Paint for Sliders - POR 15 TopCoat?
Discussion in 'Armor' started by Scott B., Aug 18, 2016.
  1. Jan 17, 2019 at 1:12 AM
    runner05
    runner05 Well-Known Member
    Karl
    I chose powder coating. If they get scraped, I will just use spray paint.
  2. Jan 17, 2019 at 7:58 AM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    hopefully *when* they get scraped :devil:
  3. Jan 17, 2019 at 8:01 AM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    In my experience, if you wheel and use your sliders, nothing works well. Granite+slider = bare metal no matter what you put on. Now between the frame and the sliders I dunno. I just use rustoleum or similar.
    Nothing says I had a good day better than fresh metal showing on a slider.
    Key-Rei and xxTacocaTxx like this.
  4. Jan 17, 2019 at 8:05 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    I tried rattle can first, but it came off from salt/sand spray the first time i drove in the snow. covered everything with POR-15 after that and havent had problems with that since. I top coated with truck bed liner. touchups are easy too.
    ecgreen[QUOTED] likes this.
  5. Jan 17, 2019 at 8:07 AM
    ecgreen
    Sean
    Hmmm...interesting. Did you use an etching primer? I didnt mention I used primer at first.
    Admittedly I have had fsome flaking, but none that I care about. I am sure the the POR-15 would not flake if done right.
  6. Jan 17, 2019 at 8:10 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    i did also use etching primer primer. its possible that the areas that came off weren't clean enough. i wiped down with acetone and alcohol before applying. also, its worth noting that i did not strip anything before switching to POR. i just wire brushed the loose stuff off and applied POR on top of everything else.
    ecgreen likes this.
  7. Jan 17, 2019 at 8:15 AM
    tundraconvert
    tundraconvert Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    I'm on first round of painting sliders. You have put a coat of spray paint over bedliner? I'm asking because my main concern with bedliner is the fading that can occur.
    Thanks for feedback.
    Casper66[QUOTED] likes this.
  8. Jan 17, 2019 at 8:22 AM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    i wasn't aware of that either. seems kinda weird since truck beds are exposed to sun in a lot of cases. fortunately, it is real easy to touch up
  9. Jan 17, 2019 at 9:30 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    I do yes, the cheap diy bed liner has almost no UV protection. It will turn chalky and break up with sun exposure. A couple of simple coats of spray paint will offer a big improvement in protection
  10. Jan 17, 2019 at 10:00 AM
    tundraconvert
    Eric
    San Diego
    Thank you.
    Casper66 likes this.
  11. Jan 11, 2021 at 8:57 PM
    NWBoon
    NWBoon Well-Known Member
    Puget Sound, WA
    2019 TRD OR DCSB Cement
    Thanks for all the informative posts, I’ve never even heard of POR15. I ordered bare rock sliders last November and plan on using POR15 as a base coat. The top coat will be one of the Rustoleum products. What size POR15 would should I buy?
    psmura likes this.
  12. Jan 11, 2021 at 9:19 PM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    I recall a quart was enough for two coats on my sliders
    NWBoon[QUOTED] likes this.
  13. Jan 11, 2021 at 9:25 PM
    NWBoon
    Puget Sound, WA
    Thank you!
  14. Jan 11, 2021 at 9:35 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Do you spray on or brush on the Por15?
  15. Jan 12, 2021 at 6:36 AM
    #35
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    I bought a bunch of those cheapy 1” paint brushes from Home Depot to use as disposable paint brushes. Stuff is a bitch to clean.
  16. Jan 12, 2021 at 9:54 AM
    #36
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    NWBoon likes this.
  17. Jan 12, 2021 at 10:41 AM
    #37
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I forgot about this thread!
    I ended up using the rattlecan method. After cleaning the metal, I applied 2 coats of Rustoleum self-etching primer, then 2 coats of Rustoleum bed liner. Along the bracket part that is bolted to the frame, I used Rustoleum gloss black instead of bedliner. My thinking was the gloss paint would not trap as much dirt and moisture as the bedliner. Not sure how valid the idea is, but it sounded good at the time. ;)
    The bedliner is holding up well. The undersides have not been sandblasted. However, the liner has worn off where the slider is used as a step by my passenger. And, there a couple of places where contact with immovable objects has scraped the paint off. To be expected.
    This spring, I hope to clean up the affected areas, prime, and recoat the entire sliders with liner.
    NWBoon likes this.
  18. Jan 13, 2021 at 9:46 AM
    #38
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I painted my sliders the exact method and it has held up really well. I'll be doing the same this spring. Remove and respray with Rustoleum bed liner. I did touch up spots here and there but it needs a new coat. Cheap and effective.
    NWBoon and Scott B.[QUOTED][OP] like this.
  19. Apr 8, 2021 at 5:04 AM
    #39
    lynyrd3
    Bill
    East Central Upstate NY
    I’m about to clean up my sliders for about the 4th time . Original powder coat sucked and they started rusting after the first winter . Pain in the ass because they are welded on :( I’ve used Rustoleum rusty metal primer ,Rustoleum rust reformer and bed liner . Nothing holds up to the North East winters . If had bolt on sliders I would take them off have them sand blasted and start over .
  20. Apr 8, 2021 at 11:02 AM
    #40
    psmura
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Rustoleum products are pretty much useless in NY winters. POR-15 or Chassis Saver is the only way to go. Topcoat with the rustoleum.
    wi_taco and lynyrd3[QUOTED] like this.
