Paint for Making Toyota Emblem Match Black Plastic on Grill?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hot Taco, Jun 18, 2013.
  1. Jun 18, 2013 at 7:36 PM
    Hot Taco
    Hot Taco [OP] Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    I'm in the process of doing the black headlight mod and painting the Toyota emblem on the grill to hopefully match the black plastic on the grill.
    I started painting everything with Rust-Oleum satin black paint plastic paint, but it was too glossy, so I bought some Rust-Oleum matte black automotive paint. While the finish looks good, in daylight the painted surface looks dark green compared to the black plast on the grill. Blech. :(
    Is there a different brand of spray paint that comes in a matte finish that matches the black plastic of the grill a bit better? I'm going to head to the store(s) tomorrow in search of different paint, but it's pretty much a crap-shoot at this point to try and figure-out which brand might actually be black.
  2. Jun 18, 2013 at 7:40 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Mar-Hyde black satin. Available at any NAPA. Used by all bodyshops... it's how I did mine
  3. Jun 18, 2013 at 7:42 PM
    Hot Taco
    Richfield, WI
    Ooooh... thanks! I forgot NAPA even existed, but I do have one near me. :D
  4. Jun 18, 2013 at 7:51 PM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Dupli-Color Toyota Black
  5. Jun 18, 2013 at 7:52 PM
    Hot Taco
    Richfield, WI
    Is this paint glossy or matte?
  6. Jun 18, 2013 at 7:53 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I usually happen to use whatever I have on hand in the realm of flat/matte black. Ended up painting mine with flat black duplicolor enamel, worked like a charm. I could imagine krylon camo ultra flat black or whatever its called would work too.
  7. Jun 18, 2013 at 7:54 PM
    byrd
    byrd Unknown
    David
    Kansas
    Glossy but you can get Rust-oleum Matte clear coat.
  8. Jun 18, 2013 at 8:30 PM
    EndOfAnEra
    EndOfAnEra Well-Known Member
    2013 TRD Sport Magnetic Gray Blackout
    Black badges, GoRhino Dominator II bars, Ion Alloy 179 wheels
    The Krylon Gloss Black is really close, and bed liner spray looks really good.
  9. Jun 18, 2013 at 8:35 PM
    WHPLSH3
    Vance
    Alberta
    Black Satin is an EXACT MATCH. If your emblem is down to the bare plastic, this will bite right in because it's laquer based. Will not chip either...
  10. Jun 18, 2013 at 8:40 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Derp it.. I did mine two years ago no peeling whatsoever.
  11. Jun 19, 2013 at 5:23 AM
    Hot Taco
    Richfield, WI
    Is this the stuff? It says you can paint aluminum foil with it, then crunch-up the foil and the paint will still stick.
    Hehe... as mentioned in my original post, I'm also doing the black headlight mod, so no "Derp" for me :eek:
  12. Jun 19, 2013 at 5:25 AM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    Plasti-derp it
  13. Jun 19, 2013 at 7:06 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Plastidip way more fun than spray paint.. and probably half the time and its only 6 bucks a can woohoo!!
  14. Jun 19, 2013 at 9:09 AM
    WHPLSH3
    Vance
    Alberta
    That's the stuff!
  15. Jun 19, 2013 at 7:17 PM
    Hot Taco
    Richfield, WI
    Well, apparently Mar-Hyde is available at any NAPA except the one by me :( The guy at the counter new what I was talking about but said he can't remember the last time they carried Mar-Hyde products.
    Not wanting to special order something and wait a week, I got Dupli-Color Trim Paint instead. So far, it looks really good. I just sprayed my emblem as a test and I'm pretty happy with it.
  16. Jun 19, 2013 at 8:12 PM
    WHPLSH3
    Vance
    Alberta
    I'm not familiar with that product but from what I googled, it looks like a suitable substitute. Good choice!
  17. Jun 19, 2013 at 8:21 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    that duplicolor trim paint is great. ive been using it for years. matches the black trim on any vehicle and holds great. ive painted a bunch of interior pieces and a few exterior with it.
    thats what i would of recommended. :thumbsup:
  18. Jun 19, 2013 at 8:25 PM
    Hot Taco
    Richfield, WI
    I wonder if it would hold-up well if I painted my lower valence piece with it? The lower valence piece on the 2012/2012 is gray and I'd rather have it black. However, I have a lot of gravel trucks near me so I'm a bit concerned about the paints ability to take a hit!
  19. Jun 19, 2013 at 8:29 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Plasti-dip works great and matches nicely. I just rescently did the BHLM and changed my plasti-dip from black to white.
  20. Jun 19, 2013 at 8:33 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i originally painted my lower valence with the trim paint.. and although it held up for awhile.. the sand dunes, dirt roads, etc here eventually started to chip at it. i switched to the Derp for the lower and it has held up much better. for everything else though, the trim paint has worked great.
