Paint Defender Spray!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EFalco50, Aug 4, 2013.
  1. Aug 4, 2013 at 8:34 PM
    EFalco50
    EFalco50 [OP] Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
  2. Aug 4, 2013 at 8:38 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    interesting... thanks for sharing! :thumbsup:
  3. Aug 4, 2013 at 8:40 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I've seen Youtube videos of it and it's suppose to be the same as putting down 3M protector on your vehicle. I've seen commercials on TV about it and got pretty excited. Then I realized that I had already done it on my truck. If I didn't already have it, I'd try it out.
  4. Aug 4, 2013 at 8:42 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    I see it as a potential application after doing your Dip Plastic job to protect it.
  5. Aug 4, 2013 at 9:01 PM
    jw1983
    Alberta
    What about just doing clear dip over your project?
    I wanted to put 3M over my dipped stuff and I was told it hasn't been done yet. I would think that removing the dip on top of the 3M, the 3M would come up with it. YOu think that samething would happen with the amount of glue on the 3M being on top of the Plasti Dip.
  6. Aug 4, 2013 at 9:34 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Someone be a guinea pig and use it on their Taco :D. Take lots of pics and or make a vid. Would do it to my Taco if the review is good.
  7. Aug 5, 2013 at 8:30 AM
    jw1983
    Alberta
    Oh shit, that's it! 1-2 years. You're better off getting the other stuff then getting the spray on then. I know that it's going to be more expensive, but it's going to be worth it.
  8. Aug 6, 2013 at 6:46 AM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    I could see its best use in areas that are common for rock chips.
  9. Aug 6, 2013 at 6:50 AM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    seems legit
  10. Aug 6, 2013 at 6:52 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    This is actually a really cool thing. It's like $20 a can and that will do the entire front end like a clear bra. They say it does not last as long as the actual film, but this is much cheaper. If you go and get your car or truck clear bra'd by a pro it could cost as much as $500-700. Even then if they get sand blasted or marred up you have to replace it. I sprayed this stuff on some parts as a trial thing. It flowed out like glass. I was impressed.
  11. Aug 6, 2013 at 6:53 AM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Sounds awesome , gonna have to try it can't beat that price.
  12. Aug 6, 2013 at 6:57 AM
    ntilehman
    Seth
    Charlotte, NC
    Its pretty cool. I was hesitant to see how it would flow out and become one clear piece. It did though. Follow the directions of a coat in one direction then the next coat perpendicular to the last. I think it was 3 coats. There is no flash time in between like paint. You just keep spraying. It looks hazy and all weird before while it's wet.
  13. Aug 6, 2013 at 8:34 AM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    No flash time? Woah.. I think they are selling this stuff at autozone I'll have to go check it out.
  14. Oct 15, 2013 at 5:31 AM
    spieler
    spieler Well-Known Member
    Jonesborough, TN
    13 white DCSB SR5 4x4
    3" Lift kit/265 Duratracs/SCS Stealth 6 matte black wheels, OEM White grille switcheroo, TRD skid derped white, CSjumper drtl map dome parking lights fog light bulbs, Lifetime LED headlights, **Reverse light mod, Foglight anytime Mod, Trimmed mudflaps, Fully Debadged, 3rd brake light cover by well...me, Liquid Innovations black carbon dipped front emblem, G-Tek Fab diamond plate white door sill protectors, SOS Bolt-on Sliders bedlined, MattGecko rear window security bar, Hardwired Radar Detector w/custom sucker mount, Horse Stall Bed Mat, Audiocontrol LC2i with custom mount ACR-1 remote, Custom sub box behind drivers rear seat, Mag light holder behind seat, Center console organizer , Passenger seatbelt flapper fix, Tailgate anti-theft Mod, Bed storage Locks Mod, hygieneboy ghetto gutter grille guard
    Any updates? pics???
  15. Oct 15, 2013 at 8:06 AM
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    After being quoted over $600 to have the film put on the leading edge of my hood and around the headlights, I'm going to try this spray instead. I'm itching to get the ugly plastic bug deflector off the hood. Respraying every year seems like no big deal.
  16. Oct 15, 2013 at 9:16 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    From what I've read, make sure you follow the instructions exactly and put down enough film thickness or it'll be difficult to peel off in the future.
  17. Oct 15, 2013 at 11:15 AM
    Nmwill
    Nmwill Well-Known Member
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Blacked out emblems and grill. 265/75's shortened antenna
    I used It on my rocker panels to protect from rocks pitched from my tires. I don't think I put on a thick enough coat. Cus a month or so later it had gouges out of it. I'll be trying it again soon. I'll take pics this time
  18. Oct 15, 2013 at 12:32 PM
    adio
    HI
    ^^ would you recommend the product?
  19. Oct 16, 2013 at 5:37 AM
    spieler
    Jonesborough, TN
    I've seen some reviews where people cant get bugs off afterwards...like they were glued in. I wonder if that wasn't proper coverage of the product or proper curing. It says apply between 65-90 degrees and then sun cure for a few hours...I may have missed my window and might have to wait until spring to do it unless I heat my garage! My super white needs something because I have already had to wash the front 3 times in a month whereas my silver Ford I traded in got a bath like.....a couple times a year and bugs came off with some bicep grease.
