Pads and Rotors poll
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 27, 2011.
  1. Sep 27, 2011 at 4:14 PM
    george3
    george3 [OP] Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I don't know how to make a poll - maybe someone can put a poll thing on top of this post. I would like to find out if there is a consensus on TW on what are the best pads and rotors for our trucks. I've had problems with ABS putting me in the middle of the intersection instead of stopping at the stop sign and my front wheels shake a little when I apply the brakes. Piercedtiger just had pads and rotors put on his truck from Monroe and it solved his ABS problem that he has had from the get go - so they are obviously superior to OEM.
  2. Sep 27, 2011 at 4:17 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I tried to make a poll once and couldnt figure it out, once somene here posted I was able to. So here you go, go make your poll. :D
  3. Sep 27, 2011 at 4:29 PM
    george3
    new jersey
    tacoma
    Thanks. I was hoping someone else could do it. I'm really only interested in the bottom line - What are the best Pans and Rotors for our truck.
  4. Sep 27, 2011 at 4:30 PM
    saugus
    saugus Well-Known Member
    (check here) "Yes, post a poll with this thread"
  5. Sep 27, 2011 at 4:31 PM
    george3
    new jersey
    tacoma
    Just a little rain will do it. I almost ran into my garage door at no mph once. Piercedtiger had trouble in a parking lot at no mph.
  6. Sep 27, 2011 at 4:33 PM
    george3
    new jersey
    tacoma
    Thanks. Where's that at ?
  7. Sep 27, 2011 at 4:36 PM
    saugus
    The poll check box is in the beginning of the new thread page. You will have to start over. Although some forums allow inserting polls in the middle of a thread. I think a mod can do it if he wants to.
    I would like to know what the equivelant quality aftermarket rotor is that can replace a worn out oem one. I am looking to buy a couple centrics but worry they may be crap.:p
  8. Sep 27, 2011 at 4:39 PM
    J C
    J C Member
    Central Florida
    2011 Tacoma TRD Off Road 4X2
    Nerf Bars Window deflectors
    Hawk pads for the win...
    Drilled and slotted rotors look pretty but do nothing for stopping power...
  9. Sep 27, 2011 at 4:51 PM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Slotted Rotors (I used ATE on my last change) dissipate heat quickest and may be better for use in our trucks. Brembo makes an excellent and affordable rotor with akebono ceramic disc. Suggest anyone changing their rotors and brakes go with stainless steel lines as well. Go to tirerack to price some of their rotors and break pads. I guess I can cite them since they seem to have some of the best prices. When buying a rotor make sure you get a hard steel rotor.
  10. Sep 27, 2011 at 4:53 PM
    george3
    new jersey
    tacoma
    Thanks. I've heard or read the Hawk LT are good and the drilled and slotted rotors just wear the pads out faster. Is that your feeling ?
  11. Sep 27, 2011 at 4:56 PM
    george3
    new jersey
    tacoma
    Thanks. How do you know it's a hard steel rotor vs what ?
  12. Sep 27, 2011 at 4:56 PM
    saugus
    Thanks, what exactly is the reason for the steel brake lines? Is it because mine will wear out soon anyway or because they will save me when I slam on the brakes?
  13. Sep 27, 2011 at 5:09 PM
    george3
    new jersey
    tacoma
    I'm sure others will chime in but it's my understanding that it gives you a harder peddle. The rubber lines expand when you put the brakes on and give you a softer or mushy peddle. We have a member that sells them on a group buy. If interested I'll look for the the link for you.
  14. Sep 27, 2011 at 5:10 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    He lives in NJ.... The do occasionally get snow. ;)
  15. Sep 27, 2011 at 5:12 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Snow, ice, sand, gravel.... Didn't really matter. Anything other that dry asphalt.
    Shit, it even kicked in going down a city street during the summer due to the pot holes, and manhole covers. Had to brake long before those the slow for the left turn. I don't take that road anymore.
  16. Sep 27, 2011 at 5:12 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    If you haven't already adjust your rear brakes. I did mine about 2 weeks ago and now my truck stops on a dime.
  17. Sep 27, 2011 at 5:19 PM
    george3
    new jersey
    tacoma
    Tell me about that. I thought they were supposed to adjust themselves when you back up and stop and you can force the issue by backing up fast and jamming on the brake. Am I all wrong ?
  18. Sep 27, 2011 at 5:21 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I know I had mine done to pass inspection as the parking brake cable was seized. Didn't make a difference. ABS was still useless on snow and loose terrain. This is about the only reason I would looking forward to winter: see how the new brakes work. :rolleyes:
  19. Sep 27, 2011 at 5:22 PM
    S.B.
    Sean
    That is what is supposed to happen, but the auto-adjusters have never worked for me or my dad and any vehicles we have worked on or driven.
  20. Sep 27, 2011 at 5:22 PM
    S.B.
    Sean
    Ya the ABS does suck on snow/ice.
