Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Apr 4, 2019 at 3:54 PM
    #4461
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Another fleet truck update. These are in a Ram 1500 that I used to drive two years ago. The vehicle has temporarily come back to my area and it still has the Wildpeaks I put on it. Unfortunately, the maintenance log book has gone missing, but based on old invoices I estimate these tires have over 50k miles on them.
    1Shifter, Hairy Taco and boostedka like this.
  2. Apr 4, 2019 at 4:37 PM
    #4462
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Went back to Wildpeak after having a set of Duratrac from a used setup I purchased. Glad to be back on this quieter tire. Maybe slightly less aggressive, but I doubt any real compromise. What are the PSI people are running for P265 70 17?
  3. Apr 4, 2019 at 4:43 PM
    #4463
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    34 upfront 32 in rear
  4. Apr 7, 2019 at 5:20 PM
    #4464
    decal211
    decal211 Well-Known Member
    Vermont
    2016 TRD Sport Silver DC SB 4x4
    Hey all!
    Just bought a set for 4r pro wheels for my 2016 TRD Sport. Think I'm set on the wildpeak at3 but not on tire size. Seams like a lot of folks run 265/70r17 on stock suspension. Does anyone have any pictures of a gen 3 trd sport with 265/65r17? Thanks!
  5. Apr 10, 2019 at 6:25 AM
    #4465
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Well I had a new set of 265/75/16 Wild
    Peaks installed at America’s tire yesterday.
    I asked two different sales people that the yellow dot be placed at the valvestem per Falkens recommendation and they said sure no problem we will balance them correctly. Drove home and noticed slight vibration at around 70 on the freeway so decided to check the mounting location of the yellow dots and found none of them were even close to the valvestem. One was 180 degrees off on the complete opposite side from the valvestem and had 3oz. Of weight to balance. Oddly enough I noticed all the weights were placed where the yellow dot was located on all four tires.
    Feel like going back and making them remount them the way I asked for.
    Marcmtb1 likes this.
  6. Apr 11, 2019 at 2:47 PM
    #4466
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Maybe a stupid question but will a 265x75r16 tire fit under the truck as a spare? I still have the OEM size as spare . So far I like the Wildpeaks they seem to get quieter the more I drive em 20190404_170141.jpg
  7. Apr 11, 2019 at 3:10 PM
    #4467
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    Just had 265/70/17s mounted w/ TRD Pro 4Runner wheels. Not a lot of miles logged on them yet, and had the old wheels and tires in the back. Will report back after some drive time. Seemed to roll very smooth and no vibrations, but only got up to about 55mph. Look great, much more aggressive in person than pictures depict.
    felix1776 and shwokee like this.
  8. Apr 11, 2019 at 5:51 PM
    #4468
    SCHALICKE
    SCHALICKE Utahrd
    S. Champ
    Clearfield UT
    2015 Tacoma TRD OFF Road
    Never Enough
    Yes it will fit.
    1Shifter[QUOTED] likes this.
  9. Apr 15, 2019 at 8:31 AM
    #4469
    FletchLax
    FletchLax Well-Known Member
    Kyle
    Greenville, South Carolina
    2020 Cement SR5 DCSB
    I need a little help making my final decision. First time replacing tires on the Tacoma I bought 2 years ago. She currently runs 260/70r16 and desperately needs replacement tires
    My truck sits without a lift and I pull the above pictured trailer around the southeast almost every weekend between June - August.
    Do I want the AT3 in 265/70r16 or 265/75r16 ?? Will 265/75 rub without a lift? I don’t do off-roading, it’s mostly highway and city miles. I like the idea of gaining an inch for the look, just don’t want it to rub or cause a big drop in MPG
  10. Apr 15, 2019 at 9:39 AM
    #4470
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    @FletchLax
    You’ll fit either size with no lift and mileage won’t be hurt more than maybe 1mpg with the 265/75’s.
    So 265/70 or 265/75 in SL, P or C load. Do not get E load.
    On a semi-unrelated note, I’d recommend a single leaf “long add-a-leaf” or a weight distributing hitch. Looks like you squat a bunch with that trailer and from experience...it’s not a comfortable ride like that.
  11. Apr 15, 2019 at 9:49 AM
    #4471
    FletchLax
    Kyle
    The 265/75 Falkens I was scoping out were an SL load, so good to know...what exactly is the difference there? Weight capacity?
    In regards to the squat, I've definitely noticed it too - are these what I would need?
  12. Apr 15, 2019 at 10:15 AM
    #4472
    Marcmtb1
    PHX, USA
    @FletchLax
    In a short answer yes. Weight capacity which is correlated to the number and thickness of tire plies...leading to tire weight.
    SL Wildpeaks are pretty stout and will be better off than your current tires when you’re towing.
    I’ll PM you on suspension stuff so we don’t distract this thread
    FletchLax likes this.
  13. Apr 16, 2019 at 5:48 AM
    #4473
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Pretty aggressive tire for a truck that is on highway, no off-road use, and no snow. What about the less aggressive Falkens? Like a Rubitrek?
  14. Apr 16, 2019 at 10:58 AM
    #4474
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    Hey man! Awesome truck, love your set up, how are the cooper ST Maxx in the snow?
  15. Apr 16, 2019 at 11:05 AM
    #4475
    Sandman TRD
    Indy
    I have put about 100 miles on my 265/70/17s SL. Not a lot of mileage yet, but very pleased with these so far. No balancing issues with mine, very quiet for the aggressive tread design, and ride smooth. I like the way the truck handles better with these VS my stock 16” Goodyears. Doesn’t float near as much.
  16. Apr 16, 2019 at 11:08 AM
    #4476
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Does Falken make 255/80r16 wildpeak at3w P rated 4 ply?
  17. Apr 16, 2019 at 11:14 AM
    #4477
    Wixo
    Hank
    Tint, LED interior
    Also, how much did you pay for your 265/75r16s? I paid $780 for all 5. Includes all necessary balancing after wards and rotations. I got the insurance for an extra $50.
  18. Apr 16, 2019 at 11:17 AM
    #4478
    Wixo
    Hank
    Tint, LED interior
    Rims and tires?!?!
    DLillest[QUOTED] likes this.
  19. Apr 16, 2019 at 11:18 AM
    #4479
    Wixo
    Hank
    Tint, LED interior
    I didnt have any, then I offroaded pretty hard. Took all the mud off and it almost went away. When I brake hard I feel some vibration.
  20. Apr 16, 2019 at 1:25 PM
    #4480
    Roddy13
    Roddy13 Well-Known Member
    For all highway... I would not get the falken wildpeaks. Get some Michelin LTX/Defender/or AT2's @ costco can be had for a great deal.
