P3 Brake controller stays on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BMET, Jul 28, 2014.
  1. Jul 28, 2014 at 7:55 PM
    BMET
    BMET [OP] Member
    Cape Girardeau, MO
    09' TRD Sport DC 6MT
    I have used this same brake controller in previous trucks with no problems. I got it wired but the 2 dots stay illuminated with the key off? I am not sure why it still has power going to it. My truck has the factory tow package and I know it is properly wired. Any suggestions? I haven't come across this issue in other posts.
  2. Jul 28, 2014 at 8:09 PM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    Double check that it doesn't go off after a few minutes. Mine did the same thing...went inside, posted a thread, went back out and it had turned off.
  3. Jul 28, 2014 at 8:12 PM
    BMET
    BMET [OP] Member
    Cape Girardeau, MO
    Thanks buddy, will check that.
  4. Jul 29, 2014 at 2:38 AM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    I have the P3 as well and questioned it after it was installed. Read the manual and it notes that it remains lit I believe for about 15 minutes after engine is shut off.
  5. Jul 29, 2014 at 4:29 AM
    cquester5
    cquester5 Well-Known Member
    2014 Tacoma TRD Sport
    Mine did the same thing so I called tech at customer service. He said it will remain lit for up to 30 minutes after switching off the ignition, and it is for safety. He also said it will provide signal to the electric brakes in the event there is a momentary loss in power at the switch. Also, just stepping on the brake pedal even with ignition off will reactivate the controller.
  6. Jul 29, 2014 at 6:31 AM
    BMET
    BMET [OP] Member
    Cape Girardeau, MO
    You guys are right, not that I doubted you! I don't have my manual anymore, this controller is a few years old. I guess I just never noticed it before.
