P3 Brake Controller Issue/Question 19
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Price168, Feb 26, 2020.
  1. Feb 26, 2020 at 1:47 PM
    Price168
    Price168 [OP] Well-Known Member
    WV/TN/Tampa FL
    04 PreRunner Reg Cab
    3-Body 2-Suspension 305/70/16 ( Fierce) Hella 500's 5100's Rear Grill Craft Powder Coated Bumpers Line-X Rockers/ Bed CBI Ditch Lights/ Rigid Industries
    2019 OR 6SPD
    Seems like issues only come up when you least expect them. I did some searching and didn’t find a similar issue.
    Problem, Purchased an 18ft car hauler new last summer and initially towed it without a controller. I bought the P3 Controller and the plug and play harness. Install was very simple and the initial function check without the trailer worked fine. Fast forward 8 months after the trailer has been parked I finally get to test everything as a whole right before a 400 mile road trip. As soon as I plugged everything up the controller threw a “ no brake “ fault. I unplugged it and then it went away. 10 miles down he road I feel the brakes dragging and I stop. After thinking they were froze I finally figured out that when my turn signals are on the brakes kick on and off. I also figured out they grab when the headlights/ taillights are on too.
    It’s currently raining outside, so I’m trying to do as much due diligence online before I jack the trailer up and go to work. I would6O assume the truck is wired right because it’s plug and play..so I would place my time to a wiring issue in the trailer probably.
    Anyone have a similar issue? I’m thinking they may have tap the brakes to the wrong pin on the trailer plug? I’ve cleaned both ends and I see no visible issue at the plugs.
    I figure I will check grounds first and then go from there.
