P11F0
Discussion in 'New Members' started by Sullyone3, Jun 4, 2025.
  1. Jun 4, 2025 at 1:55 PM
    Sullyone3
    Sullyone3 [OP] New Member
    Gabe
    2019 Tacoma TRD
    Bought a 2019 TRD and the check engine lights on. After further research I have a P11F0 code. I’ve looked through the forum here and see that it’s a ratio issue in the 5th cylinder I guess. My question is how much is this gunna run to get the work done. Any help is much appreciated.
  2. Jun 4, 2025 at 1:59 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Sorry to hear that. If you just purchased the truck recently, I would hound the hell out of whoever sold it to you to try to get them to do something helpful about it.
    The typical fix is a new cylinder head, plus 2 new exhaust valves for the affected cylinder and then labor to move all the other valves to the new head and of course install the head. It's not a small job. I would say typical price to do it is $5-8k.
