P430 light won’t go away.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Mar 25, 2025.
  1. Mar 25, 2025 at 5:54 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
  2. Mar 25, 2025 at 6:37 AM
    black3rdgen
    black3rdgen Well-Known Member
    STL
    3G on 35s, 5.29s
    YW tune, 5.29s, equal length dual exhaust, 2000w audio system
  3. Mar 25, 2025 at 6:51 AM
    jardoo
    Beirut, Lebanon
    A tune will remove the po430 code ?
    What kind of tune ?
  4. Mar 25, 2025 at 7:02 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    You need cats....
    "your cats were bad so your mechanic removed them"
    You also need a new mechanic....
    if youre in the Middle East & you dont need cats, why do you care if your CEL is on?
    Jakerou and Chew like this.
  5. Mar 25, 2025 at 7:08 AM
    jardoo
    Beirut, Lebanon
    because it says “trac off” so I don’t have traction control.
    not all the cats were removed. The two at the bottom were. I still have the ones by the engine.
  6. Mar 25, 2025 at 7:21 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Since this is your second thread about the same issue with no resolution my thought is new catalytic converters.
    jardoo[OP] likes this.
  7. Mar 25, 2025 at 7:22 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Basically you have two options.
    One is to replace the lower cats with new OEM...typically aftermarket cats will still throw the same code. This is the best answer for both the smell of the exhaust and the efficiency of the motor.
    The other is to simulate the O2 signal to fool the ECM to believe the exhaust is catalyzing. I have done this on older wideband systems but haven't on the Tacoma. You will usually get the CEL to turn off but will most likely still run rich...this will likely be the same result with a tune as well.
    jmneill likes this.
  8. Mar 25, 2025 at 7:31 AM
    slater
    San Diego
    Its usually the front cats that fail, so I still say new mechanic...
    Figure out why they failed, last thing you want to do is throw thousands of dollars in cat converters in a truck that has issues causing the cats to fail...
    Then throw new cats at it, I also dont recommend aftermarket cats, ever, theyre garbage & wont last....
    Your mechanic complicated things by not having a clue....
    respectfully....
  9. Mar 25, 2025 at 7:31 AM
    jardoo
    Beirut, Lebanon
    sorry my bad. It was the primary upper cats that were removed.
    ok thanks for the info. Is it bad for my truck to run it without those primary cats ?
  10. Mar 25, 2025 at 7:35 AM
    slater
    San Diego
    Get your story straight....
    Doesnt change anything...
    Sounds like nothing was properly diagnosed & your mechanic removed cats that may have been good, or not, who knows...
    Cats are expensive & gambling / rolling the dice isnt a good idea....
  11. Mar 25, 2025 at 7:47 AM
    jardoo
    Beirut, Lebanon
    it was actually the front cats that failed, my bad. They were removed.
    is it bad for my truck to drive without them?
  12. Mar 25, 2025 at 7:48 AM
    jardoo
    Beirut, Lebanon
    well yeah they are removed so I need new ones either way. They are hard to ship here all the way from the U.S. and very expensive.
    I can get used ones off of old Tacomas. That’s always a possibility.
  13. Mar 25, 2025 at 8:48 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Not sure who tunes 3Gs in the Middle East haha.. maybe contact KanooPerformance? I know they work with Toyotas and they’re located in Bahrain.
    There are small gains to be made with a cat delete and a proper tune. It will hurt more than it helps on the stock tune though.
  14. Mar 25, 2025 at 9:30 AM
    jardoo
    Beirut, Lebanon
    thanks !
    haha there’s a guy here but he charges 550 for a cat delete tune.
  15. Mar 25, 2025 at 9:37 AM
    airforceb2cc
    Don
    KCMO
    Still cheaper than cats...
    Another option is to hop on car-part.com and search for an exhaust manifold. Call the yards that show it and see if they will ship overseas.
  16. Mar 25, 2025 at 9:43 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    If you ever intend to ship the truck to the U.S. it will have to have the cats so I would recommend replacing. If not try the work around method which ever is cheaper.
    Chew and jardoo[OP] like this.
  17. Mar 25, 2025 at 9:47 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Your mechanic was a genius he said u have bad cats … took them off took your money and sold the good cats lol
    Chew likes this.
  18. Mar 25, 2025 at 9:51 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    OP, might call his mechanic and ask him if he has a good used set of cats. lol :D
  19. Mar 25, 2025 at 10:23 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Sounds about right. I’m in $650 for my Yotawerx tune+custom files.
  20. Mar 25, 2025 at 12:39 PM
    jardoo
    Beirut, Lebanon
    Interesting. What’s that mean? Sorry I don’t know too much about exhaust systems.
