Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Aug 17, 2019 at 6:46 PM
    #4621
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Anyone using these tires in 265/70/17s on 17" SEMA wheels on a stock 3rd gen TRD OR Taco?
    Considering moving up to 17" from the 16" wheels and was wondering if there was any rubbing issue to expect.
  2. Aug 19, 2019 at 12:27 PM
    #4622
    Brockton
    Brockton Well-Known Member
    2006 TRD Off Road
    Having these (265 70 r16) installed this week and will post before and after pics!
    Then Saturday...they will get tested!
  3. Aug 19, 2019 at 12:39 PM
    #4623
    Goran
    Goran Well-Known Member
    Jacob
    WA
    2023 Tundra Pro
    Just installed some 265/75r16 10ply falkens! Really enjoyed the ride, super smooth and no balancing issues yet.
    Here are my cheap poser shots.
    H3llRid3r likes this.
  4. Aug 20, 2019 at 4:40 PM
    #4624
    Brockton
    2006 TRD Off Road
    Man, these things look mean! $635 installed at Discount Tire and I’ll be heading to the dirt this weekend!
    2E22BB46-16B1-454C-8E17-2AE1384BDF44.jpg A2D9A3F6-4EB0-40C6-816A-19EA9F52FE5E.jpg
    JCWages and THE_KiRRAx like this.
  5. Aug 23, 2019 at 8:31 PM
    #4625
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    JCWages likes this.
  6. Aug 27, 2019 at 8:57 AM
    #4626
    go2cnavy
    Wow that was fast!
    TBX, JCWages and onesixonetwo like this.
  7. Aug 28, 2019 at 7:34 PM
    #4627
    go2cnavy
    C-load rides beautifully. Just mounted them and I am amazed at the difference.
    1st set - 5K miles. Falken WP 285/75-16 E-rated. -Super stiff and tons of rub.
    2nd set - 45K miles. Falken WP 265/75-16 P-Metric. Too spongy/bouncy. Too small. They worked great in all conditions (especially the snow) and had tons of tread left when I replaced them with
    #3 255/85-16 8K miles. COOPER STT Maxx E-rated. Perfect size. Too stiff. Wandered right. No rub. 8,000 miles
    #4 275/70-17 Falken WP C-rated. PERFECT!
    onesixonetwo and JCWages like this.
  8. Aug 28, 2019 at 11:13 PM
    #4628
    TBX
    TBX Member
    Looks like the 285-75-16 weighs in at 60.6 lbs vs 57.1 lbs for the 275-70-17. Do you think the weight contributed to the ride stiffness at all?
    The reason I ask is because I'm still deciding between 285-70-17 C @62.8 lbs vs. 285-70-17 E @58.9 lbs. It's a 3.9 lb difference per tire. If the C is a lot less stiff compared to the E then I may just suck it up and get the heavier tire for a much better ride quality.
  9. Aug 29, 2019 at 3:31 AM
    #4629
    go2cnavy
    No. Not at all. It’s all the load rating. There is no wrong choice if you’re making the choice consciously. Here is a cut and paste from a debate I had in this thread about load ratings.
    https://www.tacomaworld.com/threads/what-tires-will-i-get.623205/#post-21403136
    Our trucks are not heavy enough for E rated tires. Even heavily armored it’s still not heavy enough for E-rated tires. I do air down. I even have to run 30-32 psi on the street or the rear traction sucks in the rain.
    A lot of people like E-rated tired because they can air down considerably and that’s ok. It’s even required for what some people do with their trucks. However, the OP stated use doesn’t indicate that he want to run 12psi and wheel his truck where max traction and puncture resistance is required.
    Some people also buy E-rated because they are too cheap to spend the extra money on C-rated tires since they are considerably more expensive.
    Others buy P-metric because they like a good ride and aren’t super heavy.
  10. Sep 1, 2019 at 3:14 PM
    #4630
    JCWages
    JCWages Well-Known Member
    Grass Valley, CA
    2018 GMC Canyon SLE 4x4
    King 2.5 coilovers, 33s, steel bumpers and stuff.
    I finally managed to flat an E-load yesterday on the trail. :burnrubber:
    I took a side trail (Chimney Rock Trail) that quickly turned very narrow with a lot of downed branches (pine) and trunks along the edge of the trail. Due to the narrowness of the trail and the width of my truck I couldn't avoid the smaller bits of debris and I think that's what punctured the upper sidewall. A quick plug fix and I aired it back up to 20psi and it held for another 40+miles of rough trail and another 50+ miles of winding highway back home. Drove another 94 miles today and still holding air.
    What's funny is I have watched the sidewalls conform and wrap around rocks and take no damage but sharp sticks are the devil's tool!
    onesixonetwo likes this.
  11. Sep 2, 2019 at 1:53 PM
    #4631
    tacowizard3
    tacowizard3 New Member
    2019 Cement TRD OR DCLB
    Sup guys? My new 2019 TRD OR DCLB with a leveled suspension will be delivered on Wednesday and I'm doing some prelim research on some new tires. The wild peaks seem like they're the most attractive at this point in my research but I can't decide if the stock (265/70/16) is the way to go or to 265/75/16 or 275/70/16. I'm leaning toward the 265/70/16 but worried the level kit will make them look too small. It's a super noob question but does anyone out there have pics of their taco with these specs??
  12. Sep 4, 2019 at 10:18 AM
    #4632
    TBX
    TBX Member
    I went to America's Tire and bought the 285 70 17 C's yesterday, even though they weighted more than E's! Can't wait to slap them on this weekend.
    Honestly, I would go with the 265 75 16. You'll be much happier.
    Denteen likes this.
  13. Sep 4, 2019 at 3:23 PM
    #4633
    go2cnavy
    The C load is so much better. Ride is great.
    JCWages likes this.
  14. Sep 4, 2019 at 4:32 PM
    #4634
    JCWages
    Grass Valley, CA
    That will probably be my next tire, or the Geolandar X-AT. The 3-ply sidewall on an AT is nice.
    On a related note, there was a paperwork mixup regarding certs on my current 285/70/17E tires and America's Tire (Discount Tire) in Auburn took care of my punctured tire away. Love these folks!
    TakoLoko12 likes this.
  15. Sep 5, 2019 at 8:11 AM
    #4635
    Discount Tire
    Discount Tire [OP] Tire & Wheel Specialists Vendor
    Arizona, USA
    JCWages, glad to hear your local America's tire did the right thing and took good care of you with your damaged tire.
    We appreciate your support.
    JCWages likes this.
  16. Sep 16, 2019 at 8:41 AM
    #4636
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I replaced a set of Yokohama Geolandar AT's with Wildeak AT3's. The Yokohamas were 275/70R16, I went back to stock 265/70R6 with the Wildpeaks. The Falkens look great and handle smoothly and quietly on pavement, wet or dry. Good on dirt/gravel roads. No plans for heavy duty mudding or rocks.
    Wheeled and dealed with my regular Discount Tire shop and drove off with four tires with certs for $644.
    If their durability is as their good as their looks and performance, they are great truck tires.
    Simon's Mom likes this.
  17. Sep 17, 2019 at 12:25 AM
    #4637
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    ABEE7E94-9277-4615-96D8-FF29BD0EB557.jpg 9B7CDA0D-6929-4A2C-8CF1-224F330CDE49.jpg
    With or without logo
  18. Sep 17, 2019 at 9:04 AM
    #4638
    Discount Tire
    Arizona, USA
    Looks good, let us know how they do for you. Thank you for your support.
    Good looking tire and wheel combination no matter which way you run them. We appreciate your business.
  19. Sep 20, 2019 at 5:53 PM
    #4639
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I love mine. Discount Tire helped me out last year and I made my choice. 275/65/18 on 0 offset, Addict 2 wheels. Two inch lift coming next weekend.
    Mitch09 likes this.
  20. Sep 21, 2019 at 8:05 AM
    #4640
    Discount Tire
    Arizona, USA
    Invid, thank you for posting the excellent photos. Your truck looks awesome, good choice.
    We appreciate your giving us a shout out. :thumbsup:
