Paden's Truck
Discussion in '2nd Gen. Builds (2005-2015)' started by BMOC, Jun 20, 2011.
  1. Sep 7, 2012 at 4:57 PM
    #701
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Would be better if you put the f67 or better yet the f55s on your truck and left the spindles on.
  2. Sep 7, 2012 at 5:06 PM
    #702
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    been there, done that
    spindles + F55
    spindles + F67
  3. Sep 7, 2012 at 5:17 PM
    #703
    05TacoRunner
    Peoria, Az
    Sick bro. Now that is how you DGAF
  4. Sep 8, 2012 at 11:27 AM
    #704
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Where's the boost man?!?!?! ;)
    J/k. Seriously though. Given me some ideas. :spy:
  5. Sep 8, 2012 at 1:11 PM
    #705
    BMOC
    BMOC [OP] Well-Known Member
    Paden
    Phoenix, AZ
    I would love some more power, lol! gears and a S/C are definitely on my list
  6. Sep 8, 2012 at 1:16 PM
    #706
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Any bump stops lol
  7. Sep 8, 2012 at 1:20 PM
    #707
    BMOC
    Paden
    Phoenix, AZ
    fuck that noise. j/k. I wanted to hold off on bumps til I got an engine cage so I could bump off the UCA bolt, but camburgs kit doesn't have one.. might just have to settle with an LCA bump
  8. Sep 8, 2012 at 1:24 PM
    #708
    08pretaco
    az
    I just called SDHQ and Ryan said I have to remove the factory bumps in order to run secondaries...why did everyone in the LTBS say you dont have too??? I will call Burg on Monday to see whats up.
    Who are you going to have cage the engine for you?
  9. Sep 8, 2012 at 1:29 PM
    #709
    BMOC
    Paden
    Phoenix, AZ
    I think they'll fit man, if people are running stock bumps with secondaries, no reason yours shouldn't.
  10. Sep 8, 2012 at 1:45 PM
    #710
    05TacoRunner
    Peoria, Az
    I am still running my factory bump stops with secondaries. Maybe camburg is different? I don't see why you shouldn't be able to.
  11. Sep 8, 2012 at 3:45 PM
    #711
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    how are f67s on a 2nd gen ?
  12. Sep 8, 2012 at 4:40 PM
    #712
    BMOC
    Paden
    Phoenix, AZ
    sick low ride height, but not enough up travel or load capacity.
    wouldn't recommend them unless you're mall crawlin
  13. Sep 9, 2012 at 9:18 AM
    #713
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Paden are you going to change rear springs?
  14. Sep 9, 2012 at 9:28 AM
    #714
    BMOC
    Paden
    Phoenix, AZ
    yeah, im going to see what I can make work with my current mounts.. these are starting to sag and ride bump stops with any load..lol
  15. Sep 9, 2012 at 9:29 AM
    #715
    PLC721
    Patrick
    Chandler, Az
    How about just rebuilding the pack like cliffs truck? Or go Baller status with some 50T's
  16. Sep 9, 2012 at 9:35 AM
    #716
    BMOC
    Paden
    Phoenix, AZ
    i thought he just had the standard defined kit?
    50t's would be sweet, i wonder if they would mount up properly to my hanger and shackles though.. they're on sale right now, hmm.
  17. Sep 9, 2012 at 9:36 AM
    #717
    PLC721
    Patrick
    Chandler, Az
    Yeah but he had some leafs added to the pack. But also he carries a lot of weight
  18. Sep 9, 2012 at 9:37 AM
    #718
    BMOC
    Paden
    Phoenix, AZ
    oh gotcha, i'll try that first.
  19. Sep 9, 2012 at 9:43 AM
    #719
    PLC721
    Patrick
    Chandler, Az
    i vote you just link the rear....
  20. Sep 9, 2012 at 9:54 AM
    #720
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Matt (nelson18matt) switched out to 50T from F67's as well as a few other members, mind you they are 1st Gens the measurements are the same at 52.5" they bolt right up. :cool:
