Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Apr 2, 2018 at 11:03 AM
    #3221
    Lthompson
    Lthompson Well-Known Member
    Mine still wont balance. and the wa wa wa wa wa wa wa sound down the highway has been present since new. I'm around 10k now. Still have tire shake, been to 3 different places and balanced like 5 times. But they look good
  2. Apr 2, 2018 at 8:39 PM
    #3222
    JasonSix
    JasonSix Well-Known Member
    Got these tires 3k miles ago, so far so good!
  3. Apr 3, 2018 at 7:28 AM
    #3223
    adt7108
    adt7108 Well-Known Member
    Cookeville, TN
    Thats good to know, I have been eye balling these tires for my next set.
  4. Apr 3, 2018 at 8:24 PM
    #3224
    JasonSix
    Very smooth no road noise
    adt7108[QUOTED] likes this.
  5. Apr 3, 2018 at 8:28 PM
    #3225
    SpriggitySprat
    SpriggitySprat Well-Known Member
    Ohio
    2017 SR 2.7 4x4 AC Bearded Package
    Window tint (15% sides, 5% rear) Bull bar Bed mat (modified horse stall mat) 265/75 Falken Wildpeaks Hondo Garage radio knobs Better Built slimline toolbox LED replacements for interiors, reverse, and license plate Derped the stock steelies Tinted tail lights and third brake light Faux Pro Grille "Raptor Style" Lights 20" behind grill light bar 2" wheel spacers Cup holders and bottle opener in bed rail Custom bedside stickers and tailgate letters (CBoy808)
    These tires have been great, I have about 15k on them and they have been outstanding. Initially, it took a couple tries to get them balanced. I had some slight vibration at around 60 mph. After going back in to have them re-balanced twice, they finally got it right. Maybe these tires are hard to balance, maybe the tech who did it wasn't all there, who knows. Either way, once they got balanced correctly they have been great. For the tread they offer in adverse conditions they are pretty quiet on the highway and ride smooth. I would definitely buy these tires again.
  6. Apr 4, 2018 at 10:39 AM
    #3226
    Genghis_Khan60
    Genghis_Khan60 Active Member
    Hamza
    Booneville, MS
    2015 Blue Ribbon Tacoma TRD OffRoad
    For those of you running the 10ply, what psi are y’all running? My shop has them aired up to 50psi and I haven’t had time to chalk them just yet.
  7. Apr 4, 2018 at 12:07 PM
    #3227
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    50 psi is way too high. I run mine around 35.
  8. Apr 4, 2018 at 1:26 PM
    #3228
    Genghis_Khan60
    Hamza
    Booneville, MS
    That’s what I was thinking when my gauge shot out this morning! I knew I wasn’t crazy!!!
  9. Apr 4, 2018 at 5:23 PM
    #3229
    Genghis_Khan60
    Hamza
    Booneville, MS
    Update: after an hour of chalking my tires I’m still confused. 35psi on the front and the chalk is wore clear across. I’m at 30psi on the rear and the outside lugs on both tires still aren’t making contact? I’m going to buy a new pressure gauge tomorrow and start back over at 40psi all the way around. :bananadead:
  10. Apr 5, 2018 at 5:00 AM
    #3230
    04dgmsilv
    04dgmsilv Member
    DE
    2010 DC LB Sport
    Icon CO Front, Bilstien Rear, Wheelers 3-Pack
    Picked up a set of P285/70-17s from DTD online in Feb, got my SCS Ray10s a month ago and finally got everything mounted, balanced and installed in the last week or so.
    The Good - These replaced a set of Toyo RTs in the same size that I liked, but the wet/snow traction was poor. These are truly night and day different, I can actually accelerate w/o spinning in the rain again! I think the compound used on the P rated tire is excellent. They also look good, plenty aggressive for me.
    The Bad - 50-60 mph shake, steering wheel shakes back and forth ~1/2". When I picked up the tires after they had been mounted I was a bit shocked how much weight it took to balance. One wheel might have 30 1/4 oz weights. The shop is very reputable and has done most of my family's tire work over the years w/o issue.
    Not sure what my next option is, will play with air pressures a bit (running 33 F/28 R - empty bed), but based on looking at some of the issues here, I may just have a bad tire/set?
  11. Apr 5, 2018 at 6:41 AM
    #3231
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Bed of the truck is lighter than the front and will require less PSI
  12. Apr 5, 2018 at 8:04 AM
    #3232
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    04dmsilv, thank you for your business. I apologize you are having a balance issue. Pm coming your way.
  13. Apr 5, 2018 at 9:24 AM
    #3233
    Genghis_Khan60
    Hamza
    Booneville, MS
    I wouldn’t think the difference between pressures would be that drastic?
  14. Apr 5, 2018 at 9:25 AM
    #3234
    SpriggitySprat
    Ohio
    I also had a couple issues with balancing. It took the shop a couple tries to get it right. I had a similar shake at around the same speeds. It did take quite a bit of weight but they finally got it right and the tires have been outstanding since then. Try having the shop re-balance them and see if that helps.
  15. Apr 5, 2018 at 9:26 AM
    #3235
    BajaTom
    BajaTom Well-Known Member
    Tom
    Utahhhh
    2015 Tacoma TRD OR DCSB 4 door
    OME 2.5 886 Dakkar suspension, ARE shell, with Thule bars and cargo rack,
    It also says the e load weighs 55lbs...yikes!
  16. Apr 5, 2018 at 9:47 AM
    #3236
    Genghis_Khan60
    Hamza
    Booneville, MS
    They are pretty heavy, but I haven’t noticed any loss of power since installing. I’ve gotta make a 200mile round trip in a few days and see how it effects my mpg.
  17. Apr 5, 2018 at 9:54 AM
    #3237
    Newwt
    Tampa, FL
    Yeah does seem like a lot for this truck, if you don't haul anything or tow keep going to see when it evens out.
    When I had my 2500hd the difference was over 10psi, but I never ran the rears that low incase I needed to haul something.
  18. Apr 5, 2018 at 1:31 PM
    #3238
    MarvinL
    MarvinL Well-Known Member
    2018 Tacoma TRD OR 4X4 DCSB
    What is the best price you guys are getting on a set of 285/70r17?... looking to get my set next week.
  19. Apr 5, 2018 at 4:02 PM
    #3239
    blown ION
    blown ION Well-Known Member
    NJ
    2017 TRD PRO White
    Does your shop use a road force balancer? If not, it's something to possibly look into.
  20. Apr 5, 2018 at 4:05 PM
    #3240
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    The door jam says' differently, doesn't it? Same all around??
