highway, kicked my Tacoma from fifth to fourth gear and spat out an engine code for a solenoid electrical problem. Haven't been able to shift my truck into fifth gear since, everything else seems to be working fine. I checked both the transmission wire and harness/connector but no luck. Does anyone know how to check the shift solenoid valve SL1? I've researched diagrams but haven't had any luck, and am hoping I don't need to drop the pan to better inspect it. Not to keen on dropping it off at a transmission shop :(
  2. Jan 29, 2019 at 7:48 AM
    2011TRDSPORT
    2011TRDSPORT Well-Known Member
    Len or Lenny
    Kamloops, BC, Canada
    Tacoma TRD Sport. Magnetic Gray
    2" front and rear.
    Bump.. I've for a 2011 TRD Sport. I've got the same code after some heavy wheelin' in 4-low with chains on for an extended period of time. I've also got a P0986 code for the Shift solenoid SR circuit or valve. I've printed a bunch of infor off prodemand.com at work. Just wondering if anyone else has any experience with this stuff. Thanks!
