PA in your truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Sep 15, 2010.
  1. Sep 15, 2010 at 9:55 AM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I wanna get one cus i think it would be fun as hell to mess around with. I have a cobra CB that can toggle between cb and pa...so i just need a pa speaker right? And that would just connect to the back of the cb right?
    any brand recommendations or speaker recommendations?
  2. Sep 15, 2010 at 10:00 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    lol I knew you would be = to or < than 18yr old...
    Radioshack should have the parts you looking for.
  3. Sep 15, 2010 at 10:05 AM
    DaytonLax14
    Corey
    Ohio
    i don't think radioshack has pa speakers
  4. Sep 15, 2010 at 10:13 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    sometimes i wish i had one when driving home...4 lane rd and people roll side by side at 50mph in a friggin 70 zone...lol
  5. Sep 15, 2010 at 10:15 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    they sure do....that's where i got mine. you need the speaker, a standard headphone jack and however many feet of wire.
    and i'd recomend not using it for the purpose of "messing around", not even friends. i use mine on trails when it's hot as balls, that way i can ask my spotter questions and keep the cool air in the cab :D (i know, dick move, but he gets beer later, so it'd good). also used it when i volenteered to use my truck in a parade, and they needed a way for the float to play audible music for the people watching. worked surprisingly well jsut holding the mic. to the stereo speaker. but i'm getting off topic......things to know, 1) radio shack 2) don't be dumb once you have it.
    otherwise, it's a very easy install, the hardest part you'll have is deciding on where to put it.
  6. Sep 15, 2010 at 10:16 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
  7. Sep 15, 2010 at 10:18 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ^^^that's the one i have, works great. very waterproof too. i've dunked mine a few times and it still works
  8. Sep 15, 2010 at 10:18 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    http://www.radioshack.com/product/index.jsp?productId=4371942
    This is a simple PA Speaker. it is amplified and has a standard input jack.
    The install is fairly simple as this model does not need an on/off switch.
    I also have an aux option on my CB. If i conect the speaker to that jack, it will play what the CB recives. it comes in handy so you could here the comunications while your out of your truck.
  9. Sep 15, 2010 at 10:30 AM
    DaytonLax14
    Corey
    Ohio
    okay so i just need to get the speaker and a 3.5mm audio cable, which will just plug into my cb and it's good to go right?
  10. Sep 15, 2010 at 10:34 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    correct, speaker, wire, headphone jack. you'll need access to a soldering iron too.
    you'll also need some hardware to secure it.
  11. Sep 15, 2010 at 10:34 AM
    DaytonLax14
    Corey
    Ohio
    i got a soldering iron and a ton of hardware at the shop. thanks fellas
  12. Sep 15, 2010 at 10:40 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    oh, one little tip, make sure you identify the positive and negative terminals on the headphone jack correctly (this is from personal experience). if you get them backwards, the speaker will still work, but you won't get the volume and clarity as you would if hooked up correctly....took me a couple months to figure that one out:rolleyes:
  13. Sep 15, 2010 at 10:42 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    I heard they are illegal to use when you are in your truck. That's the law here.
  14. Sep 15, 2010 at 11:57 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    pretty sure that's true in all 50 states while on public roads
  15. Sep 15, 2010 at 12:25 PM
    pittim
    pittim mittip backwards
    Mk7 TDI
    Permanent CEL
    if you're going at 50mph you're not going to be able to hear a little PA speaker that just simply plugs into your CB.
    People can pretty much only hear mine whenever I'm completely stopped.
  16. Sep 15, 2010 at 1:45 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ^^^ depends greatly on location... i had mine under my hood for a while, behind the fuse box, and you could only hear it when i was stopped. i now temporarily have it mounted with the open end of the speaker going directly out the hole for the winch in my all pro bumper, and now it's audible when driving. (temporary, because a winch is in the works, then i have to relocate it again)
  17. Sep 15, 2010 at 1:48 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    a pa would be awesome...to bad im electrically challenged :(
  18. Sep 15, 2010 at 2:58 PM
    DaytonLax14
    Corey
    Ohio
    this thing is pretty darn loud lol
  19. Sep 15, 2010 at 3:01 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hah, that was quick.
    radioshack have what you needed?
  20. Sep 15, 2010 at 4:16 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    i had a BIG PA speaker under my truck at one point...... dont know where it went lol the part that mounted to the truck was still their but the speaker was missing lol guess a mud pit or rock took it off lol
