P2440 on 2008 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JohnAllen67, Sep 14, 2024.
  1. Sep 14, 2024 at 10:22 AM
    JohnAllen67
    JohnAllen67 [OP] Member
    My 18 year old is staying at college 70 miles away with our 2008 Tacoma. He called with a check engine light on. I drove down last night and he had a P2440 – Switching Valve Stuck Open Bank 1. I erased it and he followed me home.
    This morning I removed the hose at the bottom close to the fan and blew in. It allowed no air and what I saw is that might mean the fan is the problem.
    Asking if that sounds right?
    Would it help to spray it all down if carb cleaner?
    Is it right to go with a fan replacement or go on to the Hewitt mod, and if so does that sometimes cause a loss of power?
    Does the 2008 go into limp mode if a code comes up?
  2. Sep 14, 2024 at 12:21 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Stuck open is almost always the valve, easiest way to check it is pull the main hose off between the valve and the pump with the engine running. If you feel exhaust coming out of the hose the valve is bad.
  3. Sep 14, 2024 at 12:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I forgot to reconnect the vacuum hose to it one time and got that code
