Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Feb 3, 2018 at 10:30 AM
    #2881
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Those look good man. How have they been on road in the packed snow? I might Go Alaska next, heard it is great up there? What size are those?
  2. Feb 3, 2018 at 8:48 PM
    #2882
    FarNorthTaco14
    FarNorthTaco14 James 2:18
    Jeremiah
    Anchorage, AK
    2012 SR5 6-Speed Manual
    Soft topper, Kings, Total Chaos and stuff!
    Thanks man, they do good on the snow, but of course they aren’t the best on the ice in 2wd without a decent amount of weight in the back. Alaska is amazing man, I recommend it. It’s beautiful up here. It’s got a lot of intense wheeling and easy stuff as well. Summer is amazing if you overland.
    ready6delta[QUOTED] likes this.
  3. Feb 4, 2018 at 12:19 AM
    #2883
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    265/70/17 here! Enjoying the tires for the most part. They definitely are louder than stock, which is expected. I've been getting vibes lately on the freeway...thought it was the tires, got them re balanced and they were 'good' so I just got my alignment rechecked as well because along with the vibes, it was pulling hard to the right on the freeway. Turns out one of my tires has a pull to it..shop switched the tires around and then it pulled to that side. Is that something that is warranty-able? My alignment has to be offset a bunch to compensate for the pull now.
    Other than that, tires have done great offroad and in the snow I've tried them in.
  4. Feb 4, 2018 at 2:30 AM
    #2884
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Got a set put on a couple hundred miles ago. For winter conditions (snow and packed snow on road)
    They are at least as good as the ko2's as far as stopping and grip. They are not as good as the toyo at2's gripping. The Toyo's are the best AT tire I've used of the three in the winter, they just sling stuff out of their tread very well. They are $50 more a tire on a 16 inch wheel, probably worse as you go larger, so you are getting some benifit for the price increase.
    IMO, if you are thinking of these or k02, get these. If you are thinking about this or Toyo and don't mind spending a couple hundred extra, get the ToyoAT2's.
    ready6delta, readyme and DrFunker like this.
  5. Feb 4, 2018 at 7:09 AM
    #2885
    MarvinL
    MarvinL Well-Known Member
    2018 Tacoma TRD OR 4X4 DCSB
    I think I am sold on these... I bought some ray10s in 17s and was going to wait for a lift to install them.. seeing the price on these I think I might have to try mounting with 265/70r17 first.
    Anyone running the tires on stock suspension without major rubbing issues?
  6. Feb 4, 2018 at 8:24 AM
    #2886
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Lots of folks are running that size tire on stock suspension. The rubbing will vary depending on the wheels/offset. Stock wheels (+25mm for your stock OR wheels) will present little to no rubbing. Wheels with less offset (negative number) than stock will begin to have increased tire to plastic/frame contact.
    With your wheels at 8.5” wide and -10 offset, expect some rubbing on the mud flaps and probably some on the plastic of the front wheel well. A heat gun, dremel, or razor knife will fix the issue.
    ready6delta likes this.
  7. Feb 4, 2018 at 8:31 AM
    #2887
    MarvinL
    Thanks, I will see where it goes. I might just have to do the CMC necessary before the lift.
  8. Feb 4, 2018 at 8:33 AM
    #2888
    backcountryj
    Jonathan
    GA
    I’d be shock if you need to go fill on CMC to get clearance for 265s.
  9. Feb 4, 2018 at 8:45 AM
    #2889
    MarvinL
    not so much to just clear the 265s, I am getting a lift next year and go with 285s which would need a CMC, might as well do it now.
    A friend of mine will buy my stock wheels and tires for the price of a new set of falkens, was originally going for KO2s, just saw these and they are looking good.
  10. Feb 4, 2018 at 8:47 AM
    #2890
    backcountryj
    Jonathan
    GA
    Gotcha. Yea for 285s you’ll need to cut it up.
    MarvinL[QUOTED] likes this.
  11. Feb 4, 2018 at 8:50 AM
    #2891
    trevordavis14
    trevordavis14 Well-Known Member
    Trevor
    2017 DCSB OR 4x4
    Running them on our 4runner, great tire so far, except for the sand....Was expecting a bit more out of them there!
  12. Feb 4, 2018 at 11:11 AM
    #2892
    readyme
    readyme Well-Known Member
    Western WA
    2017 TRD OR DCLB
    Thanks for providing first hand info.
    For the price I am going to go with Falken.
  13. Feb 4, 2018 at 11:48 AM
    #2893
    Bridge4
    MA
    No problem, I think you will be happy with them, they are a good tire and I don't regret getting them at all.
    readyme[QUOTED] likes this.
  14. Feb 5, 2018 at 9:13 AM
    #2894
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    Great looking truck; the Holeshot looks awesome!
    As for the pull, yes, this should be covered under the manufacturer warranty.
  15. Feb 5, 2018 at 9:22 AM
    #2895
    Technique
    Alex
    Utah
    Thanks!
    Gonna head down to Discount today and see if I can get a replacement tire ordered.
  16. Feb 5, 2018 at 9:42 AM
    #2896
    ready6delta
    JACOB
    Good to hear man thanks.
  17. Feb 5, 2018 at 1:01 PM
    #2897
    Discount Tire
    Arizona, USA
    Sounds good and I'm confident your local DT will take care of you :thumbsup:
    If we can be of any assistance from our end, feel free to shoot us a PM.
    readyme likes this.
  18. Feb 5, 2018 at 10:19 PM
    #2898
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    whats the MPG with P285 Vs LT285 or P265 Vs LT265 Report!
    I have P26570r17 18 highway/15 City
    3 in lift Fox.
  19. Feb 5, 2018 at 11:19 PM
    #2899
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    So put about 200 miles on these tires since I got them. p285/70/17.
    Thought I'd write something real quick since we got about 5 inches of snow here in Chicago the past 24 hours.
    Drove through unplowed streets and freeway today where every car seemed to be sliding all over the place. Even without the 4x4 I was cruising along solid as a rock. Turned on the 4x4 and just passed everyone up no problem. Not even a slip. Super happy with these tires. For 33's shipped to my door for $600 bucks I couldn't be happier. Half the price of the ST Maxx's or Duratracs I was considering.
    mightym likes this.
  20. Feb 6, 2018 at 1:24 AM
    #2900
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Yes these are very good in the snow. Just wish they came in load range C.
    abqnurse80 likes this.
