Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Sep 5, 2016 at 4:21 PM
    #521
    CaptNoPants
    CaptNoPants Well-Known Member
    Toyota Tacoma 2015 PreRunner
    Stock
    Thanks for your input guys, I'm thinking I've got a couple things going. The TPMS sensors where purchased on the same day from the installer, these where the 20* ones because my stock ones from the steel rim did not fit. From what I'm reading the ones one are either malfunctioning or aren't reading the proper psi. Now I still have my stock steel rim and tire under the bed, with the stock sensor. Not sure if they are not communicating properly with the new ones. I'm still heading back this week to see what's up. I didn't just shell out $40 a piece for 4 sensors.
  2. Sep 5, 2016 at 5:42 PM
    #522
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I did the chalk test, 33 psi in the front, 31 psi in the rear.
  3. Sep 5, 2016 at 8:08 PM
    #523
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    These tires do look great and are getting good reviews for ride quality. Here's a pic of them I saw on another taco.
    My only concern is that they seem to wear fast according to other reviews I've read. I'm still on the fence of whether to get them or not.
  4. Sep 5, 2016 at 9:20 PM
    #524
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    They do have a 55k mileage warranty so I'm not worried about wear. If they don't make the 55k then I'll just warranty them. I think mine have about 15/32 after 6k of use (17/32 new).
  5. Sep 6, 2016 at 6:06 AM
    #525
    Paul-P
    Paul-P Member
    San Diego
    2014 White Tacoma DoubleCab TRD Offroad 2WD
    17x9 Wheels & 285/70-17 tires, Bilstein 5100s, Wheelers Off Road 3/8inch polyurethane taco lean spacer, Westin Bed mat
  6. Sep 6, 2016 at 9:44 AM
    #526
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    So I got a question for you guys who are running these tires.
    So I've had the tires on the truck now for 3,067 miles and thus just started the other day. They are P265 75 16's Odd wearing on the tread on the front tires. My alignment is perfect, truck drives straight as a arrow. I have a 3" Lift with light racing upper control arms and my alignment specs are set at, camber 0, toe 0, and caster 3 degrees. Been running 36 psi in all 4 tires. You can see how the center tread is like work in the groves of the front vs the rear.... Any ideas?!?!
    Drivers front tire:
    Passenger front tire:
    Drivers rear tire:
    Passenger rear tire:
  7. Sep 6, 2016 at 10:02 AM
    #527
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Lt. or p rated? My guess would be to high of pressure. But that's just a guess.
    canyonchaser likes this.
  8. Sep 6, 2016 at 10:09 AM
    #528
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The edges are rounding over just a bit, likely from cornering. Once they get rotated I bet the rears (then will be the fronts) will do the same. The new silica compound a lot of tires are starting to use is softer and doesn't hold the edge as crisply as the old rubber.
  9. Sep 6, 2016 at 2:37 PM
    #529
    matadorCE
    matadorCE Well-Known Member
    Melbourne, FL
    '05 Prerunner Accesscab TRD Offroad
    Maybe you need some camber since perhaps the tire is rolling on the outer edge too much when cornering.
  10. Sep 6, 2016 at 3:29 PM
    #530
    moe2o4
    Corey
    Pittsburgh PA
    They are P rated.
    That's what i was thinking. That silica compound is completely different that normal tire rubber.
  11. Sep 6, 2016 at 6:38 PM
    #531
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    30 days after buying the tires. For at least the Falken $100 rebate, you'll have to provide your tread lightly confirmation letter and original tire receipt. So they're looking to make sure you were a tread lightly member ahead of purchase. The discount one doesn't verify it.
    Both are prepaid cards.
    Discount promotion can be mailed in or filled out online (with the appropriate offer code which you have to call in to get)
    Falken is mail-in only.
    DrFunker and BeaverYota[QUOTED] like this.
  12. Sep 7, 2016 at 11:10 AM
    #532
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    Ordered a set of P265/75R16 yesterday. Will post pictures once I get them mounted!
    axisofoil and Soul Surfer like this.
  13. Sep 7, 2016 at 12:17 PM
    #533
    axisofoil
    Gilbert, AZ
    Me too! Except... Mine will be mounted tonight. Woooooooo
    winguyen[QUOTED] and Soul Surfer like this.
  14. Sep 7, 2016 at 12:47 PM
    #534
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    image.jpgTo replace my coopers that I can't get to drive straight.
    DrFunker and Soul Surfer like this.
  15. Sep 7, 2016 at 1:33 PM
    #535
    DrFunker
    DrFunker Well-Known Member
    What size did you go with?
  16. Sep 7, 2016 at 1:59 PM
    #536
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    265/70-17. I am getting my 255/80-17 coppers exchanged for new ones. I will get them mounted this weekend.
    DrFunker[QUOTED] likes this.
  17. Sep 7, 2016 at 2:59 PM
    #537
    bulldog
    SW MO
    2023 Pro
    I ended up w 33 psi hot in front and 31 psi hot rear. I had those pressures cold but they went up 4-5 psi hot and it rode bouncy. I suspect they will be really low cold. I did the chalk test but don't think it was accurate. Anybody else running 265/70 16 and if so what pressures are you running?
  18. Sep 7, 2016 at 3:04 PM
    #538
    moe2o4
    Corey
    Pittsburgh PA
    So anyone else having these issues?
  19. Sep 7, 2016 at 3:18 PM
    #539
    gugman
    gugman analog
    bob
    Vermont
    anyone run these in snow yet?
  20. Sep 7, 2016 at 3:45 PM
    #540
    NordidiroN
    NordidiroN Well-Known Member
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Retrax MX Pro bedcover, Avid bumper gaurd, Predator step rails, Aux D rings, Door sill protectors
    Not to get too sidetracked here, but what Coopers did you have and what exactly was the issue?
