Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Sep 27, 2016 at 10:38 AM
    #621
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
  2. Sep 27, 2016 at 12:25 PM
    #622
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Soooo... assuming I read that right... Wear them down to 2/32nds and claim the warranty!
    Make sure to have them rotated and milage documented.
    I've never had to claim a tread warranty on anything but it looks pretty straight forward...only part of it that looks sketchy it the part that says "normal highway use." Doesn't make sense that they can deny a warranty for a All Terrain tire used off-road?? :confused:
    I'm no lawyer tho :anonymous:
  3. Sep 27, 2016 at 12:30 PM
    #623
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    It recommends rotation at least every 5000 miles documented. I'll be religious about it now that I know they could be subject to premature wear. But it's still just a bummer if the tires only last for 1/2 the recommended life cycle and hopefully you don't get the run around when trying to make a claim.
  4. Sep 27, 2016 at 12:40 PM
    #624
    Midnighttaco08
    Sam
    Gilbert, AZ
    I'd be pissed if they gave the run around when trying to put in a claim.
    Especially if they give the run around for "normal" use of an all terrain.
    TRDPro4x4[QUOTED] likes this.
  5. Sep 27, 2016 at 2:46 PM
    #625
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I won't run a tire at 2/32's in the winter. 1/4" is my minimum. So I would never get to the point where I would make a claim.
  6. Sep 27, 2016 at 4:16 PM
    #626
    Midnighttaco08
    Sam
    Gilbert, AZ
    If this is your winter tire, you must have VERY mild winters...
    I don't think this would be my choice for winter driving at all... no way this is aggressive enough, even for California mountains...
  7. Sep 28, 2016 at 5:18 AM
    #627
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Does anyone have this tire in 265/70/17 in the E load rating? As I understand it they are slightly taller and have deeper tread than the 6ply one.
  8. Sep 28, 2016 at 6:41 AM
    #628
    CrimsonCountry
    CrimsonCountry Well-Known Member
    Huntsville, AL
    2006 4Runner (4.0) Sport Edition
    (F) LR UCA + DR/Icon 2.5" Ext Travel (R) 5100/SAW+DS 1.5" Driver only | 285/70/17 Toyo AT II| Level 8 Guardians
    Usual excuse, been swamped at work but will try to snap/upload a few pictures tonight. They look sooo gurddd. IMO, these aggressive AT styles, especially with the protruding sidewall, look better than MTs given how much more tread there is to "fill out" and square off the tire's profile (except for the Toyo MTs, my favorite tire in looks the department).
    This is something I failed to mention during my initial post and was in the back of my mind after reading other comments here. Having said that, I can't say I feel any kind of softness/over-compliance when driving as my AT II were no softer. If anything, these feel more surefooted while driving but maybe its the extra weight (granted only ~2.5lbs per tire). I was not very good about rotating/re-balancing my AT IIs and they ended up lasting 57k miles and still have a good 4-5/32" tread left (why did I switch?? Ha). I'll make a point to do so with these but it will be more of a chore given that the DT I had to purchase these from is a good drive from my house, and the rotations must be documented with a receipt I assume. Time will tell...
  9. Sep 28, 2016 at 7:15 AM
    #629
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    They are definitely sure footed. They grip up and hookup.
  10. Sep 28, 2016 at 7:40 AM
    #630
    CrimsonCountry
    Huntsville, AL
    I could feel them grabbing and pulling hard as I was turning, fully cranked, out of my driveway this morning. My AT IIs didn't do that either. I am hoping newfangled rubber defies the norm for a wet-weather, grippy tire and last the full 55k (crosses fingers, arms and legs). I think we'll all be using the warranty if not.
    Forgot to ask, what PSI is everyone running (Size and LT/P)?
    Granted I'm in a 4unner so weight distribution is little more than the Tacos (equal PSI front to rear) but I'm at 34.5-35 PSI all-around for my P285/70/17s. It feels great and turns/rolls well which makes me think its maybe a little high-centered, too much PSI?? I tried running them at ~33 PSI last night and didn't feel as good to me. Yet to do the chalk test.
  11. Sep 28, 2016 at 1:16 PM
    #631
    NinjaJuan
    NinjaJuan Well-Known Member
    Seattle, WA
    '04 4Runner | NWTI Bumper | Kings | Cooper STT Pro 315/70R17
    P266/70R17. '04 V8 4Runner. Currently running 35 front, ~32.5 rear
    I need to do a chalk test on mine as well. I like how it feels at 34-35 PSI in the front, but need to do a chalk test before running it long term.
  12. Sep 28, 2016 at 4:38 PM
    #632
    3GTaco
    3GTaco Well-Known Member
    2016 TRD Sport AC MGM
    P265/70R17 set at 29psi cold. They typically warmup to 31psi per the TPMS.
  13. Sep 28, 2016 at 4:53 PM
    #633
    Hairy Taco
    North of Hell
    08 TRD
    P285 70r17. 34psi on all 4
  14. Sep 29, 2016 at 7:25 AM
    #634
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    Note that MPG measurements with larger tires using the truck instruments are probably meaningless. I understand that the speedometer/odometer records data from a wheel sensor. With larger tires installed, the wheel/tire will travel farther with each revolution, but the truck doesn’t know that. This means the distance traveled will be underestimated. At the same time, it will take more power to move the truck since the larger tire will act like a higher gear ratio. The net result will almost certainly be a decrease in recorded gas mileage. The only accurate measurement would be to use a GPS based distance recorder or to drive on an interstate and record the distance from the mile markers, not the odometer.
  15. Sep 29, 2016 at 10:30 AM
    #635
    CrimsonCountry
    Huntsville, AL
    True. Or, you could just do it the quick-and-dirty way by multiplying the mileage by 1.07 (as my 33s are 7% larger in diameter than the factory spec 265/65s) or 1+whatever your % increase is.
    ready6delta likes this.
  16. Sep 29, 2016 at 11:06 AM
    #636
    Hairy Taco
    North of Hell
    08 TRD
    ...quick and dirty FTW
  17. Sep 29, 2016 at 12:56 PM
    #637
    MGB
    You are right; simpler is better...
  18. Sep 30, 2016 at 6:07 PM
    #638
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Ordered 4 - P265/75/16's Today. :bikewheelie2:
  19. Oct 1, 2016 at 2:25 AM
    #639
    DrFunker
    DrFunker Well-Known Member
    :yes:
    Soul Surfer[QUOTED] likes this.
  20. Oct 1, 2016 at 3:04 AM
    #640
    Soul Surfer
    Jimi
    Good Morning Doc!
    DrFunker[QUOTED] likes this.
