P301
Discussion in 'New Members' started by Sheriff1417, Dec 4, 2015.
  1. Dec 4, 2015 at 5:47 AM
    Sheriff1417
    Sheriff1417 [OP] New Member
    2001 tacoma
    None
    I have a 2001 tacoma ,code 301 on ,engine runs rough but clears after 20 min ,all mechanics are stunned ,I replaced plugs and coil pack in cylinder 1 ,only to have it run worse with the new pack so the older one was put back in ,all mechanics are grasping ,need a hand
  2. Dec 4, 2015 at 7:46 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome and good luck with getting everything taken care of!
  3. Oct 19, 2021 at 2:36 PM
    ryanlewis1985
    ryanlewis1985 Member
    2003 Tacoma 2.7l manual 4x4
    I've similar problems - thinking of replacing the fuel injector at this point. Any tutorials or videos you guys know of? TIA - Ryan
  4. Oct 19, 2021 at 2:37 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Instead of replacing fuel injectors, try swapping the injector from cyl 1 to cyl 4 and see if the misfire follows. That would then indicate that the injector is indeed the problem.
    ryanlewis1985[QUOTED] likes this.
  5. Oct 19, 2021 at 3:11 PM
    ryanlewis1985
    That makes sense thank you!
  6. Oct 19, 2021 at 3:33 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    ryanlewis1985 likes this.
