Padlocks that won't corrode or jam up in dusty conditions
Discussion in 'Off-Roading & Trails' started by pinem56, Feb 19, 2022.
  1. Feb 19, 2022 at 4:56 PM
    pinem56
    pinem56 [OP] Well-Known Member
    NE
    2018 TRDOR DCSB AT
    Looking for a relatively cheap padlock to lock cases that are going to be attached to a bed rack. Needs to not jam up when exposed to dusty road conditions or corrode when left out in the elements. Would prefer a combo lock, as I have too many keys already for everything else on my rack. However, if a keyed lock is the only solution to not having to get the bolt cutters out later, I'll add another key to the keychain.
    Looking for a relatively small lock, that has a shank size in the 3/16" or 6mm size range. Doesn't have to be theft proof, just a visual deterrent of sorts.
    Reading way too many reviews on Amazon has left me more confused than when I started. It would appear anything made by Master will corrode, even their all weather locks. Abus seems to be considered a better product, but their website is completely useless for trying to determine what they make and what model number I want. Definitely not interested in any Chinese ripoff locks.
    Figured this would be the best place to ask, as it's trail use that can gum up a lock faster than anything, with all the dust, rain and ice one encounters.
  2. Feb 19, 2022 at 6:25 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Cheap and good don’t usually go together. Abloy is a good weather resistant lock.
    Key-Rei likes this.
  3. Feb 19, 2022 at 6:30 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Try marine locks from ABUS.
    Example…I bet they have smaller ones.
    https://www.amazon.com/gp/aw/d/B000XBHUJA?ref=ppx_pop_mob_b_asin_title
    Biscuits and Kabanstva like this.
  4. Feb 19, 2022 at 6:38 PM
    Kabanstva
    Kabanstva Well-Known Member
    Also recommend anything from Abus. Their German made locks are the best but won’t be cheap.
  5. Feb 19, 2022 at 6:42 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Good luck on that elusive search
    -Nevada resident
  6. Feb 19, 2022 at 7:00 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Brass one with SS or brass internals. All we use outside at work on our installations and valves. Some have been in use for decades.
  7. Feb 19, 2022 at 7:01 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Pad locks need to exercised. Just sitting there, they will jam up/freeze up. I have 3 on my work truck, two of which open and close every day. The 3rd maybe once a month. That one has more issues jamming up than the other two that get used daily. Does not matter the weather or conditions. Frequent use will keep them in working order.
  8. Feb 19, 2022 at 7:17 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Use Boeing Boe-Sheild T-9 on your locks. It's a deep penetrating dry lubricant that won't attract dust but keeps everything moving freely.
    Was originally developed for the landing rams on carrier based aircraft but ai found it to be my go to lube for all kinds of things like suspension uniballs/heims and locks.
    I had a door lock that was so stiff it fel like you would snap the key off locking it sprayed a little T-9 in it and ran the key in and out and two days later you could stick the key in the lock and it would just fall open it was so free.
    Works great in padlocks left out in the weather.
  9. Feb 19, 2022 at 7:30 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Exactly right, Same as the U.S. Forest Service has used for Many Years. They use Brass Locks.
  10. Feb 19, 2022 at 7:35 PM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Master lock and a can of WD40
  11. Feb 19, 2022 at 7:44 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    WD-40 attracts dirt.
    Key-Rei and wilcam47 like this.
  12. Feb 20, 2022 at 10:24 AM
    Kabanstva
    So does Fluid Film and any other wet coating. What’s your point?
  13. Feb 20, 2022 at 10:30 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  14. Feb 20, 2022 at 10:34 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Put a ziploc bag over the lock with rubber band
    Sharpish likes this.
  15. Feb 20, 2022 at 12:26 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    The OP said he was going to be in Dusty Conditions.
  16. Feb 20, 2022 at 12:58 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Keep in mind the following.....Good-Fast-Cheap. Choose 2, the third is excluded.
    3/16" shank......isn't much of a theft deterrent. Might be just as well off using a 3/16" grade 8 bolt with tamper resistant features.
