P2000 Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by cooperman1516, Apr 28, 2016.
  1. Apr 28, 2016 at 7:40 AM
    cooperman1516
    cooperman1516 [OP] Member
    1997 Tacoma 2.7L, 4x4, 5 spd, xtra cab
    None....she's stock :)
    Hello everyone,
    I searched the forum for the P2000 error code and nothing relevant comes back. Have any of you had/dealt with this code? I cleared the code and waited the 100 or so miles and sure enough it came back. I checked the service manual and see nothing listed for P2000. I know it has to do with NOx levels but not sure what that translates to on the truck.....maybe EGR, injectors..etc
    Any help is greatly appreciated
  2. Apr 29, 2016 at 6:27 AM
    cooperman1516
  3. May 6, 2016 at 3:21 PM
    eon_blue
    Azusa, CA
    Just saw your thread and that no one chimed in, so here's my best guess based on what I've read. Seems like the P2000 code is a pretty uncommon one to see in Tacomas.
    A google search showed that it's an issue with Dodge trucks frequently, basically it's an emissions related issue. From what I gather, a lot of guys seem to have some luck solving the issue by cleaning and or replacing their MAF or o2 sensors. Seems like that would be a good place to start, cleaning your MAF sensor is super easy to do yourself. Afterwards, disconnect your battery for a few minutes to reset the code and drive around for a few days (takes the ECU several driving hours before it can pick up the code again after battery disconnect), and see if that helps?
  4. May 16, 2016 at 3:43 PM
    cooperman1516
    Thanks eon. I found the same info, mostly relating to dodge deisels.
    For anyone interested I took out the upstream O2 sensor and it did not pass the torch test. Additionally, I found an exhaust leak at the flange directly upstream of the CC. I bought a new denso sensor ($90 at Napa) and a new exhaust gasket. I cleared the code and have run about 200 miles without the code returning. We'll see if it returns again, I'll update the post if it does.
    eon_blue likes this.
