Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Mar 21, 2018 at 10:01 PM
    #3201
    Pirahna
    Pirahna Well-Known Member
    Prunedale, Ca
    2012 Black T/X Baja DC
    Found here
  2. Mar 21, 2018 at 10:31 PM
    #3202
    Taco'09
    Taco'09 Well-Known Member
    Thanks! I must be delusional. So they are heavier than advertised? Not exactly what I wanted to hear, oh well....
  3. Mar 22, 2018 at 6:30 AM
    #3203
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    One more pic. Took this one with my real camera. Lowered pressure to 28lbs cold and it rides a little better.
    th3118, Maticuno, CABlue and 3 others like this.
  4. Mar 22, 2018 at 4:11 PM
    #3204
    Jfab
    Jfab Active Member
    2017 Inferno Tacoma Sport
    Told me the same PSI.
  5. Mar 28, 2018 at 1:03 PM
    #3205
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
  6. Mar 28, 2018 at 3:22 PM
    #3206
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    Looking good bowhunter. :cool:
    Bowhuntercoop likes this.
  7. Mar 28, 2018 at 6:17 PM
    #3207
    Bowhuntercoop
    Thanks for the sale, you guys run a great business.
  8. Mar 28, 2018 at 6:25 PM
    #3208
    djmr1972
    djmr1972 Well-Known Member
    N. Central Mass.
    18 Cement TRD Off Road Long Bed
    Visors, Roof rack, decals in and out, bug deflector, tonneau cover, bed extender
    Im thinking of going from 265/70/16 to 265/75/16 from stock wranglers. Is it worth it for a better ride and looks? which one is best to go with?
    Edit: sorry for a repeat question... too many pages to read
    Also, I dont go wheeling. just new england snow
  9. Mar 29, 2018 at 2:38 AM
    #3209
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Just did the same switch. Yes it's worth it. Ride is similar...do it mostly for looks
  10. Mar 29, 2018 at 7:52 AM
    #3210
    djmr1972
    N. Central Mass.
    I just see so many comments about using E, LT etc tires and cant figure which will be the better ride without sacrificing mpg.
    Def plan to go with the size just dont get the so many differing opinions on load I guess
  11. Mar 29, 2018 at 9:05 AM
    #3211
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Based on your concerns you should stick with a standard load tire. Weight and stiffness are the qualities of an e load range tire. Weight and stiffness=poor ride quality and lower mpg’s
  12. Mar 29, 2018 at 10:08 AM
    #3212
    Discount Tire
    Arizona, USA
    Our pleasure, thank you for your support.
    djmr1972, as mentioned if you are concerned with mileage and ride quality you may want to go with the SL version.
    djmr1972 likes this.
  13. Mar 29, 2018 at 6:14 PM
    #3213
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    265/75/16
  14. Mar 29, 2018 at 7:30 PM
    #3214
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Definitely go SL. Still very rugged tires...You'll be pleased.
  15. Mar 30, 2018 at 6:25 AM
    #3215
    tacoma dude
    tacoma dude Member
    David
    2017 inferno orange tacoma
    trd pro grill so far
    I bought a set of the 265=70-17 wildpeaks had one mounted on my 2017 sport double cab stock wheel and was told they were too wide and would probably rub the uca any one else run into this .
  16. Mar 30, 2018 at 6:36 AM
    #3216
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I have 265/75/16’s with zero rubbing. You will be fine.
  17. Mar 30, 2018 at 6:39 AM
    #3217
    badger
    badger Well-Known Member
    07 SR5
    There are two areas where E rated tires shine. They are tougher and resist cuts and flats better for people who use their trucks hard, especially offroad. E rated tires have stiffer sidewalls that improve the steering response of tires with high profiles like the 255/85-16. Lower rated tires give a softer ride, partly because they weigh less. In low to mid profiles they handle fine. Lighter weight tires accelerate faster, stop faster, and transmit less shock to the chassis over bumps. If my truck were just street driven with an occasional forest road thrown in, I would run a C rated tire. If I were 100% street, I might even run a P. I run Es because of the roads I drive, and I never have to worry about them.
  18. Mar 30, 2018 at 9:15 AM
    #3218
    jptheriot
    jptheriot Meso Investor #5
    Jp
    St. Louis
    3rd Gen TRD Sport DCSB 4x4 / previously owned 1st and 2nd Gen
    Step Bars / BakFlip FiberMax Tonneau Cover /5% Tint Rear 20% Front / Reverse Cam Anytime / Coin Holder / LED Interior and reverse lights / Katzkin Leather Interior / Hondo knobs / TRD Pro Wheels / Black badges / Pro grille / @mesojdm designed Ultimate LED side mirror turn signals, BTLM, BD 3rd Brake Light, GASSHOLE, Ultimate Dome Light, Ultimate Map Lights, Custom Fuse Cover, Custom OEMeso Headlights / In-dash Universal Mount with iOmount
    No issues on mine. Thanks @Discount Tire Direct for the great deal!
    krampaht and ToyoDrew like this.
  19. Mar 30, 2018 at 11:56 AM
    #3219
    Discount Tire
    Arizona, USA
    Good looking truck jptheriot. :cool:
    Thank you for your business.
    jptheriot likes this.
  20. Mar 30, 2018 at 11:59 AM
    #3220
    djmr1972
    N. Central Mass.
    wonder if the diff is 17 vs 16
