Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Mar 28, 2019 at 5:43 PM
    #4441
    Mario0815
    Mario0815 Well-Known Member
    Mario
    2016 Tacoma TRD Sport
    Thanks! After the mail in rebate, It was around $110 per tire. I kept the stock size, I don't plan on lifting the truck and didn't want to lose MPG or rub.
    GSDLVR123 likes this.
  2. Mar 28, 2019 at 6:30 PM
    #4442
    buggravy
    buggravy Well-Known Member
    Calabasas, CA
    '19 TRD Offroad
    Thinking that might be cost prohibitive :canada:
  3. Mar 29, 2019 at 5:49 AM
    #4443
    terps2005
    terps2005 Well-Known Member
    Southern MD
    17 Super White DCLB Sport
    TRD Pro Grill w/white letters Inno roof rack Body Armor Hiline Bumper TRD Pro Skid plate Full meso interior chrome delete Bronze AGP T4R replica wheels Falken Wildpeak AT3W tires Homelink Mirror Pioneer DMH-WC6600NEX head unit with Maestro integration A shit ton of crumbs and dirt in the back from my 2 little monsters
    I know I'm an outlier but I have 87,800 miles on my set that I put on in February 2017 and the tread is still good to go....plenty of depth left. I do a ton of highway miles and don't really drive it hard. Should I replace them anyway or drive them until the tread depth gets to replacement level?
    1Shifter, mgmdclb and boostedka like this.
  4. Mar 29, 2019 at 7:14 AM
    #4444
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    I generally drove mine till theres not much tread left on them, but was in an accident last year where I hydroplaned and rolled my truck. I thought I still had the summer left in those tires easy but the accident definatly changed my idea of when I’m gonna replace my next set.
  5. Mar 29, 2019 at 9:52 AM
    #4445
    Crent89
    Crent89 DIY TACO
    california
    2008 silver Tacoma TRD sport/ 2018 Super White 4Runner 4X4
    so i have a 2nd gen with 3rd gen OR struts, gave me about a 1in lift up front. question is can i run 265/75/16 with no problem or will they rub? i will be installing some 1.5" wheel spacers if that helps at all.
  6. Mar 29, 2019 at 10:05 AM
    #4446
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Are the rim stock, or aftermarket? If you have aftermarket rims, especially with a smaller offset/backspacing, you might rub with the spacers. I had 1.25" spacers with a 0 offset rim, and the same tire size, and I was rubbing.
  7. Mar 29, 2019 at 10:31 AM
    #4447
    Crent89
    Crent89 DIY TACO
    california
    i actually have 3rd Gen OR wheels aswell.
  8. Mar 29, 2019 at 10:33 AM
    #4448
    DarthPow
    Then you should be fine, the offset on those is pretty big, you shouldn't run into the cab mount or the pinch weld, or any of the plastic mud flaps. But obviously can't be sure until you put them on.
    Crent89[QUOTED] likes this.
  9. Mar 29, 2019 at 6:17 PM
    #4449
    Wojotiger
    Wojotiger Member
    Was looking at getting these in 285/75r16 but was hoping to find them in less than 10ply. For those that went 10ply, are you happy? I currently run some cheap 285/75r16 and was hoping I could go with a lighter setup but found I'd have to buy a 17in rim if I wanted to go the same size but in a lower rating and can't decide if the cost is worth it. Please let me know how you like the 285/75r16 10plys
  10. Mar 30, 2019 at 3:52 PM
    #4450
    Mario0815
    Mario
    Mounted mine today!
    shwokee, zwright, shakerhood and 4 others like this.
  11. Mar 30, 2019 at 3:54 PM
    #4451
    mgmdclb
    2018 MGM DCLB Sport
    I had 1.25" wheel spacers on my 2nd gen with stock sport wheels and a 2.5" lift and 265/70/17 General AT2's and rubbed at full lock in reverse.
  12. Mar 30, 2019 at 4:02 PM
    #4452
    mgmdclb
    2018 MGM DCLB Sport
    265 75 16?
  13. Mar 31, 2019 at 6:44 AM
    #4453
    Mario0815
    Mario
    I kept the oem size 265/70/16.
    Medic352 and TXpro4X4 like this.
  14. Mar 31, 2019 at 4:58 PM
    #4454
    TheFlash121
    TheFlash121 Active Member
    2016 Tacoma SR5 V6 DBCSB Blazing Blue Pearl
    A few weeks late but got my 265/75/16 at a local shop. Mounted and balanced with the new wheels as well. Already have 800 miles on them. They are great no balancing issues either. On first rotation I will get them rebalanced just in case. Stock lift for now. Although I have noticed a hit of 3mpg I’ve taken. My air filter has been due, so I changed it today. Let’s see if that helps. I paid $700 all in, a bit steep I know Although I got lifetime rotation and balance plus warranty included. Loving them so far 970C2BF7-5F9C-46D2-819B-34E918CF836F.jpg D0FF0EA6-7CE5-4E0C-A7DC-E9A8C3E918B2.jpg
    bcgill, 1Shifter and mgmdclb like this.
  15. Mar 31, 2019 at 6:52 PM
    #4455
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I just ordered a set from WM, total without mounting and balancing was 463.00. I wasn't sure if I wanted to stay at the OEM size or go up to the 265's. I'm glad to hear you're not having rubbing or balancing issues
  16. Apr 1, 2019 at 9:11 AM
    #4456
    Tgruetzm
    Tgruetzm Well-Known Member
    2018 DCSB OR MT
    DIY hand mounted and balanced these over the weekend. Once I figured out a good process it was about 30 minutes per tire.
    My static balancer seems to do a decent job, didn’t notice any vibrations at 80 mph.
  17. Apr 3, 2019 at 5:42 AM
    #4457
    buggravy
    Calabasas, CA
    '19 TRD Offroad
    I've got 265/70/17s going on today. For air pressure I was thinking I'd start at 35psi, and adjust as/if needed from there. Sound about right?
    boostedka likes this.
  18. Apr 3, 2019 at 6:30 AM
    #4458
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Ordered 4 265/75/16 sl rated wild peaks yesterday...!!
    Went to America’s tire and showed them the offer by Walmart and Amazon for 108.00$... I told them that DTD could beat that price, ship free and no tax.
    Got all 4 for 426.00$.
    They traded my spare in and gave me another brand all terrain tire n the same size for 41.00$.
    My total out the door for all 5 tires including lifetime warranty was 672.00$.
    Not as good as some I’ve seen on here but I was happy with deal.
    They ordered them and I should get them installed next week.
  19. Apr 3, 2019 at 6:51 AM
    #4459
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    I just got the same, I think I will start with 35 as well.
  20. Apr 4, 2019 at 1:52 PM
    #4460
    1Shifter
    Jeff
    09 PreRunner
    Pulled the trigger on some Wildpeaks. Got em on sale at WM. Their gonna rub the dude said, slap them bitches on I said
