Paint chip on new truck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewGuyJosh, Dec 19, 2013.
  1. Dec 19, 2013 at 3:09 PM
    NewGuyJosh
    NewGuyJosh [OP] Well-Known Member
    So I found a small paint chip on my 2014 tacoma I've only had for 3 weeks tonight. Its on the fuel door right above where you pull to open it. I'm guessing it's from a rock or something. Probably 1/3 the size of an eraser head. So what do I do now? Is this a job for touch up paint? If so, Any tips on applying?
  2. Dec 19, 2013 at 3:35 PM
    NewGuyJosh
    It is the new blue color so yes it is fairly dark
  3. Dec 19, 2013 at 3:38 PM
    Tacoma Mike
    Southern Maine
    Order a tube from the dealer.
    Keep it in your truck.
    Touch up as necessary.
    I use a toothpick to make sure I get in the edge of the chip without overloading it with to much paint.
  4. Dec 19, 2013 at 4:03 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Above suggestions are the easiest but may not result in a fully hidden repair. I've used a method of touching up with base coat to add color to the chip following with clear coat (several coats) to fill. After cure, use a razor blade to scrape smooth, followed by 1500 grit, compound, polish, then wax. Search you tube on Kevin Tetz paint chip repair.
  5. Dec 19, 2013 at 4:05 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Some people use Dupli-color.
  6. Dec 19, 2013 at 4:09 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I'd hit up the dealer. Being such a new truck, they may fix it for free. Good luck!
  7. Dec 19, 2013 at 4:18 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Yes, definitely hit up the dealer, I got my whole hood repainted on a new Saturn I purchased back in the late 90's, gratis, for some strange reason, the paint started to bubble in spots on the hood after a couple of weeks, weird...the hoods were metal, the plastic fenders, doors and side panels had no problems...
    The factory repaint was spot on...
    Go to dealer first...
  8. Dec 19, 2013 at 4:23 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    just have a beer and get over it...shit happens. It'll happen again too.
    Why go to the dealer with a sob story, looking for free shit...why's everyone always want free shit?
  9. Dec 19, 2013 at 4:29 PM
    Offduty
    Offduty Member
    Gary
    Colorado
    2014 DCSB TRD Off Road MGM
    Vent Visors, N-Fab Light Bar, KC Lights, Tonnaeu Cover, N-Fab Nerf Bars
    Big difference between a rock chip and a factory paint defect. The Dealer is not going to repair a rock chip under warranty. A factory paint defect will be covered under your warranty. The proper way to repair is to base color coat, clear coat, let dry and sand with wet/dry sandpaper and then buff with compond then fine polish
  10. Dec 19, 2013 at 4:38 PM
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    Exactly get over it!!It won't be the last!!
  11. Dec 19, 2013 at 4:48 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    GET DR. COLORCHIP THE TOUCH UP PAINT SUCKS ASS!!! I NOW HAVE A FREAKING PAINT BLOB ON MY TRUCK FROM IT AND I WILL BE ORDERING DR. COLORCHIP SINCE IT LOOKS LIKE IT WORKS AND IT IS AS SIMPLE AS PAINT IT ON AND THEN WIPE OFF THE EXCESS.
  12. Dec 19, 2013 at 4:53 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I would not advise keeping it in your truck. Paint doesn't like climate changes. Store somewhere climate controlled (in the A/C of your home, for example) and it will last a lot longer. Sold paint for Lowes for two years now.
  13. Dec 19, 2013 at 4:58 PM
    sfhjr
    sfhjr Active Member
    Stan
    Eastern, PA
    2013 TRD Off Road DCSB MGM
    ARE CX Series Cap, Pop n Lock, Weather Tech: Floor Mat's & Side Window Deflectors, OEM Bed Mat, LED Bed Lights
    Look's like it's time to trade the old girl in.
  14. Dec 19, 2013 at 5:05 PM
    Offduty
    Offduty Member
    Gary
    Colorado
    Dr. color shit looks like covered up acne
  15. Dec 19, 2013 at 5:43 PM
    Tacoma Mike
    Southern Maine
    I never had an issue with it over the years but your point is well taken.
