Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Jan 24, 2019 at 9:19 AM
    #4121
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    A TPMS rebuild kit contains replacement parts for the valve assembly. Like standard rubber valves, these components wear over time. The Discount Tire stores include them with the installation :thumbsup:
    Details: TPMS Rebuild Kits | Discount Tire Direct
    Nearly all the Discount Tire stores have Road Force balancing equipment, which can be identified from the roller that is applied to the tire while the assembly is spinning - see the image below.
    The Road Force number is somewhat arbitrary, though it may be used as a quick indicator that there may be something "wonky" with the tire & wheel assembly. Or in other words, the higher the road force number means you may need to take a closer look at the assembly as a whole, both the tire and wheel, specifically if it's calling for a lot of weight. 4.5 ounces for a 32" A/T isn't excessive, but anything over 8 ounces I personally would dismount the tire and rotate it 180° from the current position, then rebalance.
    As far as stacking weight goes, this is typically done on narrow wheels when performing a Dynamic Spin Balance (A.K.A. 2-plane balance). With a Dynamic Balance, you want the inside weight no less than 6-inch away horizontally from the outside weight and visa versa (see the image below). This leads me to your comment regarding the weights being placed to one side... are the weights applied toward the inside front of the wheel (near the face of the wheel) and if so, are their clip-on weights on the back side of the inside barrel?
    ACEkraut likes this.
  2. Jan 24, 2019 at 9:43 AM
    #4122
    SnowSpartan
    SnowSpartan IT, not the clown.
    Boise, Idaho
    2017 Gray DCSB TRD Sport
    $540 for 4!
    eltacoutah[QUOTED] likes this.
  3. Jan 24, 2019 at 10:31 AM
    #4123
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    I have mine set to 40 all around, but actually just came to this thread to ask what other people are running them at. Any other recommendations or input from others would be awesome!
  4. Jan 24, 2019 at 11:57 AM
    #4124
    Mista_G
    Mista_G Well-Known Member
    Costa Mesa, CA
    '13 DCLB 4x4
    Kings F/R 2.5" EXT w/700lb springs, JD Fab UCA’s w/ Lower Pivot Kit, Icon Progressive AAL (with TSB and overload in), CB drop, 285/75-17 nitto ridge grapplers, SCS Deep Dish Ray Dimes, Snugtop Rebel Shell, Prinsu Toprac, Gibson SS Catback Exhaust, ATH front /rear steel bumpers, CVT awning, Airflow snorkel, @ Shmellmopwho sliders, SC w/ @justdsm HPtune, 3° Cam Gears @mightytacoman, 2.8 smooth flow pulley, StopTech BBK
    I run mine at 34, seems to be a nice psi.
    DarthPow likes this.
  5. Jan 24, 2019 at 12:43 PM
    #4125
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    40 psi on a light Tacoma sounds like it would ride like a dump truck. I run 36 front, 32 rear on my Silverado 2500 and that seems to be about perfect. For a Tacoma, anything over 32 would be overkill and likely to cause accelerated tire wear.
  6. Jan 24, 2019 at 1:03 PM
    #4126
    DarthPow
    It is definitely is a bit stiff, but more a bit more responsive, and a little more efficient, at least in theory. Maybe I'll let them down to 36 all around, and see how that feels for a little while.
  7. Jan 24, 2019 at 1:06 PM
    #4127
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    They are stacked on top of each other, towards the outside, not in towards the vehicle. No clip on weights. This dynamic spin balance done with a traditional machine or also a road force? Think I'll go up after work and try and have them 180 it and balance again, see if it's worse or better. If I can get this figured out, think the tires will be good.
    Thanks for the good info
  8. Jan 24, 2019 at 2:53 PM
    #4128
    Zacowacko
    Zack
    SW, OK
    Got lucky and got someone who knows a little at DT. What you have pictured in your post and same as they have is a hunter quick match, standard roller, no pressure. Said it measures rollout for high spots, doesn't apply 1200lbs of pressure.
    Hunter Road Force have a much larger roller and overhead laser, see below. He said sales guys do that. Hmmm. Not sure what to do now...
  9. Jan 24, 2019 at 2:57 PM
    #4129
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Would anyone here trust Costco to mount new tires on new Ray 10s? We don’t have a DTD nearby and my success with some of the local shops has not been great - they aren’t careful and that’s putting it lightly.
  10. Jan 24, 2019 at 7:32 PM
    #4130
    SnowSpartan
    Boise, Idaho
    I would say it is always hit or miss on places you aren't sure about. Go in to Costco, ask them questions on things you know well (in relation to tires), if they can explain it to you clearly, then I would give them a shot. If the question spaces them, then decide whether or not you want the headache like you've had with the local shops.
    On another note, I was told by DT that aftermarket wheels tend to make these tires shake, as it is harder to balance them. Can't back that up though, just wanted to give you a heads up.
    But on the positive side, going with Costco would be a good deal, so many people use them. Cheaper priced tires, life of maintenance, and I think they road hazard warranty the tires, where as at DT you have to buy it separately. Wish you luck.
  11. Jan 24, 2019 at 7:35 PM
    #4131
    The Real Moondog
    Moondog
    Excellent points and thank you! I just bought tires for my GTI (grocery getter) so I think I’ll give them a try with it and then if it goes well maybe I’ll try the Taco. I just really don’t want my Rays screwed up. I appreciate the help!
  12. Jan 24, 2019 at 8:24 PM
    #4132
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I used the Toyota Dealer to mount mine brother, they were a little more expensive but it was done correctly which was worth it in my humble opinion.
  13. Jan 24, 2019 at 8:30 PM
    #4133
    shakerhood
    Southern Ohio
    You might also want to get the alignment in your truck checked too, mine suffered from a bad case of Toe Out from the Factory.
  14. Jan 24, 2019 at 8:30 PM
    #4134
    The Real Moondog
    Moondog
    And if they screw it up I most likely have a better chance of getting them to repair, replace, or fix what they do. My dealer is also a Lexus dealership and the owner’s son told me last time they handled high dollar wheels all the time and that they would not screw them up. I guess I’m going to fork over some extra cash and maybe save a headache. I’ll let Costco do the grocery getter GTI tires and the dealer can do my Taco setup, especially since it has to go back to the shop yet again. Ugh. Appreciate the help bro....:)
    shakerhood[QUOTED] likes this.
  15. Jan 24, 2019 at 8:34 PM
    #4135
    The Real Moondog
    Moondog
    So I know this is a Falken thread but I just ordered a set of new tires for my VW GTI late Tuesday night from Jake @Discount Tire Direct and they have already arrived at my home! Super fast service and, yes, they beat a very low advertised price from a competitor. I highly recommend them FWIW. Peace....
    shakerhood likes this.
  16. Jan 24, 2019 at 10:49 PM
    #4136
    Zacowacko
    Zack
    SW, OK
    Mine were priced good from DT, mount and balance not so much. They lost 3 screws for my center caps and cracked two over tightening, TE stock wheels. Then told me they had a road force machine and would throw that in to get the sale. I asked if they had one before I purchased. In the past RF only thing that would make my duratracs tolerable. Got those RF across the street at the Ford dealer, our Toyota dealer has changed owners several times in the last few years and leave a lot to be desired. Ford dealer been there, same family for like 40 years. Like their service, actually bought my Tacoma there used, lol.
    I've actually got better service from Sam's club, than the DT, but it's a new store, so maybe that has something to do with it...
    Trying to decide on whether I want to pay for the RF across the street or just buy some tires from them and return these. Why can't anything be easy, lol
  17. Jan 24, 2019 at 10:59 PM
    #4137
    The Real Moondog
    Moondog
    I understand where you are coming from for sure. Things for me are never as easy as just going to the nearest dealer and getting something done. Something always get screwed up and it really gets old. And, it’s hard to find time to go back to get the screw ups fixed too. We don’t have a DTD where I live yet but even when they open it’ll still be a new store and that can be both good and bad. I’ve found them to go above and beyond to try to make things right but they are not an option where’s I live so it’s either a Toyota dealer or a local guy that has a Road Force but I’ve never used him and just don’t know.
  18. Jan 24, 2019 at 11:17 PM
    #4138
    Jamie4x4
    Jamie4x4 Well-Known Member
    Jamie
    San Diego
    ‘18 MGM OR 4wd DCLB (Stolen), in market for new DCLB
    255's, 5100s w OME, full Martin Roof Rack, Snugtop
    I recently got 265/75/16 wildpeaks and theyre great! Took them in the snow a few times already, and I barely needed 4wd.
  19. Jan 25, 2019 at 4:17 AM
    #4139
    Noslackline
    Noslackline Well-Known Member
    New England
    '15 TRD Sport DCSB 4X4 BRM
    We're running 265 65 17's with inflation @ 32 fronts 30 rears empty bed.... seems to be a good match for ride quality, handling, traction and fuel consumption.
    These tires are exceptional in the wet.
  20. Jan 25, 2019 at 7:41 AM
    #4140
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I agree that they are great tires but I don't think you are really comparing apples to apples. Tacoma with BFG's vs Work truck towing 7k lbs (assuming full size truck) with Falkens. The work truck is less likely to spin a tire in wet conditions due to the heavier load, not necessarily the tires. While the Falkens are grippy, you can't compare unless on the same vehicle under the same conditions. There's just to many other variables in play.
    GF8er and InfernoChalupa like this.
