Padlocks for ROAM Case and Rugged Mounts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N3FOLMike, Nov 12, 2022.
  1. Nov 12, 2022 at 8:29 AM
    N3FOLMike
    N3FOLMike [OP] Well-Known Member
    2021 Tacoma TRD OffRoad
    What have you guys been using (padlocks) to secure and lock your ROAM case that will stand the test of time in all weather long term? I have a 95L and rugged mounts to install.
  2. Nov 12, 2022 at 8:32 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Nothing fancy MasterLock’s. Give them an occasional squirt of lub. You can get sets so they are all keyed alike.
    N3FOLMike[OP] likes this.
  3. Nov 12, 2022 at 8:41 AM
    N3FOLMike
    That is exactly what I have in mind. Just need to find the correct size padlock. If I can find all black locks is a plus. Thank You. A trip to HDepot is imminent.
  4. Nov 12, 2022 at 8:54 AM
    Glueboy
    Glueboy Well-Known Member
    2019 Cement TRD OffRoad DCSB
    I’m not sure about the size requirements for your application, but I would go for something made for the maritime use, like a brass ABUS lock.
  5. Nov 12, 2022 at 9:12 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    If you like , abloy locks are great but expensive. It’s almost impossible to pick. They would likely cut open the case than try to pick the lock
  6. Nov 12, 2022 at 4:13 PM
    N3FOLMike
    I will check into Abloy locks. Sounds good quality. As long as the locks do not rust as I will try to keep lubing as much as I can, I think it is good money spent. Thanks for your input.
    bulalo[QUOTED] likes this.
  7. Nov 12, 2022 at 6:42 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    +1
  8. Nov 12, 2022 at 7:30 PM
    N3FOLMike
    Wow! Those Abloy Locks are truly expensive for a lock. This is what you call, "You Get What You Pay For."
