PA to WA long haul moving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Jun 17, 2015.
  1. Jun 17, 2015 at 5:34 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What would be your concerns pulling a u-haul trailer and a motorcycle across the country, through the mountains. Current truck is a stock v6 TRD 2wd.
  2. Jun 17, 2015 at 5:41 AM
    Pigpen
    Dan
    Northwest Montana
    As long as you're doing it in the warmer months, there's nothing to be concerned about. Get off the highway and see some sights on your trip - plan extra days for this - you never know if or when you'll be by some of those areas again.
    Sugar Silva likes this.
  3. Jun 17, 2015 at 5:48 AM
    Pigpen
    Dan
    Northwest Montana
    Also, come up this way and ride the bike through Glacier National Park
  4. Jun 17, 2015 at 5:48 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Theft has always bin my concern when doing cross country moves by myself, park in well light areas. Plan on not sleeping in Nevada, every town seemed like a David Lynch movie.
  5. Jun 17, 2015 at 5:50 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Heat is actually a main concern, trains temps specifically in the mountains. As well as ride with the weak Toyo springs.
  6. Jun 17, 2015 at 6:04 AM
    Pigpen
    Dan
    Northwest Montana
    Get early starts. It starts getting light here around 5:30 this time of year and the temps get down into the 50's. Just speaking for my locale, obviously.
  7. Jun 17, 2015 at 8:52 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    Take Interstate 80 west instead of 70, It's flatter and since more northern, cooler.
  8. Jun 17, 2015 at 11:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    get in truck, turn key, drive.
    i wouldnt worry to much at all, if you find that the trans is hunting between 5th lock, 5th unlocked and 4th... put her in 4th.... other than that drive!
  9. Jun 17, 2015 at 11:47 AM
    AWalker
    AWalker Well-Known Member
    Adam
    Tacoma Washington
    08 DC LB SR5
    O.M.E 885 Dakars nitros Snugtop allpro skids allpro bumper 4X inovations sliders Jayco pop up camper Torklift tiedowns
    Leave room for a fishing pole! Pinks "salmon" will be running late summer if your heading towards Puget Sound. Not the best eating unless smoked or cooked right away but fun to catch....has nothing to do with what you asked I know. I wouldn't bat an eye at pulling a trailer under 4k cross country, besides planning out gas stops. Got 10mpg when pulling my 4500k travel trailer.
  10. Jun 17, 2015 at 12:18 PM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    I pulled a 12' uhaul, bed & cab fully loaded. Only room in truck was for me. I pulled it from Florida to Utah in August. Get a trailer with brakes & no problemo. i wasn't fast going up through the mountains though. was in 4th up hill and sometimes 3rd. Temps got high with AC on a couple of times.
