P2000 Code
Discussion in 'Technical Chat' started by cooperman1516, May 2, 2016.
  1. May 2, 2016 at 4:38 PM
    cooperman1516
    cooperman1516 [OP] Member
    1997 Tacoma 2.7L, 4x4, 5 spd, xtra cab
    None....she's stock :)
    My check engine light is on and I am getting a P2000 code with my scanner. I cleared the code to see if it would come back, it did. Checked the service manual but no P2000 listed. I searched this forum and nothing relevant comes back. I googled the code and noticed some dodge cummins guys getting the code and changing their upstream O2 sensor bank 1. I pulled the upstream O2 sensor and tested it....it was bad, also discovered a small exhaust leak right behind the O2 I changed where the pipe meets the Cat. I fixed that too.
    My question is have any of you had this code? If so, what was the fix? Thanks!
