Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. May 20, 2019 at 3:02 PM
    #4521
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    Anyone got these with SCS f5’s 16” and stock suspension? Wondering what the biggest tire size I could go with without rubbing.
  2. May 20, 2019 at 3:10 PM
    #4522
    Chris_The_Red
    Chris_The_Red Well-Known Member
    Brooklyn, NY
    2018 Cement Tacoma TRD OR
    Everyone seems to go with 265/75r16. Doesn’t rub with most 16” wheels. Safest bet.
    Pruby18[QUOTED] likes this.
  3. May 20, 2019 at 3:12 PM
    #4523
    Chris_The_Red
    Brooklyn, NY
    0F7CC875-A47C-4E01-B2B5-AF1214DCD9E5.jpg 1A3FD727-A435-4CED-B8BC-E2360A565A5A.jpg
    Pictures don’t do them justice. Very aggressive compared to OEM Goodyear’s. Very happy with them. Full pic tomorrow.
    Pruby18 likes this.
  4. May 20, 2019 at 5:54 PM
    #4524
    Slickestwilly
    Slickestwilly Well-Known Member
    Will
    NH
    25 Pro
    Depends on which offset you go with. My 16” Ray 10s have a -12 offset and rub only a little when turning while the suspension is compressed. The -25 will definitely rub a bit with 265/75/16 on stock suspension. If you have mud flaps up front you’ll have to remove them. It’ll be worth breaking out the heat gun because they’ll look awesome.
  5. May 22, 2019 at 12:26 PM
    #4525
    Hashc93
    Hashc93 Well-Known Member
    How do you like these vs the ATX?
    I think my choice is narrowed down between the two. Deciding factor would be snow performance.
  6. May 22, 2019 at 1:01 PM
    #4526
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Would you be able to post a side view? Thanks in advance.
  7. May 22, 2019 at 3:42 PM
    #4527
    Bigtrees
    Bigtrees Well-Known Member
    Oregon
    2002 Reg Cab, 2007 DCSB
    Falkens for the snow win. We get plenty of ice and snow up here and the Falkens have performed amazing. The ATx are great as well, but I’d put the Falkens ahead of them.
  8. May 22, 2019 at 3:56 PM
    #4528
    Hashc93
    Good to know and they are cheaper too so that’s a plus.
    Thanks for the reply
  9. May 22, 2019 at 6:45 PM
    #4529
    redtacofred
    redtacofred Member
    Fredericksburg, VA
    05 Tacoma Off Road
    Just ordered these from Amazon. 265/75/16 for $506 shipped to me. Can't wait to get them installed!
  10. May 22, 2019 at 6:59 PM
    #4530
    Niccas9
    Niccas9 Well-Known Member
    Nic
    2019 TRD Off-Road
    Just got the 275/70/17s to replace my Pro Comp Xtreme MT2 in 265/70/17.
    I have a 2” lift, aftermarket (JBA) UCA’s and I have a slight rub at full lock full stuff. Going to take the heat gun to the plastic this weekend to see if it makes a difference along with a fresh alignment.
    Put about 50 miles on the tires and like them so far. Much, much smoother and quieter!
  11. May 24, 2019 at 9:07 PM
    #4531
    sandman8108
    sandman8108 Well-Known Member
    Los Angeles, CA
    2002 Tacoma V6 Double Cab TRD
    Hello all,
    Im researching my next set of tires and I'm leaning towards the Falken Wildpeaks in 265/70/17 standard load. Im coming from Cooper Discoverer AT3 in LT265/70/17 load range C. My question for you all is how do these Falkens ride in the standard loads?
    They seem to weigh about the same, have similar load specs at similar PSI, and have the same 2 ply sidewall as the Coopers, even though they are technically a standard load tire. However, the Coopers are a bit jarring being a LT Load C tire. My truck is just too light now for a LT tire, and I do too much street driving unfortunately. My next tire will be a standard load for sure, but do you think the Falkens have a similar jarring type of ride that the LT Load C tires have?
    My other choice right now is the Nitto TG2 which are 5 lbs lighter and dont have the same load specs as the Falkens, so I would assume that they ride closer to the stock standard load tire feel. But I like the Falkens a lot!
    Looking forward to hearing your opinions and experiences with the Falkens.
  12. May 25, 2019 at 9:56 AM
    #4532
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    I have Falkens in E load. Swapped from the stock GY Wranglers and in my opinion, they’re less “jarring” than the Wranglers - which are lighter than the C’s.
    If jarring is an issue with your next tires, upgrade your suspension a bit and it’ll go a long ways in that regard.
  13. May 25, 2019 at 2:53 PM
    #4533
    Egyptacom
    Egyptacom Well-Known Member
    Boynton Beach, Fl
    2016 toyo taco
    Falken Wildpeaks AT3W 265/75r16 trd pro wheels.
  14. May 27, 2019 at 7:28 PM
    #4534
    Ran-TRD
    Ran-TRD Well-Known Member
    Stock suspension ?
  15. May 27, 2019 at 7:35 PM
    #4535
    Ran-TRD
    What lift are you running ? And how much lift did you get in order to run this size tire ?
  16. May 27, 2019 at 8:30 PM
    #4536
    Niccas9
    Nic
    2019 TRD Off-Road
    Did a little reshaping if the wheel well plastic with a heat gun and some minor trimming with the dremel. 275/70/17s aren’t rubbing at all now even at full stuff.
    Was also able to get the full size spare to fit in the spare compartment!
    Marcmtb1 likes this.
  17. May 27, 2019 at 8:52 PM
    #4537
    Marcmtb1
    PHX, USA
    You don’t necessarily need a lift if you’re willing to trim plastic and heat gun the fender liner. I also peeled back the fender liner and bent the vertical “pinch weld” at about a 45* angle so I could heat gun the liner a bit more flat. I didn’t feel like doing a little trimming here and there and testing and repeating..
    I don’t rub anymore and never hit on the cab mount or upper control arms. Probably because my caster is 2.3 on both sides (with stock upper control arms). I have flexed to the bumpstops at full steering lock in both directions.
    The lift is just bilstein 5100’s set at 0 with OME 885 coils and a 1/4 trim packer on the driver side. About 1.5 inches of lift in front at most. In back I have Icon RXT leafpacks in setup 2 with bilstein B110’s and Sumosprings as my bump stops. Its tough to say how much lift because of the sag I had stock with the sliders and camper shell. Rear is roughly an inch taller than front.
    Rides awesome. I’m glad I went with this size and E load.
    Funkr and Ran-TRD[QUOTED] like this.
  18. May 27, 2019 at 9:10 PM
    #4538
    Ran-TRD
    That’s awesome man, I’m still trying to decide what to do with my taco, this info really helps me out a lot man !
    Marcmtb1[QUOTED] likes this.
  19. May 28, 2019 at 5:23 PM
    #4539
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    Yes, stock suspension.
    Ran-TRD[QUOTED] likes this.
  20. May 31, 2019 at 8:10 AM
    #4540
    CMW_TRD_Sport
    CMW_TRD_Sport Well-Known Member
    Chad
    2014 Tacoma TRD SPORT
    Love them!
    Egyptacom and grdgz97 like this.
