Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Sep 27, 2019 at 7:53 AM
    #4661
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    It seems like Blizzaks were my go-to forever in winter until I finally picked up the Toyo. They were pretty new at the time but I liked the tread pattern and save some bucks. Can’t say they are any better or worse than Blizzak to be honest. Sometimes I get the feeling Blizzak are like Kleenex, people use the term to refer to winter tires...lol
    Navigator1[QUOTED] likes this.
  2. Sep 29, 2019 at 11:24 AM
    #4662
    JRadical
    JRadical Member
    I just bought a Tacoma with an OME 3” lift and 285/65r18 E Load KO2 @ 58lbs. I’ve done a lot of research and I’ve narrowed in on the Wildpeaks to replace my ko2’s as E Load tires are overkill for these trucks, and the off-road/snow capabilities combined with on-road manners seem like a good fit. I don’t really want to trim or regear so I’m torn between the 275/70r17 C Load @57 lbs and the larger but lighter p285/70r17 @50.5 lbs. Thoughts?
  3. Sep 29, 2019 at 1:05 PM
    #4663
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    Falken has some nice lightweight sizes in an 18 if you already have that size wheel. What wheels are you running and what are you planning to switch to?
  4. Sep 29, 2019 at 1:17 PM
    #4664
    JRadical
    JRadical Member
    Yeah I thought about that too. I have KMC XD 795 18x9” -12 offset wheels. I’m not a huge fan of the “deep lip” look and I feel a bit nervous about putting a 10.5” wide tire on a 9” rim.
  5. Sep 29, 2019 at 4:17 PM
    #4665
    JCWages
    JCWages Well-Known Member
    Grass Valley, CA
    2018 GMC Canyon SLE 4x4
    King 2.5 coilovers, 33s, steel bumpers and stuff.
    The LT275/70/17 will be more durable and have deeper tread. However, you lose the silica compound the P-metric version has which is better for on road traction, especially in wet conditions and packed snow. So the real question is, where do you plan on driving the truck? If you answer a lot of off-roading then go with the 275. If mainly street in areas with snow and or rain then 285.
  6. Sep 29, 2019 at 6:29 PM
    #4666
    Hairy Taco
    North of Hell
    08 TRD
    I did not realize the tread compound in the LT was different than the SL. Thanks for bringing that. Do all of the LT sizes still have a winter rating?
  7. Sep 29, 2019 at 6:42 PM
    #4667
    JCWages
    Grass Valley, CA
    I believe all of the LT sizes are still 3 peak severe snow rated. I have not run the LTs in real snow yet but on wet pavement they seem to have a little less grip than the P-metric I had in the same size. They P-metrics did great in snow last winter. Tread depth is shallower than the LTs and both versions have about 1/32 less depth than advertised.
  8. Sep 29, 2019 at 8:21 PM
    #4668
    Hairy Taco
    North of Hell
    08 TRD
    I have been running the the P285 70r17 for a few years. I have been really happy with them. Been considering the LT255 80r17. I hesitate mainly because they are a load E tire
    JCWages[QUOTED] likes this.
  9. Sep 29, 2019 at 8:25 PM
    #4669
    bzzr2
    bzzr2 Well-Known Member
    They will likely ride even better! less squishy on corners, i found my falkens soft feeling. this whole E rating hesitation that this forum has is silly. get the ones you want and love them for what they are. i much prefer the ride with my e rated toyo's. of course ride is an individual thing.
  10. Sep 29, 2019 at 8:32 PM
    #4670
    Hairy Taco
    North of Hell
    08 TRD
    I can see how the stiffer sidewall would improve cornering. I imagine the narrower tire would improve handling in the rain and snow conditions as well. The roads up here are worst, they are seriously broken from the freeze-thaw effect of our seasons. This is where the stiff sidewalks become an issue, if I lived in a warmer climate or in the US where the roads are built properly I wouldn’t hesitate. But, yeah I hear ya. I a couple likely gonna go the 255 route on my next set
  11. Sep 29, 2019 at 9:13 PM
    #4671
    bzzr2
    I run my Toyo MT 255’s in northern and Eastern Ontario winter with our shit roads. My opinion is they ride firmer than my SL rated wild peaks did, but not rough at all. The tire pressue will end up a bit lower for good wear almost negating any negative impact!
    Hairy Taco likes this.
  12. Sep 30, 2019 at 1:11 AM
    #4672
    Navigator1
    Spokane WA
    18 TRDORDCLBCEMENT
    I think the e rating rough ride is somewhat overplayed as a sidewall stiffness. Proper air pressure can help with that to an extent. One thing that isn’t usually discussed in reference to ride is the extra weight of an E. That extra weight takes more effort and time for our suspension to “soften” so more of it translated into the spring portion of the truck. Some e rated tires are 10-15+ lbs heavier than a similar size SL. That’s a lot for a suspension to counteract when you hit abrupt terrain changes.
    People talk about weight a lot but it’s usually in reference to performance or mpg.
  13. Sep 30, 2019 at 6:50 AM
    #4673
    Hairy Taco
    North of Hell
    08 TRD
    interesting point. The E rated 255 are only listed as 2lbs heavier than the SL 285 if I remember correctly.
  14. Sep 30, 2019 at 7:07 AM
    #4674
    JCWages
    Grass Valley, CA
    That is correct although the E load 285 weighs 9lbs more than the P-metric 285.
    Ride-wise there isn't a huge difference between them. Impacts with potholes and such are a bit sharper and I can definitely feel the weight when suspension drops. That's probably my only real concern is the need for more rebound damping in the shocks.
    Navigator1 likes this.
  15. Sep 30, 2019 at 7:23 AM
    #4675
    Hairy Taco
    North of Hell
    08 TRD
    Agreed. I noticed these changes when I stepped up into a 50lb 33" tire from the lighter 31-32" tire.
  16. Sep 30, 2019 at 7:28 AM
    #4676
    JCWages
    Grass Valley, CA
    That's why I wish I could try a 255/80/17. Less weight and I keep my ground clearance. But then I might miss how the truck floats on snow and the off camber stability when aired down that I get with 285s. *sigh* always tradeoffs. lol
    Hairy Taco[QUOTED] likes this.
  17. Sep 30, 2019 at 7:52 AM
    #4677
    Hairy Taco
    North of Hell
    08 TRD
    you prefer staying on top of the snow as opposed to cutting through it?
  18. Sep 30, 2019 at 8:04 AM
    #4678
    JCWages
    Grass Valley, CA
    Offroad yes, onroad no. Deep snow is different than shallow snow. When I'm in deep snow I want to float on top otherwise I'll catch my suspension and or chassis on snow and get stuck. We see this a lot when snow wheeling with heavy rigs that cut through too far and need to be winched free. :)
    I snow wheel, a lot. Get stuck a lot too. lol
    https://youtu.be/aFRf9QjBcdg
  19. Sep 30, 2019 at 1:06 PM
    #4679
    Navigator1
    Spokane WA
    18 TRDORDCLBCEMENT
    I did some snow wheeling last year. It’s amazing how fast you can lose a traction board in the deep.
  20. Sep 30, 2019 at 5:41 PM
    #4680
    JCWages
    Grass Valley, CA
    We lost 2 in that recovery! It was around midnight before got out and it had been storming for hours and we feared we might not make it back to pavement 7 miles away. So we said screw looking for the boards. Nothing quite like having your GMC rescued by Toyotas. :help::frusty: Thankfully they all got stuck too. LOL
