Packed with Technology | Falken Wildpeak A/T3W
Discussion in 'Wheels & Tires' started by Discount Tire, Mar 3, 2016.
  1. Jun 23, 2017 at 4:23 PM
    #1861
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    They're colored dots on the tires that are supposed help the installers. Go look at the dots, yellow should be close to the valve stem.
    ChadsPride and lynyrd3 like this.
  2. Jun 23, 2017 at 5:53 PM
    #1862
    bry418
    bry418 Member
    Bryan
    2003 Tacoma DoubleCab TRD 4x4
    On 3 of the 4, the yellow dot is where the valve stem is. The 4th one is a little off.
    ChadsPride likes this.
  3. Jun 23, 2017 at 5:55 PM
    #1863
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    I purchased the Certificates for mine. What Wheel are you running?
  4. Jun 23, 2017 at 7:12 PM
    #1864
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Did you have them road forced balanced?
  5. Jun 23, 2017 at 7:26 PM
    #1865
    bry418
    bry418 Member
    Bryan
    Stock Toyota alloys
  6. Jun 23, 2017 at 7:28 PM
    #1866
    bry418
    bry418 Member
    Bryan
    I don't think this tire place did the road force balancing.
    But should that matter since the beads are in the tires? Isn't that supposed to balance everything out?
  7. Jun 23, 2017 at 7:30 PM
    #1867
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I know nothing about the beads. Never even heard of it.
  8. Jun 23, 2017 at 8:29 PM
    #1868
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    The red dot is supposed to be in the valve stem.
  9. Jun 24, 2017 at 3:39 AM
    #1869
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    That's not what my tire guy said. Yellow is lightest stop and should be stem placement and red is high part of the tire. These are just starting points for the installers.
    Clay7160 and ChadsPride like this.
  10. Jun 24, 2017 at 5:49 AM
    #1870
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Your tire guy is incorrect according to what I've read and heard from others. Yellow is the light spot, but red is the high point. You use yellow unless there is also a red dot in which case you use red.
    "If there is red, use it instead"
  11. Jun 24, 2017 at 6:25 AM
    #1871
    lynyrd3
    Bill
    East Central Upstate NY
    Red dot lines up with valve stem on my Wildpeaks.
  12. Jun 24, 2017 at 6:33 AM
    #1872
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Maybe I understood him wrong. Thanks for the correction.
  13. Jun 24, 2017 at 6:36 PM
    #1873
    bry418
    bry418 Member
    Bryan
    Guess I'll have to get them balanced again with the red dot where the valve stem is and see what happens
  14. Jun 24, 2017 at 9:36 PM
    #1874
    L3TT3RS
    L3TT3RS Well-Known Member
    Taylor
    Longview, Texas
    2019 Tundra-> Fox/Total Chaos/Coachbuilder
    Make sure and update us
  15. Jun 25, 2017 at 6:04 AM
    #1875
    Scooby24
    Greg
    2017 DCSB OR 4X4
    As mentioned it's really just a starting point. Your best bet is to get them road force balanced as it will make recommendations on spinning the tire on the wheel, if it's necessary.
  16. Jun 25, 2017 at 8:18 AM
    #1876
    bry418
    bry418 Member
    Bryan
    Going in Monday to get an alignment done. Will have to ask if they road force balance. Will keep you guys updated.
    lynyrd3 and ChadsPride like this.
  17. Jun 26, 2017 at 4:10 PM
    #1877
    JIN
    JIN Well-Known Member
    Jin
    Olympia, WA
    2017 Super White TRD Sport 4x4 DCSB
    Just ordered these in 265/70/17 SL. Anyone with this size? Just wondering how much of a hit in mpg I can expect and if there was any rubbing on stock suspension.
  18. Jun 26, 2017 at 5:56 PM
    #1878
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    There going to rub like crazy. I had to remove my mud flaps and trim my fender flares at the bottom. Mpg's didn't change much.
  19. Jun 26, 2017 at 7:35 PM
    #1879
    JIN
    Jin
    Olympia, WA
    Was more wondering for the 3rd gens. They sit a little higher than the 2nd gens and no one seems to be having rubbing issues with other brand tires of tr same size.
  20. Jun 26, 2017 at 7:40 PM
    #1880
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I have the 3rd Gen sport suspension on my truck with a 1/2 spacer up front. It would be very close without the spacer. I don't know if there is more space in the wheel wells on 3rd gens.
