P235/85R16 vs P285/75R16
Discussion in 'Wheels & Tires' started by T1no33, Sep 13, 2013.
  1. Sep 13, 2013 at 10:00 AM
    T1no33
    T1no33 [OP] Well-Known Member
    Spring Hill, Fl
    2012 PreRunner V6 SR5
    - Partial Badge Removal & Dipped - Removed Mud Flaps - Blacked out Emblem - Blacked out Chrome Surrounding Grill - Salex Center Console Organizer - AntennaX 13" - Tinted Front Windshield - Derped Tacoma Emblems - Bridgestone 265/70/16 tires - Tuff AT Wheels - 3 and 1 spacer block lift (mistake big time) - Black Rear Bumper - Aries Bull Bar w/light rig
    Does anyone have any experience/knowledge about this size tire? I'm finding that they are about .50" inch shorter than the P285/75R16 and they don't affect your speed, gas mileage and gears as much.
    Thoughts?
  2. Sep 13, 2013 at 10:24 AM
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Can't comment on the 285. But I run 235/85/16 during the winter. Mine are a Canadian tire specific goodyear tire that's similar to the duratrac.
    They fit on a stock truck an full the wheel wells nicely. My mpg went down from stock, but I'm assuming thy would still be better than the 285.
    I like the ride. More sidewall to soak up bumps. Don't track quiet as well as the 265/70/16 stock size.
    My offroad use for them is mostly limited to snow covered gravel and deactivated logging roads.
    I was definitely happy with how they performed. The extra ground clearance was appreciated. Even lifted I would still run this size. Definitely a tall skinny fan.
  3. Sep 13, 2013 at 10:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Were you actually able to find a 235/85R16 tire that's P-rated?? I've never seen a tire in that size carrying less than a E-load rating.
  4. Sep 13, 2013 at 10:32 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Mine are e rated. I should say my summer stock siZe are also e rated. So the ride comparison is a bit bias.
    They ride as nice as stock from what I remember. (The 235's I mean).
  5. Sep 13, 2013 at 10:33 AM
    Pugga
    Massachusetts
    That's because the snow fills in all the potholes in the winter :D
  6. Sep 13, 2013 at 1:47 PM
    T1no33
    Spring Hill, Fl
    Thanks for the input on these. I'm asking as I put a 3" front 1"back spacer/block lift on the truck and wanted a bigger tire. Only do very light off road stuff for the most part. I have read that going to 285s really hurts gas milage, speedometer reads and gears. I found the 235s by accident and found they affect everything way less. Considering changing to those. Thanks again as your information was helpful.
  7. Sep 13, 2013 at 1:55 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    255/85/16 or 255/80/17 are also options if you wanted something as tall as a 285 but wider than a 235.
  8. Sep 13, 2013 at 2:07 PM
    T1no33
    Spring Hill, Fl
    THANK YOU
  9. Sep 14, 2013 at 2:40 AM
    CanisLupus
    Stokesdale | NC
    NO PROBLEM
    :rolleyes:
    It's becoming a popular size recently. Many say that it is the ideal size for wheeling. (not as great in mud, but who likes mud...) It will change some speedometer readings, etc if you wanted full disclosure. I plan on just getting a Ultraguage or Scangauge when I get my 255's and calibrate it to read my MPH.
  10. Sep 15, 2013 at 7:34 PM
    T1no33
    Spring Hill, Fl
    Anyone have pics of these on their truck?
  11. Sep 15, 2013 at 7:37 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    No pics but I have 235/85/16 for winter tires for better traction and I've been very happy with them. They get better mileage than my 265/75/16 summer BFG's. (both are 10 ply)
  12. Sep 15, 2013 at 7:43 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
  13. Sep 16, 2013 at 5:32 AM
    T1no33
    Spring Hill, Fl
  14. Sep 18, 2013 at 9:12 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    the 285/75R16 is quite popular here in the desert on the Gen 2 tacomas, but even with a 2" lift you have rubbing when the tire is stuffed up into the wheel well and turning. With the perfect wheel offset this is not too bad but only a cab mount chop will eliminate the problem for good. I did not want this much drama with my '12 Tacoma and settled for 265/75R16 Dura-Tracs. I am happy with them in rocks and loose stuff and they climb really well. The bigger 285's are also heavier which hurts acceleration and braking nearly as much as the diameter increase.
    A good compromise is the 'tall and skinny' route and I am saving for some 255/85R16's. Not many tires in this size, but the Cooper ST and BFG KM2 are available. I may investigeate the 235/85R16 but my whaeels are 8" wide and this is max for the 255/85 so a no-go fror the 235/85.
    I am glad to see people at least checking out somehing besides the "fatty" 285's. They all have their place, but the skinnies definitely shine in a lot of applications.
  15. Oct 9, 2013 at 8:48 AM
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    So what would be the best option for mostly pavement driving as far as comfort/gas mileage?
  16. Oct 9, 2013 at 9:34 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    on road best mileage.. probably a P245/75/16 or P245/70/17 tire will get the best mileage. A p rate 265/70/16 or 265/65/17 won't be far behind mileage wise...
    Unfortunately looks and offroad ability dont really go hand in hand with mileage and ride... defeinitely some good compromises in the 265 series though...
  17. Oct 9, 2013 at 11:30 AM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    What about from a comfort stand point?
  18. Oct 9, 2013 at 11:33 AM
    Pugga
    Massachusetts
    P-rated and H/T tread pattern. Michelin would be a great place to start.
  19. Oct 9, 2013 at 12:17 PM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    The
    Please educate me... What is H/T? I am looking into going from a mud terrain to an all terrain but would like the most comfortable/quietest ride...I never go off road but like the look of an aggressive tire with a 5.5" lift.
