Paint gone to hell!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GSD, May 29, 2011.
  1. May 29, 2011 at 1:56 PM
    GSD
    GSD [OP] Well-Known Member
    Saskatoon SK
    09 TRD SPORT
    Nitto terra grapplers,raider cap with thule tracker two roof system, 13 inch rubber antenna, wire harness mod, seat belt chime mod
    Anyone with a 2nd Gen re paint their truck completely? I have a 09 Black Sand Pearl that has seen a lot of dirt road and has a shit load of rock chips and rock rash in front of the back wheel wells. It is so bad that the 3m rock guard has peeled off on one side. Bought the truck second hand for a real good price with very low kms and the extended warranty that was fully transferable. The interior is mint as well and doesn't have even the smallest dent on the body. Thought it wouldn't bug me that much but now Im loosing sleep over it. I need some good advice.
  2. May 29, 2011 at 2:14 PM
    JKD
    JKD Well-Known Member
    If at all possible, I always prefer to keep the factory paint in place. So to me, if the chips aren't deep enough to rust and can be filled, I'd go that route.
  3. May 29, 2011 at 2:18 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
    There are a tone of them. Would look like shit if I did it my self. I should go see a pro I guess.
  4. May 29, 2011 at 2:25 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...and put some steps on it to protect the underside and those rear panels.
    It sounds like that is your only shot at avoiding the 'ground hog day' effect with the type of roads you need to drive.
  5. May 29, 2011 at 2:27 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
    Good advice.
  6. May 29, 2011 at 2:32 PM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    bedliner along the lower portion of the body?
  7. May 29, 2011 at 2:34 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
    Yes
  8. May 29, 2011 at 2:43 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Did you ever wax? Kept the mud flaps on? Another reason why i didn't get black....
  9. May 29, 2011 at 2:46 PM
    WNYTACOMA
    Clarence, New York
    It doesn't matter is the stuff is Kevlar coated, your only hope is to first limit (drastically) the number of projectiles coming at those areas if you want to keep it decent on those type roads.
    ...and you might consider a 'bug shield for that leading edge of the hood if those are roads you must drive. If you do go that route, get the one that mounts underneat and use fth little rubber nipples to even further keep the underside leading edge of the hood from the potentially vibrating shield.
    Regardless of what you do, it will take a beating on the roads. All you can do is attempt to lessen teh vulnerability of the usual areas...
  10. May 29, 2011 at 2:47 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
    I have not waxed since I have had it, flaps have never been off. Looking for advice on a fix. Is it worth painting the whole thing? Once fixed will be treated like a baby.
  11. May 29, 2011 at 2:52 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    Get the thing painted. I don't see the big problem other then the cost of it. The hardest part will be finding the right shop to do the work. If you do get it painted you might want to start protecting it with some klass or other form of wax of your choice.
  12. May 29, 2011 at 2:56 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    I have the exact same truck and mine looks like shit around the rear wheel area also. I avoid gravel roads at all costs. The damage to my paint seems excessive for the little dirt roads my truck has seen.
    I'll probably end up putting some steps on to try and limit it.
    Weakest paint job I've ever owned!
  13. May 29, 2011 at 3:33 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
    Interesting
  14. May 29, 2011 at 3:56 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
  15. May 29, 2011 at 4:02 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
  16. May 29, 2011 at 6:32 PM
    JKD
    My paint seems (?) to have hardened more than it was in the first few months I had it. It's SWB, and the best description I had for the durability of the paint was "like pretty blue cake frosting".
    I repaired a half dozen or so chips in the first year. Since then, under the same driving conditions, I haven't had any more. Weird.
  17. May 29, 2011 at 6:48 PM
    WNYTACOMA
    Clarence, New York
    Not to be Captain Obvious, but i suspect going from Black to white will generally have that effect, as far as visible swirl marks go...
  18. May 29, 2011 at 6:57 PM
    GSD
    Saskatoon SK
    09 TRD SPORT
    Hell IWould be happy with swirl marks if that is all it was. I'm talking too many chips to even begin counting!
  19. May 29, 2011 at 10:23 PM
    tanzak88
    tanzak88 Well-Known Member
    Tanner
    BC, C-eh-N-eh-D-eh
    It's these god damn Canadian roads. My truck, with 10700km on it is the same way. I travel on 18km of dirt road to get to work, once every 4 days. I hate it. I'll be getting some rock sliders I think... unless I can find some cheap tube steps on craigslist or kijiji...
    Good luck.
  20. May 29, 2011 at 10:29 PM
    BigBlueTaco
    BigBlueTaco Member
    Tacoma D-Cab 4x4
    My 2011 has the same issue. I took it to the dealer and I got the expected blow off. The service manager did admit that Toyota is using a "much thinner" clearcoat now. Throw in a frigging dash rattle and I'm quite irritated with Toyota right now.
