P1135 error code. Where to buy part?
Discussion in '1st Gen. Tacomas (1995-2004)' started by m32, Jan 22, 2012.
  1. Jan 22, 2012 at 8:07 PM
    m32
    m32 [OP] Well-Known Member
    Edwin
    2013 DCSB TRD
    Guys/gals
    I have the p1135 code and through searching, it the sensor before the cats. Does anyone know the part number and where I can buy one?
    Edwin
  2. Jan 22, 2012 at 8:19 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
  3. Jan 23, 2012 at 6:42 PM
    stucoma05
    stucoma05 Member
    Just did mine, took a risk and got the sensors off ebay for 25 each with the harness, but my check engine light came back on today. I think its the throttle position sensor, but going to check the code tomorrow and will let you know.
  4. Jan 23, 2012 at 6:44 PM
    stucoma05
    stucoma05 Member
  5. Jan 23, 2012 at 7:40 PM
    m32
    Edwin
    2013 DCSB TRD
    How long did you have it in? Did it come back immediately?
    I thought the pre-cat sensor was a air/fuel sensor and not o2?
    Edwin
  6. Jan 23, 2012 at 7:52 PM
    stucoma05
    stucoma05 Member
    2 days and no it didnt, i had to double check to be 100% but heres some pics i found from a write up. thanks for the reply, and any more in advance!
  7. Jan 23, 2012 at 8:23 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Having a code does not always equal needing to buy a part. Troubleshoot the problem before you go out and buy stuff that may not fix the problem.
    Dalandser likes this.
  8. Jan 23, 2012 at 9:19 PM
    stucoma05
    stucoma05 Member
    Well I figured it was either buy 2 o2 sensors that I could pretty easily replace, or buy a new cat conv. and have to take it to a shop.
  9. Jan 24, 2012 at 3:44 AM
    m32
    Edwin
    2013 DCSB TRD
  10. Jan 24, 2012 at 5:43 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I had the same code. My cat was completly clogged.... So i took the insides out of the cat and it runs smooth.
  11. Jan 24, 2012 at 8:25 AM
    misterdmac
    Doostin
    '97 2.7L DLX
  12. Jan 24, 2012 at 10:39 AM
    marcchrisv
    marcchrisv Well-Known Member
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Toytec 2.5" lift., just the beginning. Front Builstein coil-overs fully adjustable from 0-3". 2" AAL in the rear with 2.5 degree shim. Total Chaos uni-ball UCA's.
    I did the same thing on my 4cyl. Cat was clogged, took the cat off, knocked the insides out, and now I have a CEL on all the time. It's the Bank 1 sensor 2 that is throwing the code, however they don't make an O2 mod for these sensors (since they aren't screw in). I'm considering just buying a new cat, but after ordering 3 and having them all show up as the wrong part, I give up. I guess there are several different designs for the 1st gen 2.7 liter cat, and no one carries the one that i need. PITA!
  13. Jan 25, 2012 at 9:20 AM
    misterdmac
    Doostin
    '97 2.7L DLX
    Were you trying to get direct fit bolt-on or the universal fit? I've replaced a cat on that engine and had no trouble with part confusion. This one would fit, that is if you still have the flanges on either side.
    http://www.carpartswholesale.com/v5...html/?location=Rear&sc=Product+Listing+Page:7
  14. Jan 25, 2012 at 9:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    http://www.urdusa.com/Electronics-R...,-2RZ-FE-2.4L-,-3RZ-FE-2.7L/product_info.html
  15. Jan 26, 2012 at 9:37 AM
    marcchrisv
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    I had ordered a direct fit, and it was the long one that they sent me (apparently the california emissions), then they sent me one that was only 12" long, direct fit as well. After spending more on return shipments than i had really wanted to spend on the cat itself, i finally gave up. They did offer to pay for return shipping on the second one in lieu of me purchasing the 17 5/8" correct one (at an additional $130) on top of the 150 i spent on the first 2 and the $40 return shipping for the first one (which took several weeks to refund). I do plan on getting another cat though.. Thanks for the link to the page.. I think that's way cheeper than the one that i had found on autopartswarehouse page.
  16. Jan 26, 2012 at 9:40 AM
    98tacoma27
    Ben
    Not Beech Creek
  17. Jan 26, 2012 at 11:38 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Internet searches range from $230 to $85 for the exact same part manufacturer and number. How is that possible? Somebody is screwing a lot of consumers.
    Anyway, I found one on Amazon for $84.99 + $2.99 S+H.
    Rockauto was $97.95 + $2.99 S+H
    I got the same P1135 code - it must be the season for sensors to go bad.
  18. Jan 26, 2012 at 11:55 AM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Make sure you get a denso sensor!
  19. Jan 26, 2012 at 3:44 PM
    Boerseun
    Ferdie
    Sarasota, Florida
  20. May 22, 2012 at 9:50 AM
    Biscay89
    Biscay89 Member
    '01 Double Cab Sr5 v6 4x4
    Volunteer emergency vehicle
    Hello all.
    The check engine light came on my 2001 Tacoma Double Cab 4x4 SR5, V6 this weekend. I had no idea what it was related to but knew I was due for an oil change. I replaced air filter, oil filter, oil and the light went out. To double check, I stopped by AutoZone who hooked it up and got a P1135 error code. Since the light was out.. I assumed my issue was resolved. Questions:
    1) Should I play it safe and swap out the Denso since the error code is still there despite the light being out?
    2) Does the part number change given my Tacoma age/model or is it as Boersun listed above?
    OEM Denso is 89467-35060
    Replacement Denso is 234-9001
    3) Anyone have a step-by-step procedure for this repair? I have a tendency to make small repairs into bigger ones and would prefer to keep this simple.
    Thanks for any/all input.
    Biscay89
