P235/60R17 on a 2002 PreRunner? Help!
Discussion in 'Wheels & Tires' started by wyomarine, Aug 16, 2010.
  1. Aug 16, 2010 at 6:04 PM
    wyomarine
    wyomarine [OP] Member
    Raeford, NC
    PreRunner Rugged Trail
    Looking for some help, as I know absolutely nothing about tires and wheels. My daughter has a 2002 Tacoma PreRunner with P265/70R16 tires that need to be replaced. Someone where I work is selling P235/60R17 tires (Bridgestone Dueler H/T) and wheels (American Racing Assault) for $250 (see picture) for the set. The tires are nearly brand new with less than 2,000 miles on them. Sounds like a great deal, but I'm not sure if they'll fit on my daughters truck. I read the door panel info and it says the OEM tires are P225/75R15, though I do have P265/70R16's on there now. I've checked tire guides on the web and some indicate that I can use the P235/60R17 tire and wheel combination. Just wanted to check with the experts in this forum before I put these on my daughters vehicle. Thanks!
  2. Aug 17, 2010 at 1:08 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    They will work but your new tire is going to be considerably shorter than your current one. A 235/60 17 is 28.1 inches tall. A 265/70 16 is 30.6 inches tall. In my opinion, it will look funny. But if you don't care about looks go for it. Also, you need to consider that your speedometer will be off by 8.9%. When your speedo reads 60, you will actually be going 55.1 MPH.
  3. Aug 17, 2010 at 1:11 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    pretty sure the 225 75 15s are the stock size for a non prerunner.
  4. Aug 18, 2010 at 1:34 PM
    wyomarine
    Raeford, NC
    Bama Taco, thanks for the feedback. I appreciate the info. I purchased the wheels, but I'm going to swap out the tires now for 265/70R17's. The Bridgestone's that are on the wheels are nearly brand new so I should be able to recoup what I paid for the wheels and tires.
