p2109 code after cleaning throttle body, rough idling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MarkNap128, Mar 10, 2023.
  1. Mar 16, 2023 at 3:54 PM
    MarkNap128
    MarkNap128 [OP] Well-Known Member
    Mark
    West Warwick RI
    2013 Black Tacoma TRD Sport 4x4 dbl cab
    None
    I had borrowed that scan tool and I ordered one it won’t be here until MON.
    I created a live test checking LT fuel trims while at idle and they’re way high - check it out.
    I wanted to run the test with the purge valve unhooked and plugged to see I the numbers would drop. I’m not sure why I had the commanded value there it kind of just stayed at that 35% range while at idle
  2. Mar 16, 2023 at 5:35 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    Haha, sorry. Benefit of being 6’5” :D Too bad it didn’t fix it for you, I like to try easy stuff I most likely broke, first.:fingerscrossed:
  3. Mar 17, 2023 at 2:04 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    5 foot 7 ‍♂️
  4. Mar 18, 2023 at 7:25 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    with the engine running:
  5. Mar 18, 2023 at 7:28 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    engine off and key on (you can see where the engine was shut off):
    TnShooter[QUOTED] likes this.
  6. Mar 18, 2023 at 7:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Looks about right @ 4 gm/s
    I’m with @Dm93 and the others, you may have a vacuum leak.
  7. Mar 18, 2023 at 7:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Hmm MAF looks about right but the fuel trims are high, do the fuel trims get better, worse, or stay the same while driving?
    TnShooter likes this.
  8. Mar 19, 2023 at 12:24 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    they don’t change so it’s looking like a fuel issue, right? that sucks
    btw this is done with a scanner you can get for 20$ with a coupon and it’s bluetooth so everything is viewed from my iphone. Sure, it can’t send commands but i’m going to spend some money when I go that route.
    It has a gauge to check for fuel pressure but it doesn’t seem to read. I am sure I am going to need a gauge to check mine.
  9. Mar 19, 2023 at 9:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I would expect them to get worse while driving if fuel pressure was low but it's definitely something to check.
    The 4.0L has no fuel rail pressure sensor so you will not see that reading on the scanner, it has to be checked with a gauge teed into the fuel line.
    You will need something like this to check fuel pressure.
  10. Mar 20, 2023 at 6:33 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    will this gauge work? looks similar - i’m reading the Haynes guide at this moment to determine the steps to reading the pressure. also, check
    out these readings - this was me pressing on the throttle every 3 seconds for about 2 seconds or so - i’m seeing spikes in the LT fuel trim which I guess is getting worse as I accelerate. Also, the fuel gauge
  11. Mar 20, 2023 at 6:42 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    more readings while pressing on the throttle
  12. Mar 20, 2023 at 7:12 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I don't think so, you need the quick connect adapters to tee into the line as there is no fuel pressure check port.
    Fuel trims will do that on a snap throttle, my test would be a WOT pull while watching O2 sensor readings. If they drop lean and stay lean through the pull then that typically suggests a fuel delivery or MAF issue.
    MAF accuracy can be checked by doing the same thing while graphing MAF, RPM, IAT, and Baro and entering the results in the calculator below.
    https://atgtraining.com/atg-volumetric-efficiency-calculator/
  13. Mar 22, 2023 at 9:31 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    I’ve got the kit you referred me to. Thanks a million! Once I figure out where to connect it I will do the tests (probably this weekend).
    when I try to view oxygen sensor fuel/air, it’s only allowing me to view oxygen sensor 1?
    maybe this scanner isn’t that great after all
    Dm93[QUOTED] likes this.
  14. Mar 22, 2023 at 10:18 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can tee it in at the quick connect in the pressure line going from the frame to the engine.
    Yea something is screwy with scan data, you should have 4 AFR/O2 sensors available in data. The upstreams may be labeled as AFR sensors but there are 4 sensors in total.
    AFR B1S1
    AFR B2S1
    O2 B1S2
    O2 B2S2
  15. Mar 22, 2023 at 10:25 AM
    #35
    MarkNap128
    Mark
    West Warwick RI
    None
    on here they’re labeled oxygen sensor 1 fuel/air
    but i’m not reading anything from o2 sensor 2, 3, or 4. I doubt I have 3 bad sensors im
    only still getting the 3 evap codes p0171 p0174 and p0441. I’ll try to test with a different scanner and will use the photo uou shared and report back. Your input is invaluable. thanks
  16. Mar 22, 2023 at 10:31 AM
    #36
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    If you clean the throttle body too aggressively you can cause a vacuum leak where the throttle blade shaft enters the bore. There’s some type of moly grease or similar there to seal from the factory I believe.
  17. Mar 22, 2023 at 10:42 AM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea it's like the scanner can't even read the sensor PIDs properly, they should show numbers even if the sensors was totally dead.
  18. Mar 22, 2023 at 10:46 AM
    #38
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Never seen this before, I know 1st gens had throttle bore wear issues but never seen that on a 2nd gen.
    You can wreck the mechanism inside if your too aggressive with moving the throttle plate while cleaning though.
  19. Mar 22, 2023 at 11:28 AM
    #39
    MarkNap128
    Mark
    West Warwick RI
    None
    should the fuel trim numbers be dropping when increasing rpms? I don’t experience a drop when hammering the throttle - I also noticed this passed week it took me two tries to start the engine a few times.
  20. Mar 22, 2023 at 1:50 PM
    #40
    MarkNap128
    Mark
    West Warwick RI
    None
    i’m pretty certain I didn’t. I may have put a few scratches on the shiny surface using a soft bristle toothbrush and crc throttle body cleaner but I read that it’s no big deal.
