Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Aug 12, 2016 at 3:09 PM
    #381
    DrFunker
    DrFunker Well-Known Member
    Alright.....for those of you whom have had these on for a while - wear update please. :D
    :playball:
    Soul Surfer likes this.
  2. Aug 13, 2016 at 9:15 AM
    #382
    CaptNoPants
    CaptNoPants Well-Known Member
    Toyota Tacoma 2015 PreRunner
    Stock
    I'm currently having a lot of wiggling when driving and I'm not sure if it's due to the alignment or the balancing. Apart from that my TPMS sensor is still lit and has not gone off, I figured it was because they were new sensors. Another issues might be the techs didn't fill them to 51 psi. What is road force balancing?
    Also just a heads to everyone that bought these tires or are looking to buy either online or at a shop, just found this on the falken website while looking for the proper PSI.
    http://www.falkentire.com/wildpeak-safety-notice
  3. Aug 13, 2016 at 12:23 PM
    #383
    Fife
    Fife Well-Known Member
    Cody
    Hampton, VA
    2002 Tacoma double cab TRD
    Stock
    I'm definitely getting the wiggle too. I got the road force balance and it wiggles like crazy, I can feel it in the steering wheel.
  4. Aug 13, 2016 at 12:28 PM
    #384
    Mayonayze
    Mayonayze Well-Known Member
    If you can feel it in the steering wheel, you're likely still of balance. i read that not all road force balances are created equal; lots depends on the tech running it. Bring it back.
  5. Aug 13, 2016 at 12:30 PM
    #385
    Fife
    Cody
    Hampton, VA
    Stock
    So discount tire direct shipped me these things out of balance after I paid for the road force balance? Awesome.
  6. Aug 13, 2016 at 12:32 PM
    #386
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Good information to share. As for PSI I am running mine at 40 front and back with no issues. The road force balance is a digital machine that uses a roller over the top of the tire to find either raised spots or harder spots as well as finding the potentially heavier spot on your tire. It is much better than a simple static balance and typically the machine is more well calibrated. If you're having trouble balancing the tire it could be your wheels as well or one of the tire needs to be replaced entirely as sometimes the mold for the tire causes differences similar to a casting flaw.
    I know after I got the road force done, my steering tightened up a bit. Not like it had a whole lot of play prior to, but it was definitely noticeable afterwards. You can google road force and find a locator for shops that have the machine
  7. Aug 14, 2016 at 11:16 AM
    #387
    CaptNoPants
    Stock
    Found out after they were mounted some issues. This morning I had to top all 4 tires to 41 psi they were around 33-35 psi. Figured that would fix the tpms, noooope. Drove to work and had less wiggle in the steering so that issue fixed itself mostly because of the lack of psi? Either way the tpms lights flash and then stay on. Seems as they need to be programmed or they are malfunctioning. Fk!
  8. Aug 14, 2016 at 11:29 AM
    #388
    Mayonayze
    i aired down to 32 just to see if I could feel anything different and sure enough there was a noticeable wiggle. Not through the steering wheel, but I felt it through the chassis. Aired them back up to 40 and it went away again. Mostly. Now I think I still feel a bit of bumpiness through the chasis, but I think that may have more to do with the stiffness of the carcass on these tires. I might not have noticed it initially because I wasn't monitoring for it. Anyway, if anyone can confirm that a harder carcas tire will transfer more road lumps through the chasis, then I'll write that concern off as non-issue.
  9. Aug 14, 2016 at 12:51 PM
    #389
    Mayonayze
  10. Aug 14, 2016 at 5:28 PM
    #390
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    Yeah, no. My experience has always been stiffer carcass tires require less psi, not more. Do the chalk test. You will feel more road bumps (wiggling?) with a stiff carcass tire, but it shouldn't be like an oscillation or a consistent level of shaking - like a paint shaker - that would be a bad balance.
    Do the chalk test
    Oh, and then do the chalk test. :)
    When I do the chalk test on me E-rated BFG's, it puts me at about 29-30psi. right in line with the door sticker. Remember, the Tacoma weighs a lot less than an F250. :)
    dp
  11. Aug 14, 2016 at 6:04 PM
    #391
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    I've got a few thousand miles on mine and they look basically like new.
    I feel like I get better wet traction now than I did with my Duratracs.
  12. Aug 14, 2016 at 6:43 PM
    #392
    Mayonayze
    I had Duratracs on my 14 GC and even with the AWD-ish quadra-drive, the tracs would still break traction during wet cornering and turns. Looked great, but not good wet weather hoops.
    @canyon: I'll chalk test it tomorrow. Chalk test it tomorrow.
    canyonchaser likes this.
  13. Aug 15, 2016 at 7:50 AM
    #393
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    I'd be curious to know what your chalk test, chalk test results turn out to be. :)
    dp
  14. Aug 16, 2016 at 5:11 PM
    #394
    Mayonayze
    Front 40 / Rear 38
    So says that chalk test, chalk test.
    90% of max psi for passenger rated does not apply here.
    Also, got caught in a heavy downpour on the way home from work yesterday: wet traction is solid with these. I tried hard cornering and moderately aggressive acceleration into turns and could not break traction.
    Lastly, for dummies like me that didn't already know: it was explained to me that out balance rear tires will be felt through the seat/chasis while out of balance front will shake through the steering wheel.
  15. Aug 16, 2016 at 6:26 PM
    #395
    3GTaco
    3GTaco Well-Known Member
    2016 TRD Sport AC MGM
    What's the chalk test?
  16. Aug 16, 2016 at 7:39 PM
    #396
    ruelj4
    ruelj4 New Member
    Jay
    Tacoma
    TRD Pro Wheels, Falken Wildpeak AT3W 265/70/17, Bed Mat, Splash guards
    265/70/17 on TRD pro rims. Awesome! No additional road noise and they really fill out the wheel well. I agree with some of the other guys that pics do not do these tires justice. I think they look better then KO2s and should give me better rain performance. $600 installed. Can't beat the price. image.jpg
  17. Aug 17, 2016 at 8:10 AM
    #397
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
  18. Aug 17, 2016 at 8:11 AM
    #398
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Do you have LT or P rated tires?
  19. Aug 17, 2016 at 8:19 AM
    #399
    3GTaco
  20. Aug 17, 2016 at 6:05 PM
    #400
    Thomas2335
    Thomas2335 Well-Known Member
    I guess they don't make these with white letters?
