Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Mar 20, 2019 at 9:33 PM
    #4381
    buggravy
    buggravy Well-Known Member
    Calabasas, CA
    '19 TRD Offroad
    Anyone know if the weight on the 265/75/16 SL rated tire is a typo? On Discount Tire the 265/70/16 is listed as 43 lbs, the 265/75/16 at 44, and the 265/70/17 is listed at 47, all SL rated. It doesn't make sense in my mind that the 265/75 is only one pound heavier than the 265/70 even though it's a full inch taller. And then how could the 265/70/17 be four pounds heavier, even though it's the same diameter but has 1/2 less sidewall all the way around? Am I missing something, or is the weight listed incorrectly?
  2. Mar 21, 2019 at 6:11 AM
    #4382
    BRONSON
    BRONSON Active Member
    Canada
    2009 TRD Sport 4x4 DCLB
    885 w/ 5100's + 1/2" d.s. top plate, EL096R w/ B110's, Whiteline LCA bushings, Energy Suspension poly leaf & shackle bushings, new OEM rear shackles, custom rear brakeline mount & e-brake extensions, LR UCA's, SnugTop cap
    Weighed my set of 4-ply 265/70/17 three times on what I thought was a decent bathroom scale before mounting:
    43.0 Lbs
    43.0
    43.0
    43.6
    Mounted & balanced on FN Wheels 17" FX Pros (approx 24 Lbs):
    68.2 Lbs
    68.2
    68.8
    69.2
    Tread depth is also 13/32nds down the middle, sometimes even a hair less.
    I found the spec of 31.7" tall to be accurate once mounted & inflated, though I'm now rubbing on the passenger mudflap backing out of the driveway, even with a lift. That could be the chubbier tires, the new wheels sticking out a bit further or a combo of both. Either way I'm due for an alignment.
    DLillest likes this.
  3. Mar 21, 2019 at 6:32 AM
    #4383
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    I have the same setup but at stock height. I started rubbing only on full lock turns. Took the mudflaps off but I want to keep them for rock protection. They only seem to be rubbing on a specific part on the mudflaps. Ill be using a heat gun this week to try and bend that out of the way.
  4. Mar 21, 2019 at 1:55 PM
    #4384
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  5. Mar 21, 2019 at 5:46 PM
    #4385
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    boostedka[QUOTED] likes this.
  6. Mar 21, 2019 at 6:30 PM
    #4386
    xxhv52xx
    xxhv52xx Well-Known Member
    Henry
    SoCal (Los Angeles)
    2018 Tacoma TRD Off-Road 4x4 in Super White
    TRD Pro Grill with Raptor style grill lights TRD Exhaust with black tip TRD Skid Plate TRD shift knob TRD Pro Wheels (17”) with Falken Wildpeaks 265/70/17 Bakflip MX4 Tonneau Cover
    Getting these installed this Saturday on some TRD Pro Sema wheels. Pretty darn excited. Is there a specific way to install these? Yellow dot? Red dot?
  7. Mar 21, 2019 at 6:35 PM
    #4387
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
  8. Mar 21, 2019 at 6:35 PM
    #4388
    boostedka
    James
    NM
    That’s cool man. Thanks for posting.
  9. Mar 21, 2019 at 6:38 PM
    #4389
    xxhv52xx
    Henry
    SoCal (Los Angeles)
  10. Mar 21, 2019 at 6:39 PM
    #4390
    boostedka
    James
    NM
    Anyone have any opinions on these vs the new GY ultra Terrains?
    These wild peaks are definitely a lot less expensive.
    The balancing issues that some report are concerning though.
  11. Mar 21, 2019 at 6:56 PM
    #4391
    The Real Moondog
    Moondog
    Yes.
    xxhv52xx[QUOTED] likes this.
  12. Mar 21, 2019 at 6:59 PM
    #4392
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Nobody can tell you if you will get a good set of tires. With that being said, I got mine about 6k miles ago and I still love them. Been nice in winter.
  13. Mar 21, 2019 at 7:12 PM
    #4393
    xxhv52xx
    Henry
    SoCal (Los Angeles)
    Thanks for the info. I appreciate your input and help.
  14. Mar 21, 2019 at 7:28 PM
    #4394
    The Real Moondog
    Moondog
    Any time and best of luck to you! :)
  15. Mar 21, 2019 at 7:31 PM
    #4395
    The Real Moondog
    Moondog
    Agreed. Sometimes balance issues are the shop mounting them and sometimes it’s just an out of round tire. No manufacturer is exempt. The most consistent tires I’ve seen are Michelin’s but they don’t make anything anywhere near as aggressive as what I like/want.
    boostedka likes this.
  16. Mar 21, 2019 at 8:43 PM
    #4396
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    The yellow mark aligns with the valve stem, The red mark aligns with a dimple or mark the wheel manufacture puts on the wheel.
    Yellow mark is lightest spot of tire, so align with valve stem (heaviest spot of wheel)
    Red mark is indicating the point of maximum radial force variation on the tire. Align it with the dimple or mark on wheel (wheel assembly's point of minimum radial run-out)
    Choose one method and stick with it.
    Marcmtb1 likes this.
  17. Mar 22, 2019 at 7:04 AM
    #4397
    The Real Moondog
    Moondog
    Everything I read (see the link I posted) said if both dots are present then you should align the valve stem with the red dot.
  18. Mar 22, 2019 at 7:08 AM
    #4398
    The Real Moondog
    Moondog
  19. Mar 22, 2019 at 7:37 AM
    #4399
    drewbert41
    drewbert41 Well-Known Member
    Champaign, IL
    21 Cement DCSB 4x4 TRD OR
    road force balancing
  20. Mar 22, 2019 at 8:45 AM
    #4400
    The Real Moondog
    Moondog
    Hey folks, kudos to @GF8er for showing me and maybe the rest of us that you can’t believe everything (or sometimes much at all) that you read on the Internet! LOL. I decided to check with Falken and their verbatim response was:
    The red and yellow dots are uniformity marks used to help the dealer get a better balance with using less weights.
    The yellow dot is the low spot on the tire, and the red is the high point.
    We recommend mounting the yellow dot closest to the valve stem.
    So, I humbly stand corrected. TireBusiness is a reputable site and they said red dot but I’m going with what Falken says since they make the tire and know their tires. I think if in doubt reach out to the manufacturer but, again, thanks @GF8er !
    Tacoless, GF8er, Marcmtb1 and 3 others like this.
