P1135 error code. Where to buy part?
Discussion in '1st Gen. Tacomas (1995-2004)' started by m32, Jan 22, 2012.
  1. Sep 29, 2015 at 12:01 PM
    #61
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Buy some PB Blaster and soak those nuts and studs thoroughly before you attempt to take the nuts off. Otherwise, you'll likely snap the stud in half and have to remove the pipe in order to have the stud drilled out and replaced.
  2. Oct 19, 2015 at 5:28 PM
    #62
    HenryG
    HenryG Well-Known Member
    Washington State
    Update: Ordered the Denso and swapped it out right away. I've had it on the truck for about two weeks with no issues.
    picturethis likes this.
  3. Feb 23, 2016 at 9:48 AM
    #63
    MCObray
    MCObray Well-Known Member
    Oregon
    2002 Toyota Tacoma DC TRD
  4. Mar 3, 2017 at 11:27 AM
    #64
    Veryhelpfulforum
    Veryhelpfulforum New Member
    Liquor in the front, poker in the rear
  5. May 25, 2017 at 4:22 PM
    #65
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Thanks for the info guys. Gonna confirm the part number at the dealer then order it online.
  6. Oct 29, 2017 at 8:16 AM
    #66
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    So kind of a old thread. But.. so i have the same code. I replaced my upstream o2 sensor with a denso unit. 9003. I cleared my CEL and the code came right back. Any suggestions?? I have the #2 sensor (post cat)that im going to replace also. Thanks for your help.
  7. Oct 29, 2017 at 12:28 PM
    #67
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    What's your engine? For the 2.7l, there is no P1135 listed, but there is a P0135, which reads about the same. This is for your Bank 1/ Sensor 1 - Air/Fuel sensor, not your O2 sensor (although they are both commonly called O2 sensors). I don't see that code for the 3.4l either.
    I've had trouble with that code also. Did the diagnostics on a brand new sensor. The new sensor was good. The relay checked out good too. I did get the light off after checking and reseating all connections (twice).
  8. Oct 29, 2017 at 12:30 PM
    #68
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I have the 3.4. With a manual transmission.
  9. Oct 31, 2017 at 4:21 PM
    #69
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    So dose anyone know how to tell wich wire is the +B and wich is the HT ?
    I did try and check the relay for continuity. It seamed ok. I also tryed replugging in the sensor.
    Thanks.
  10. Oct 31, 2017 at 5:03 PM
    #70
    ghs57
    Chops
    Catskill Mts. NY
    Look at the tabs on the plug in the diagram. It's a PITA to check. I had my laptop under the truck with me so I was sure I was reading from the right prong.
    I also switched relays with another of the same type in the fuse block. Somewhere in the process, the battery was disconnected, which reset everything. The light never came back on after that (for this code anyway - I had an EVAP code shortly thereafter). This was over a year ago now.
  11. Oct 31, 2017 at 5:07 PM
    #71
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    That should be the same for the 3.4 right??
  12. Oct 31, 2017 at 5:08 PM
    #72
    ghs57
    Chops
    Catskill Mts. NY
    As far as know it is, but I've never has a 3.4l. I'll check the FSM again.
  13. Oct 31, 2017 at 5:16 PM
    #73
    ghs57
    Chops
    Catskill Mts. NY
    Yes it looks the same. B is the upper left, and HT the upper right.
    This is a different code, shows how to check the A/F sensor on the 3.4l.
    98tacoma27 likes this.
  14. Oct 31, 2017 at 5:24 PM
    #74
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Cool thanks.
  15. Nov 11, 2017 at 9:58 PM
    #75
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    So a little update. New denzo didnt fix the issue. So i broke down and took it into the shop. Turns out it was the ground on the intake manifold was bad/loose. Problem seams to be resolved. They said that it can leave you car/truck dead in the water. I guess its the first thing they check.
    Hope this can help someone else out.
