Paint 2013 Tacoma stock rims
Discussion in 'Wheels & Tires' started by Annolino122, Apr 3, 2013.
  1. Apr 3, 2013 at 8:30 AM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    So I finally took the time to paint my rims.
    The process I followed was:
    1.) dismount
    2.) wash
    3.) sand
    4.) wash
    5.) mask with cards
    6.) prime
    7.) paint
    8.) remount
    9.) repeat
    I used 100 grit all purpose sandpaper (about 3 to 4 sheets), 2 cans of rustoleum clean metal primer, and 2 cans of black rustoleum engine enamel.
    If you have any questions or compliments let me know!
  2. Apr 3, 2013 at 8:34 AM
    Large
    Large Red
    Looks pretty good, got any close up pics?
  3. Apr 3, 2013 at 8:36 AM
    Annolino122
    Evansville
    Those are the only pictures i have right now, but i can take some and post them later today.
  4. Apr 3, 2013 at 8:37 AM
    Large
    Large Red
    Hmm, ever think of leaving them white? I would be curious to see what they would look like..
  5. Apr 3, 2013 at 11:40 AM
    Annolino122
    Evansville
    Here a close up
  6. Apr 3, 2013 at 11:43 AM
    Annolino122
    Evansville
    I did too... Truthfully I considered that after the first tire
    Googled it an it looks pretty nice. Which is why when I buy rims and tires I will get black rims with a white beadlock outline or some white and lack combo
  7. Jun 29, 2013 at 2:20 PM
    manufacturedtrash
    manufacturedtrash Member
    Gregg
    Dyersburg, TN
    4X4 Silver
    Black headlights mod
    Why the cards? Do they work better than newspaper?
  8. Jun 30, 2013 at 10:45 AM
    Annolino122
    Evansville
    Once you get the pattern down they're easier to fit under the lip of the tire in my opinion, and where I live there's always a constant breeze so any paper like that was hard to manipulate
  9. Jun 30, 2013 at 10:56 AM
    tshoww
    tshoww Get It!
    Vegas
    13 TRD Sport DCLB
    Debagged Entire Truck Short Antenna White Toyota Grill Emblem
    looks good man, i'm wanting to plasti my trd rims black just haven't found any time lately.
  10. Jun 30, 2013 at 12:12 PM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    I used the same exact process on my LC wheels.
    The raised white letters look so good on a dark centered wheel. It is old school thinking in my mind. My uncle told me to only have white letters against dark centered wheels when I was 6yrs old.
  11. Jun 30, 2013 at 12:17 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    1000x better to work with. in fact OP took an unnecessary step forward (probably helped in the long run tho) and taped them down. usually you can just slip the cards into the lip between wheel n tire and you're ready to paint.
  12. Jul 1, 2013 at 7:41 AM
    Annolino122
    Evansville
    I would plasti dip them but I wanted a more permanent painting.
    About the white letters, that's why I'm doing the white beadlock, gonna be different but pretty, like a white wall
    And the tape took longer but in the long run was Moore efficient
  13. Jul 1, 2013 at 8:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Only thing I can say you should have done differently was remove the wheel weights. Once you need tires, they're going to pull the wheel weight and you'll need to sand and paint again. To do that, mark from the center of the wheel weight straight onto the tire (put a piece of tape on the tire and indicate the weight so you know which one goes where). Remove the weight, do all the prep and paint steps you listed, then reinstall weights or have the wheels re-balanced using the stick on weights on the inside of the wheel.
  14. Jul 1, 2013 at 6:08 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    What happens when you go to get your tires balanced and they remove the wheel weights? No black paint there:confused:
  15. Jul 1, 2013 at 10:00 PM
    Annolino122
    Evansville
    Well i know the DM of the local discount tire, and theyre going to mount the tire weights on the inner part of the wheel, the mount side, not the outside you see. also i get my new rims at the end of july so when i get these rims off, im actually going to get the whole wheel sandblasted and fully redo the rims, that way who ever buys them has a "custom" rim concept, and when theyre mounted and balanced wont have an issue
  16. Jul 2, 2013 at 6:08 AM
    denmen
    denmen Well-Known Member
    Dennis
    New Hampshire
    2013 4x4 V6 SR5 6-spd Spruce Mica AccCab
    Tube steps, bull bar and KC Hilites, trifold bed cover, variety of shifter knobs, comparing LED strip options, lift possibilities (prob 2 inch), and exhaust mods to tune growling on low end...
    Great read... Thanks for posting!
  17. Jul 2, 2013 at 11:09 PM
    Annolino122
    Evansville
    Thanks! and again any questions let me know
    Ill also post a picture of the truck with the new rims, the stock rims when they're done (for sale), and then the new rims with the white beadlocks
  18. Jul 30, 2013 at 4:14 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I tried to do the card trick but the Hankooks have a rim guard kind of lip around the rim and I couldn't get them to stay worth a damn, and tape didn't stick to the tire either. I think I'll give it another shot though, I like the black semi-gloss look better than the flat black I had when I derped them.
  19. Jul 30, 2013 at 9:05 PM
    Annolino122
    Evansville
    When you put them in, try an angel, where part of the card is under the lip, and part is out, then the next card fill in the gap... its a pattern.
    they essentially 100% don't fit directly under the lip, its the pattern then covers the whole tire. so like i said, partially, then use the next card to fill the gap. if that makes sense?
  20. Jul 30, 2013 at 9:06 PM
    Annolino122
    Evansville
    the new rims and tires
    when i have a day free I'm going to plastidip the silver white
