Paint damage from shell
Discussion in '1st Gen. Tacomas (1995-2004)' started by buzzboy, May 29, 2010.
  1. May 29, 2010 at 10:17 PM
    buzzboy
    buzzboy [OP] Member
    san diego
    2001 Creampuff
    2 into 1 lighter adapter!
    Bought an '01 Tacoma witha shell. I have no use for it (and is for sale btw) and I am removing it, however, the seal rubbed the paint off the cab. Looking for advice on repairing the shell scar. Can it be repaired or is it new paint for the whole truck? (Searched, but couldn't find any similar threads...Thanks.)
  2. May 29, 2010 at 11:47 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I ended up getting my bed Line-x'd after removing the plastic bed liner and seeing all the damage it caused. I figure something like that would work good for you as well, even if you decide to put your shell back on later.
  3. May 29, 2010 at 11:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I think you're looking at major $ to fix that with paint and have it look right (color match).
    Either paint the whole thing or line x it as suggested. I have seen trucks with line x on the back of the cab. Pretty sure they had the same issue as you, and that was the cheapest way to fix it. Didn't look too bad. You might even look into getting the line x color matched. It seems like I have heard of them matching to your paint.
  4. May 30, 2010 at 9:12 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Such cab paint damage is common with the pass-through boots / seals used with canopies.
    The main issue is how picky you are about the looks of your cab's rear wall. Unless you're really picky, you can get by with having a competent paint / body shop prep and repaint the affected area only. Seems to me this would look a lot less 'patchwork' than going with Line-X on the rear cab wall.
  5. May 30, 2010 at 9:53 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I think if your going to do something do it right have a good body shop paint it. You'll feel much better about it.
  6. May 30, 2010 at 5:00 PM
    buzzboy
    buzzboy [OP] Member
    san diego
    2001 Creampuff
    Thanks for the replies.Looks like I 'll try a body shop as opposed to the line x idea.The paints still nice and I'd rather try and maintain its' integrity. Appreciate the help.
